Fitbit Card for Home Assistant
Source
Usage
- type: 'custom:fitbit-card'
battery_entity: sensor.versa_battery
header_entities:
- entity: sensor.tracker_steps
icon_color: '#14308D'
- entity: sensor.distance
show_units: true
- entity: sensor.tracker_calories
icon_color: red
entities:
- entity: sensor.minutes_sedentary
max: 1000
- entity: sensor.minutes_very_active
max: 120
- entity: sensor.minutes_lightly_active
max: 50
color_stops:
'0': red
'50': yellow
'90': green
- entity: sensor.resting_heart_rate
show_units: true
Options
Name
Type
Requirement
Default
Description
type
string
Required
custom:fitbit-card
battery_entity
string
Optional
Battery entity to show battery status
header_entities
list<Object>
Optional
List of fitbit sensors to display in the header
show_units_header
boolean
Optional
false
Show units for all header entities
entities
list<Object>
Optional
List of fitbit sensors to display n the body
max
string
Optional
100
Global maximum value for body entities
header_entities options
Name
Type
Requirement
Default
Description
entity
string
Required
Name of entitiy
icon_color
string
Optional
color of icon next to entity (can be color name or hex value)
show_units
boolean
Optional
false
show units next to entity value (show_units_header overrides this)
entities options
Name
Type
Requirement
Default
Description
entity
string
Required
Name of entitiy
max
number
Optional
global max value
override global maxiumum value for this entity
color_stops
list
Optional
--primary-color
custom colors for percent circle
show_units
boolean
Optional
false
show units next to value
Neoc83
September 3, 2020, 1:43pm
2
I tried to use the custom component but whatever I try, I’m getting the error “Custom element doesn’t exist: fitbit-card.”. I’m on hass.io with HA version 0.114.4. I installed the custom component with HACS and added the following to my Lovelace config:
resources:
- url: /hacsfiles/fitbit-card/fitbit-card.js
type: module
I also tried the (deprecated?) config from the HACS instructions but that resulted in the same error.
resources:
- url: /community_plugin/fitbit-card/fitbit-card.js
type: js
In the logs I cannot find anything. Any help would be appreciated.
ElJee
November 29, 2020, 7:02am
3
Hey Neoc83 - Did you ever figure it out? I have the same issue on 0.118 - Thanks.
Neoc83
November 30, 2020, 2:38pm
4
No unfortunately not but I haven’t tried ever since.
ElJee
December 11, 2020, 8:02am
5
I actually figured it out. It worked fine when I got all the entities with the right names. Some sensors were not defined correctly.
Good luck!
