Im trying to do what i thought would be a simple automation. Tado heating is all added and working correctly.
What i’m trying to do is activate a smart plug if the temperature dips below a set level and deactivate when it hits another level (deactivate has a separate automation for now). Basically i’ve got a dumb electric radiator which I want to turn on and off when the tado thermostat reads a temperature. Ive attached my automation
What’s the friendly name of your Tado thermostat? is it “Temperature” as it shows in your picture? sounds strange. Did you type “Temperature” manually?
You must find your device in the Device drop down menu, like this:
so i “think” that the thermostat has physical entry in the home assistant (power, connected etc), then there is a Zone with the actual temperature. Ive attached the 2 entries
You actually want to base your automation on the heating percentage.
When that goes over 0% turn on your plug.
That way it will automatically take into account, home away status, weather data, time, etc
Don’t several of those features require subscription? I believe away mode requires it.
I never cared about that because I want to control tado locally and by doing so those features just won’t work.
If I manually set the Tado to, say, 21ºC, those features will still apply since my tado is connected and registered in the Tado cloud, right?
that heating percentage is useful for this thread’s particular case but for Tado itself there’s no need to use that, it uses that value automatically, right?
It was useful for the o.p. that’s why it was shared.
It’s also useful for me.
If you bought tado earlier than 2 years ago there’s no subscription at all.
So thanks everyone for your inputs. Ive take on board and changed the setup (and naming), but it’s still wont trigger the heater. Here is my current code. Ive been playing around with “attribute” and “for” but again the automation hasn’t triggered since last week when i activated it manually. Any ideas?
