Good morning.
I am trying to set up ESPHome with Home Assistant, simply to use the Bluetooth Proxy with different thermometers in the house. Roughly speaking right now I have.
1 Server with TrueNAS Scale and the apps installed from TrueCharts.
Home Assistant installed and running on IP 192.168.1.200
ESPHome installed and running on IP 192.168.1.205
An ESP32 with ESPHome and Bluetooth Proxy installed, with this configuration:
esphome:
friendly_name: Bluetooth Proxy
esp32:
board: esp32dev
framework:
type: esp-idf
version: recommended
# Custom sdkconfig options
sdkconfig_options:
COMPILER_OPTIMIZATION_SIZE: y
# Advanced tweaking options
advanced:
ignore_efuse_mac_crc: false
esp32_ble_tracker:
scan_parameters:
interval: 1100ms
window: 1100ms
active: true
logger:
level: DEBUG
bluetooth_proxy:
active: true
# Enable Home Assistant API
api:
#port: 6053
#encryption:
#key: "hidden"
ota:
password: "hidden"
wifi:
ssid: !secret wifi_ssid
# Optional manual IP
manual_ip:
static_ip: 192.168.1.202
gateway: 192.168.1.1
subnet: 255.255.255.0
fast_connect: true
ap:
ssid: "Bluetooth-Proxy Fallback Hotspot"
password: "hidden"
captive_portal:
Now, from ESPHome I can update the ESP32, but once installed, I go to Home Assistant, add the ESPHome integration and when I enter the IP address of the ESP32 it tells me that it cannot connect, that I check that the .yaml has the line “api:”
Obviously from the HA container I can ping both the ESPHome container and the ESP32 itself.
What am I doing wrong?
