I downloaded the image for my pi3, installed and all is fine.
THen I copied my HASSBIAN configuration file to the conif directory, removed SSL reference, removed mqtt, and restarted.
It does restart, giving some errors in the log, but then it suddenly HASS.IO hangs.
How to troubleshoots
when I try to go to the hass.io panel it gives an error
Failed to load the hass.io panel from supervisor
in the log I see this error
2017-07-26 14:59:42 ERROR (MainThread) [homeassistant.loader] Error loading custom_components.binary_sensor.xiaomi. Make sure all dependencies are installed
which dependecies? I copied all files from the custom_component
rpitera
(Robert Pitera)
July 26, 2017, 2:47pm
4
They should be listed in the log after that message but you could also look in the code of the cc’s that you are using. The first couple of lines should list the dependencies.
