I am interested to buy bought the Aeotec Doorbell 6 ( ZW162 ) but i am wandering if the volume of the bell can be modified at Zwave JS level because this is not documented in the documentation " Zwave-JS Config DB Browser" … https://devices.zwave-js.io/
When hitting the button #1 , an event “Doorbell 6: Siren - Siren active (3)” is present in the logbook so the doorbell is working fine … except the siren sound which is too high
Do you not see the “Default volume” entities present in your screenshot? I do… and they are all set to 1.0 which is max volume. The range is 0.0 to 1.0, set to 0.5 to set half volume, etc.
Figured it out. For anyone else struggling with this, it appears the “Default Volume (n)” configs correspond to the “Default Tone (n)” presets that you can call.
In the example above, siren.indoor_siren_6_3 will use the tone you select in Default Tone (3) in and the Default Volume (3) the device config.
