Please could someone with a better eye than I take a look at my code below and point out the error of my ways?
The error I get is:
Invalid config for [automation]: invalid template (TemplateSyntaxError: Encountered unknown tag 'endif'.) for dictionary value @ data['action'][0]['data_template']['entity_id']. Got None. (See /config/configuration.yaml, line 157). Please check the docs at https://home-assistant.io/components/automation/
- alias: "Auto Change Channel from timer"
platform: state
entity_id: input_boolean.auto_channel_change_active
to: 'on'
- service: automation.turn_on
data_template:
entity_id: >
{& if is_state('input_select.channel_select', 'BBC 1') %}
automation.bbc1
{& elif is_state('input_select.channel_select', 'BBC 2') %}
automation.bbc2
{& if is_state('input_select.channel_select', 'ITV') %}
automation.itv
{& elif is_state('input_select.channel_select', 'Forumla 1') %}
automation.formula1
{& if is_state('input_select.channel_select', 'Sky News') %}
automation.sky_news
{& elif is_state('input_select.channel_select', 'BT Sport 1') %}
automation.bt_sport_1
{& if is_state('input_select.channel_select', 'BT Sport 2') %}
automation.bt_sport_2
{& elif is_state('input_select.channel_select', 'BT Sport 3') %}
automation.bt_sport_3
{& if is_state('input_select.channel_select', 'Eurosport 1') %}
automation.eurosport_1
{& elif is_state('input_select.channel_select', 'Eurosport 2') %}
automation.eurosport_2
{% endif %}
- service: input_boolean.turn_off
entity_id: input_boolean.tv_channel_change_clock_status
