Hello everyone,
I’m training in a FitX-Gym since a couple of years now and since the beginning of the pandemic they released a feature to see the current utilization of the studio. Raukze released a custom HACS integration a while back which crawls the FitX-Website as they had a graph on it to show the utilization. With a change of their system infrastructure they changed it and released a more or less public API to request those infos. I integrated that new API into the custom integration which kind of broke with the HA Release 2023.4. Since the integration just retrieved Rest-API data, it could be implemented with a RESTful Sensor natively built into HA. The data from the API looks something like this:
"startTime": "00:00:00",
"endTime": "00:00:00",
"items": [
"endTime": "01:00:00",
"percentage": 1,
"level": "LOW",
"isCurrent": false
"startTime": "01:00:00",
"endTime": "02:00:00",
"percentage": 1,
"level": "LOW",
"isCurrent": false
"startTime": "12:00:00",
"endTime": "13:00:00",
"percentage": 59,
"level": "NORMAL",
"isCurrent": true
"startTime": "22:00:00",
"endTime": "23:00:00",
"percentage": 0,
"level": "LOW",
"isCurrent": false
"startTime": "23:00:00",
"percentage": 0,
"level": "LOW",
"isCurrent": false
This array has always been sorted by the date. This is the reason why a rather easy implementation of a restsensor is possible:
- platform: rest
resource: https://mein.fitx.de/nox/public/v1/studios/1561099930/utilization
headers:
x-tenant: fitx
icon: mdi:weight-lifter
name: FitX Auslastung
unique_id: fitx
unit_of_measurement: "%"
value_template: >-
{% for item in value_json['items'] if item.isCurrent %}
{{ item.percentage }}
{% endfor %}
To use this sensor in your own region, you have to change the studio id (in the above example: 1561099930) to your own studio id. To do this do the following:
- Download this Gist: Get the ID of a FitX Studio by it's name. · GitHub
- Run it like this:
python fitx_id.py bielefeld-mitte
- It should return Something like this:
Searching ID for Gym bielefeld-mitte...
Found the ID for bielefeld-mitte: 1516366190
- Use the given ID in the sensor.
It’s showing the following in HomeAssistant:
