Im very new to Home Assistant and I purchased a Heiman Smart Smoke Sensor HS1SA-Z. Ive managed to set up a Z Wave network and i’ve got the Heiman Smoke Detector showing up in Home Assistant. I’ve also managed to set up iOS notifications and created an Automated Trigger so that when the Smoke Detector goes off I would like a notification to be sent to my iPhone.
Using the Automated UI approach this is the trigger which is created:
I can test the trigger and it does indeed send a notification to my iPhone. I also went into Developer Tools to change the state of the Smoke Detector to On (using binary_sensor.heiman_technology_co_ltd_smart_smoke_sensor_hs1sa_z_sensor) and it does send a notification to my iPhone. OK Great!!
When I go and test the Smoke Detector by blowing smoke into it, the alarm goes off for a good few minutes however Home Assistant does not send the notification. I also checked and the state for binary_sensor.heiman_technology_co_ltd_smart_smoke_sensor_hs1sa_z_sensor is not showing as On so its still in an Off state so I assume this is why it’s not sending the notification.
I am new as well in HA and just received my Heiman Smoke sensors.
Using the Automation UI, I setup the IOS notification based on the following coding :
alias: Message Iphone détection fumée au garage
description: Message Iphone détection fumée au garage
device_id: e9d9b2a3e88334df193d1b77e8f4a2bc
domain: mobile_app
type: notify
title: Détecteur de fumée garage
message: Détection de fumée au garage
mode: single
It works perfectly well if I run the automation or as you did put in debug the Sensor on Status “on”.
But I am facing the same issue if I am blowing smoke into the sensor. The smoke alarm starts but I did not receive any notification on my mobile.
I saw the answer of @wolfpins but I do not know how to how to add the below lines :
platform: state
to: ‘2’`
Apologies for the stupid question but your input will be really appreciated.
