ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform fitbit
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_component.py", line 171, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for
return fut.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/fitbit.py", line 235, in setup_platform
import fitbit
File "/srv/homeassistant/lib/python3.5/site-packages/fitbit/__init__.py", line 10, in <module>
from .api import Fitbit, FitbitOauth2Client
File "/srv/homeassistant/lib/python3.5/site-packages/fitbit/api.py", line 13, in <module>
from requests_oauthlib import OAuth2Session
File "/srv/homeassistant/lib/python3.5/site-packages/requests_oauthlib/__init__.py", line 9, in <module>
if requests.__version__ < '2.0.0':
TypeError: unorderable types: module() < str()
Looks like you have the issue that I had with Hassbian on jessie. Fix for this is to rollback requests from its current version 2.18.4 to 2.14.2 whilst in the VENV the restart HA
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_component.py", line 189, in _async_setup_platform
return fut.result()
import fitbit
