I just tried to use the zwave js firmware update feature, but it doesn’t seem to update the firmware on my Inovelli Red series dimmers. Here is the log:
2022-09-17T13:21:25.387Z CNTRLR » [Node 019] Sending firmware fragment 388 / 389
2022-09-17T13:21:25.470Z CNTRLR » [Node 019] Sending firmware fragment 389 / 389
2022-09-17T13:21:25.939Z CNTRLR « [Node 019] Firmware update completed with status OK_RestartPending
2022-09-17T13:21:25.942Z CNTRLR [Node 019] Firmware updated, scheduling interview in 5 seconds...
2022-09-17T13:21:25.959Z CNTRLR [Node 019] Downloading firmware update from https://files.inovelli.com/firmwar
e/LZW31-SN/Beta/1.61/LZW31-SN_1.61.otz...
2022-09-17T13:21:26.739Z CNTRLR [Node 019] Firmware update https://files.inovelli.com/firmware/LZW31-SN/Beta/1
.61/LZW31-SN_1.61.otz downloaded, installing...
2022-09-17T13:21:27.841Z CNTRLR [Node 019] Timed out while waiting for a response from the node (ZW0201)
2022-09-17T13:21:30.967Z CNTRLR [Node 019] Beginning interview - last completed stage: None
2022-09-17T13:21:30.970Z CNTRLR [Node 019] new node, doing a full interview...
2022-09-17T13:21:30.974Z CNTRLR » [Node 019] querying protocol info...
2022-09-17T13:21:31.043Z CNTRLR « [Node 019] received response for protocol info:
basic device class: Routing Slave
generic device class: Multilevel Switch
specific device class: Multilevel Power Switch
node type: End Node
is always listening: true
is frequent listening: false
can route messages: true
supports security: false
supports beaming: true
maximum data rate: 100000 kbps
protocol version: 3
2022-09-17T13:21:31.051Z CNTRLR [Node 019] Interview stage completed: ProtocolInfo
2022-09-17T13:21:31.054Z CNTRLR » [Node 019] querying node info...
2022-09-17T13:21:31.144Z CNTRLR « [Node 019] node info received
supported CCs:
· Z-Wave Plus Info
· Multilevel Switch
· Configuration
· Association
· Association Group Information
· Transport Service
· Version
· Manufacturer Specific
· Device Reset Locally
· Powerlevel
· Security
· Meter
· Security 2
· Central Scene
· Supervision
· Protection
· Application Status
· Firmware Update Meta Data
2022-09-17T13:21:31.153Z CNTRLR [Node 019] Interview stage completed: NodeInfo
2022-09-17T13:21:31.160Z CNTRLR [Node 019] Interviewing Manufacturer Specific...
2022-09-17T13:21:31.162Z CNTRLR » [Node 019] querying manufacturer information...
2022-09-17T13:21:31.243Z CNTRLR « [Node 019] received response for manufacturer information:
manufacturer: Inovelli (0x031e)
product type: 0x01
product id: 0x01
2022-09-17T13:21:31.249Z CNTRLR [Node 019] Interviewing Version...
2022-09-17T13:21:31.251Z CNTRLR » [Node 019] querying the CC version for Version...
2022-09-17T13:21:31.335Z CNTRLR [Node 019] supports CC Version (0x86) in version 2
2022-09-17T13:21:31.337Z CNTRLR » [Node 019] querying node versions...
2022-09-17T13:21:31.415Z CNTRLR « [Node 019] received response for node versions:
library type: Enhanced Slave (0x03)
protocol version: 6.4
firmware versions: 1.52, 1.45
hardware version: 1
