Dumb question: @Andrea_Liosi, how do I go about adding this?
Hey! Just download the repo from Github and add the folder deebot in custom_components to your custom_components folder. If you do not have one, just create it. After that, add the config @Andrea_Liosi posted into your configuration.yaml and then it should work. I am able to see it now.
I have a 930, and it would appear this isnât working. I got a bunch of json and xml errors in the logs. Looks like this might be 950 specific.
Please share logs I will try to see if itâs a bug or 930 is xml based
UPDATE: State is now properly displayed and you can change fan speed
Yeah. Iâll post them over in github, to keep this thread clean.
Thanks for this. Are you planning to integrate this into the ecovacs component? If not could you add this to HACS?
I have an older Ecovacs Deebot Slim and the Ozmo 950. Unfortunately it seems like I need the ecovacs component for the Slim and the deebot component for the Ozmo. And because of this I also get two entities each, while for each component one entity doesnât work.
BTW: I get a very long cryptic name for the Ozmo, you too?
Edit: Just noticed that the ecovacs component doesnât work while the deebot component is installed. So currently it looks like I can only use one deebot in ha. Any suggestions?
Adding this to HACS would be superb!
What I would love to see: a map like the users of the Roborock have so you can name areas and use voice commands to say: âDeebot, please clean the kitchenâ.
Thank you for you working @Andrea_Liosi!
im tryng to integrate it in HACS but it gives me some problems. i still dont get it
It get the ID of the device if the nickname is not defined
It shouldnt be a problem, can you open a issue in the github repo with errors log?
Im working about it ![]()
Where did you define the Nickname? I have the standard one in the app settings âDEEBOT OZMO 950 Seriesâ
Will do that. Both components automatically set up both devices, so I tried to disable one each, but that also did not help, the ecovacs (compontent) slim stays unavailable. Will try it again, have a look at the logs and open an issue.
Now available on HACS!
Cool! Under which name? Was not able to find it under âdeebotâ or âecovacsâ
Ah, I see it now. Thanks again for all the work and quick replies!
PS: for those on the 930, I figured out a problem with DEEBOT OZMO 930 vacuums: their firmware checks are broken. This could be a reason why these vacuums are still behind the 950.
Using a proxy dump on the phone, I was able to discover the 930 is making a 404 call to firmware updates:
This is pretty bad. Iâve emailed US Customer Support about this. Hopefully theyâll be able to get this to their engineers so they can update their servers to catch this URL.
But for now: firmware updates for the 930 are dead in the water.
PPS: Also, as you can see from the URL, the firmware version is 1.9.9. According to their site, 900 series is on 2.x and uses the ânewâ ECOVACS Home app. While the 930 does use the ECOVACS Home app, itâs not on 2.x. This 2.x firmware is most likely the JSON change people are seeing here.
So I have managed to changed the files as per the posts higher up, I can now find the entity in my HA but I can`t operate the bot for some reason I get the bellow
9:25 PM custom_components/deebot/vacuum.py (ERROR)
Ping did not reach VacBot. Will retry.
9:25 PM /usr/local/lib/python3.7/site-packages/ozmo/init.py (WARNING)
You do find those kinds of âerrorsâ quite a bit in HA. It could just mean that itâs not connected to the vac yet. Leave it for an hour or two and see if it fixes itself. You could also try manually telling the vac to do some cleaning & then charging. Sometimes it seems the device needs to operate before HA can get the initial status from it.
I struggled to get this working for my 907(900 series Deebot, I think from Costco, white).
Anyway, I kept getting an error âCrypto.PublicKey.RSAâ has no attribute âimport_keyâ
Turns out I had to install or upgrade Crypto. At the terminal I used: pip3 install crypto. For good measure, I also did pip install crypto. At the same time I also used pip3 install pycrypto and pip install pycrypto.
Again, Iâm fairly noob to this but thatâs what finally ended up working for me after I followed the above instructions for the custom component.
I havenât been able to check for the other sensors/commands but at least Deebot loaded and I can see and activate my vacuum.
