Get the following error in log. Looks like HA is trying to get some battery stats from a z-wave device and fails. That’s normal as i have only z-wave dimmers (qubino and fibaro) installed. Only AEON Gen5 stick might have a battery but…
Running
cat zwcfg_0xedxxxxdb.xml | grep battery
Returns zero results. OZW log also as far as i can tell doesn’t return any errors
homeassistant.core: Error doing job: Task exception was never retrieved
File "/usr/lib/python3.4/asyncio/tasks.py", line 237, in _step
result = next(coro)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 335, in _async_process_entity
new_entity, self, update_before_add=update_before_add
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 204, in async_add_entity
yield from entity.async_update_ha_state()
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 229, in async_update_ha_state
device_attr = self.device_state_attributes
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/zwave/__init__.py", line 606, in device_state_attributes
battery_level = self._value.node.get_battery_level()
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/openzwave-0.3.1-py3.4.egg/openzwave/command.py", line 284, in get_battery_level
for val in self.get_battery_levels():
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/openzwave-0.3.1-py3.4.egg/openzwave/command.py", line 306, in get_battery_levels
type='Byte', readonly=True, writeonly=False)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/openzwave-0.3.1-py3.4.egg/openzwave/node.py", line 440, in get_values
for value in self.values:
RuntimeError: dictionary changed size during iteration
