First try on custom component
I’m trying step by step to implement a fram memory module to esphome.
to do so, i’m trying to setup a custom component, to start with, no fany stuff, just setup and loop.
one thing i don’t understand, why is the log output from the setup not visible in esphome.
The log output from the loop is visible.
is it becaus the chip isn’t ready for displaying anything, how can i manage to display these kind off stuf.
Later on in the setup the fram chip is setuped, so i wan’t to display a message that a memory module is found and is ready for use.
This is what i have so far, not much but try to understand why things are going as they go.
My i2cfram.h file
    @file     I2CFram.h
    @author   AGE
    @section  HISTORY
    v0.1 - fIRST TEST RUN
    iNTERFACE for the MB85RC I2C FRAM from Fujitsu.
    @section LICENSE
    Software License Agreement (BSD License)
#include "esphome.h"
class MyFram : public Component
public:
  void setup() override
    ESP_LOGI("custom", "Setting up  myI2CFram");
  void loop() override
    ESP_LOGI("custom", "Running ...");
my esphome file
esphome:
  includes: i2cfram/i2cfram.h
esp8266:
  board: d1_mini
# Enable logging
logger:
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_pwd
  ap:
    ssid: "102-fram Fallback Hotspot"
    password: !secret esphome_pwd
  manual_ip:
    static_ip: 192.168.1.102
    gateway: 192.168.1.1
    subnet: 255.255.255.0
# Enable Captive portal
captive_portal:
#enable ota
ota:
  password: !secret esphome_ota
web_server:
  port: 80
# Enable Home Assistant API
api:
  password: !secret esphome_api
i2c:
  - id: bus_a
    sda: GPIO4
    scl: GPIO5
    scan: true
# restart button voor de s0tool
button:
  - platform: restart
custom_component:
- lambda: |-
    auto my_fram = new MyFram();
    App.register_component(my_fram);
    return {my_fram};
  components:
  - id: my_fram_id
If you are accessing the logs using wireless, then the setup message was likely logged well before the wireless connection was established. Try using serial connection to usb to view the logs then reset the module. Should see the complete startup that way with all the setup() info logged.
found out somthing to print out information.
one can use void dump_config() and printout information.
