Firmware version unavailable
Hello, since my last update I don’t see anymore the Firmware version. It is the same on Apollo Air-1 / Apollo Msr-1 and also on my ESP32 S3 Box 3
Do I miss something ? what I can do to see again the FW version ?
Thanks for your help
screenshot-discord.com-2024.04.05-13_19_48
It is under Diagnostic
it is normal if the ESPHome add-on is not running
afbeelding
Thanks but the addon is running, the reason why I don’t understand :frowning:
On my setup it’s under Configuration
Just started the add-on
afbeelding
So maybe try to restart the add-on.
Good idee, I have try but it changed nothing :frowning:
The esphome Addon has nothing to do with the esphome integration.
The addon is only used when compiling/flashing the esphome (and that doesn’t even have to run on HA, i used to compile it with python from cli on my w10 machine).
When unit has been flashed, addon isn’t required anymore and can be stopped :wink:
But do you have a text sensor for version info?
# Example configuration entry
text_sensor:
  - platform: version
Without that, no version info :thinking:
Thank you, you give me interesting infos about the fact that I don’t have to let always running ESPHome :slight_smile: so, I’ve stop it from now and can confirm that all is running good
Where do I have to add this “text sensor” ?
It is strange because before the la ESPhome update I was able to see the alert if the Firmware was the last or not without to add anything.
BTW, I can see, like before, some infos on the top left of the page. Maybe they removed the entities Firmware ?
screenshot-a982dnqpm6zb609xmsuxxlxnd8c5emi0.ui.nabu.casa-2024.04.05-14_40_18
It should be in your yaml of esphome.
Maybe post it here (redacted if you want)?
Click on the firmware entity, it should show like
The problem is that I don’t have any entities “Firmware”
When I click on Firmware, I have this texte in the window:
This entity is no longer provided by the esphome integration. If the entity is no longer used, delete it from the settings.
Finally I found where was the problem. To activate the Firmware , you have to activate in the settings of ESP home plugin the “Home Assistant Dashboard Integration”
