Fitbit Integration Broken
Hi Folks,
seems that the Fitbit integration has broken since 2022.6.5 or 2022.6.6.
When I try and reconfigure it, I get the following error - I’ve looked into the code for the integration, but can’t see anything that might be causing it (not that I’m a coder by any stretch)
I’ve found a few topics talking about the Fitbit integration being updated, but doesn’t appear like it’s ever happened.
Has anyone else come across this and been able to resolve it?
It has been reported:
There is a guide here that some have roported success with:
yeah, thanks @tom_l - I tried the Multiple Accounts custom component, but it returns the same error, so I wasn’t sure if it were the Integration or something core to Home Assistant…
well, that was odd, turns out there was something unexpected with my backup copy of fitbit.conf, which has worked in the past.
all sorted now, but doesn’t explain why the integration broke with an upgrade…
I’m having the same error as you mentioned above but it’s still not working. I was using the multi-account fitbit method as listed here: Home-Assistant/Fitbit - Add Multiple Accounts at main · TheTroubleshooter/Home-Assistant · GitHub so I tried blowing the entire fitbit integration away and starting from scratch but it still pops that error "Failed to call service configurator/configure. unexpected end of data: line 4 column 2 (char 83). @DrewXT what did you do to fix it?
At the the I set it up again, and it started working.
It’s just broken again, so I’ve set up MyFitnessPal as a conduit from Fitbit to Garmin, and using the Garmin connect integration to pull the Fitbit data I was pulling directly.
Almost syncs in real time with a free account in MyFitnessPal, and I already use a Garmin Epix2 as my sports watch
