First try... need some help
i just started with ESPhome and HA.
I already got it running to edit a demo sample program to switch 2 LEDs on ESP-Board.
esphome:
  platform: ESP8266
  board: d1_mini
wifi:
  ssid: "-------------"
  password: "--------------"
  ap:
    ssid: "Test Esp Fallback Hotspot"
    password: "1BvuZaiGlfkd"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: "---------"
ota:
web_server:
  port: 80
switch:
  - platform: gpio
    pin:
      number: 16
      inverted: yes
  - platform: gpio
    pin:
      number: 2
      inverted: yes
Now i can switch the onboard-LED and also the LED on the ESP8266 Module.
How can i let switch one LED automatic on this : - sun.is_above_horizon: ?
I am not yet good in the syntax so it would be great to get some help.
Thank you,
Wolfram.
You will need the sun component:
And then to automate your LED switch use the switch turn on/off actions:
So something like this:
time:
  - platform: homeassistant
sun:
  latitude: 48.8584° # your lat and lon here
  longitude: 2.2945°
  on_sunrise:
    - then:
        - switch.turn_on: led2
  on_sunset:
    - then:
        - switch.turn_off: led2
thank you, but i get an error:
Couldn’t find ID ‘LED2’. Please check you have defined an ID with that name in your configuration.
id: LED2 (source myfirst.yaml:52)
Here my Listing:
esphome:
  platform: ESP8266
  board: d1_mini
wifi:
  ssid: "--------"
  password: "--------"
  ap:
captive_portal:
# Enable logging
logger:
api:
ota:
web_server:
  port: 80
switch:
  - platform: gpio
    pin:
      number: 16
      inverted: yes
  - platform: gpio
    pin:
      number: 2
      inverted: yes
time:
sun:
  latitude: 52.xxxxx° # your lat and lon here
  longitude: 8.xxxxxx°
  on_sunrise:
    - then:
        - switch.turn_off: LED2
  on_sunset:
    - then:*
        - switch.turn_on: LED2*
Add ids to your switches to use them in other parts of esphome:
switch:
  - platform: gpio
    pin:
      number: 16
      inverted: yes
  - platform: gpio
    pin:
      number: 2
      inverted: yes
OK, thank you, that works (copiles without errors)
But should`nd be the LED always on regardless of switch state?
Or does the switch-state override the sunrise?
Or is it better to use above_horizont and if yes, how is the syntax for that?
If you don’t wan the LEDs to be able to be manually controlled as a switch, use an output component instead.
You can also just use internal: true and it won’t be exposed to HA
Well, it should show the state in HA,
i made it like this:
switch:
  - platform: gpio
    pin:
      number: 16
      inverted: yes
  - platform: gpio
    pin:
      number: 2
      inverted: yes
output:
  - platform: gpio
    pin:
      number: 2
      inverted: yes
time:
sun:
  latitude: 52.xxxxxxx° # your lat and lon here
  longitude: 8.xxxxx1°
  on_sunrise:
    - then:
        - output.turn_off: Ausgang2
  on_sunset:
    - then:
        - output.turn_on: Ausgang2
But i am asking me, what should be the better way to do something like this:
Should i only program the funtions to the esp8266 and use HA Automation or should i put this into each esp?
How can i display-only (instead of a switch) the state of Ausgang2(LED2)?
Is there a icon like a bulb?
