Firmware updating Conbee 2 stick?
Hi All,
I run my HA on a Synology NAS in docker using a Conbee 2 stick together with ZHA.
Now I plan to firmware update my stick, never done that since I bought it.
I cannot do that on my NAS using ZHA (as I understand) so I thought I would move the stick to my computer and flash the firmware there.
My question is:
Will I lose any programming/have to reconnect my devices when I return the stick after firmware update to my NAS?
Thanks,
AseKarlsson
Should work without having to re-pair anything.
Thanks Francis, Great!
Can confirm - reflashed latest firmware on mine with a Windows PC last Tuesday while troubleshooting an issue. stick retains all Zigbee network settings and hooked right up when returned.
Thanks Nathan for the confirmation!
Just confirming, Did the flash today and everything worked fine afterwards!
(Windows 11 could not find ths stick, so had to use Windows 10)
Thanks,
AseKarlsson
Hi, Iā€™m thinking of doing a firmware update, did you guys use any guide or how did you go about it?
Nevermind, found this ConBee 2 Firmware
I updated two sticks without any problems: one via windows with the command line flasher and one via the Phoscon web interface on a VM.
-David
