I have bought a rpi4 model b 4GB, I put image hassos_rpi4-5.9.img on a 32SD, rpi4 connected LAN.
I have try 3 different SD.
connecting via browser to homeassistant.local:8123 I can see a page “Preparing Home Assistant”… more than 20 hours and the page say always “Preparing Home Assistant”.
I have try for several day… never complete first installation
I had the same (with RPI 3) and never got it fully to work either.
If you press the blue ‘button’ of the installation you will see where it is hanging.
I either had issues downloading files from a repo or with communication with my internal docker
Make sure you have pi-hole disabled during install (if you are running this). Sides by that I can’t offer much advice. Glad i am not alone with this issue
20-12-21 18:42:56 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
20-12-21 18:43:26 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-homeassistant:landingpage to homeassistant/raspberrypi4-homeassistant:2020.12.1
20-12-21 18:43:26 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-homeassistant with tag 2020.12.1.
20-12-21 18:43:41 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fraspberrypi4-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)").
20-12-21 18:43:41 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
20-12-21 18:44:11 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-homeassistant:landingpage to homeassistant/raspberrypi4-homeassistant:2020.12.1
20-12-21 18:44:11 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-homeassistant with tag 2020.12.1.
20-12-21 18:44:26 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-homeassistant:2020.12.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2020.12.1&fromImage=homeassistant%2Fraspberrypi4-homeassistant: Internal Server Error ("Get "https://registry-1.docker.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)").
20-12-21 18:44:26 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
I guess my reply won’t help you, but the issue I have, is the same. After waiting A LONG time it would sometimes boot till the setup phase. Then it was still barely usable because I cannot install any addons nor update it.
I got my device installed after at least 10 attempts. Sometimes rebooting it (many times) got me to this point.
