First ESP program not showing in HA
I wrote a simple program to control my pool filler.
But only once in a while does it show in HA.
WiFi is like -40dBm
It does show in ESPhome.
It works just fine, but was wondering if their was a noob mistake.
Thanks,
Robert
?How do I list code?
code below
esphome:
friendly_name: Pool Filler
esp8266:
board: nodemcuv2 #esp01_1m
Enable logging
logger:
Enable Home Assistant API
api:
encryption:
key: “**************************”
ota:
password: “********************”
wifi:
ssid: !secret wifi_ssid_ext
Optional manual IP
manual_ip:
static_ip: 192.168.50.201
gateway: 192.168.50.1
subnet: 255.255.255.0
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “Pool-Filler Fallback Hotspot”
password: “********”
captive_portal:
Binary sensors
binary_sensor:
  • platform: gpio
    pin:
    number: D1
    mode: INPUT_PULLUP
    inverted: true
    publish_initial_state: True
    filters:
    • delayed_off: 60000ms
      on_press:
      then:
      • switch.turn_on: Pool_Valve
      • logger.log: “Valve On”
        on_release:
        then:
      • switch.turn_off: Pool_Valve
      • logger.log: “Valve Off”
switch:
  • platform: gpio
    pin:
    number: D7
    inverted: false
What do you mean “show in HA” - exactly where?
esphome:
esp8266:
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "**********"
ota:
  password: "********"
wifi:
  # Optional manual IP
  manual_ip:
  ap:
    ssid: "Pool-Filler Fallback Hotspot"
captive_portal:
## Binary sensors
binary_sensor:
  - platform: gpio
    pin:
      number: D1
      mode: INPUT_PULLUP
      inverted: true
    filters:
      - delayed_off: 60000ms
    on_press:
      then:
        - switch.turn_on: Pool_Valve
        - logger.log: "Valve On"
    on_release:
      then:
        - switch.turn_off: Pool_Valve
        - logger.log: "Valve Off"
switch:
  - platform: gpio
    pin:
      number: D7
      inverted: false
I guess that was open ended.
When I go to Overview it simply says Unavailable.
But I can see it in ESPhome.
Just didn’t know if it was something I didn’t put in my yaml file.
Robert
