[FIXED] Flux_led does not set brightness or color correctly when device is initially off
I’m running 0.103.2 via hass.io v193. i’ve stumbled on an issue where if a flux_led device is off and i turn the device on via a scene or automation, it will not receive the correct brightness/rgbw settings and will simply turn on to the state that it was in previously. if i wait a second and reissue the command, it will then properly adjust to the correct brightness/rgbw. has anyone else seen this and found a fix?
i managed to hack a solution to this… posting here for future if someone else runs into this issue. the problem seems to be that the magiclight led controller doesn’t accept rgb/brightness commands unless it is on and it takes a few milliseconds between turning the controller on and it being ready to accept commands. so my solution is to add a .5 second pause between turning it on and sending commands. this results in an annoying period where the leds are in whatever the previous state of color and brightness was, so to fix that i also added a step of setting the controller to zero brightness/rgb before turning it off. so now all you notice is a slight delay when you turn the leds on. it’s rather hacky since it involves customizing flux_led/light.py. on hass.io system do the following:
create the following path:
config/custom_components/flux_led
create the following files in that path:
__init__.py
"""The flux_led component."""
manifest.json
  "domain": "flux_led",
  "name": "Flux led",
  "documentation": "https://www.home-assistant.io/integrations/flux_led",
  "requirements": [
    "flux_led==0.22"
  "dependencies": [],
  "codeowners": []
light.py
"""Support for Flux lights."""
import logging
import random
import socket
# Added for MagicLight hack
import time
from flux_led import BulbScanner, WifiLedBulb
import voluptuous as vol
from homeassistant.components.light import (
    ATTR_BRIGHTNESS,
    ATTR_COLOR_TEMP,
    ATTR_EFFECT,
    ATTR_HS_COLOR,
    ATTR_WHITE_VALUE,
    EFFECT_COLORLOOP,
    EFFECT_RANDOM,
    PLATFORM_SCHEMA,
    SUPPORT_BRIGHTNESS,
    SUPPORT_COLOR,
    SUPPORT_COLOR_TEMP,
    SUPPORT_EFFECT,
    SUPPORT_WHITE_VALUE,
    Light,
from homeassistant.const import ATTR_MODE, CONF_DEVICES, CONF_NAME, CONF_PROTOCOL
import homeassistant.helpers.config_validation as cv
import homeassistant.util.color as color_util
_LOGGER = logging.getLogger(__name__)
CONF_AUTOMATIC_ADD = "automatic_add"
CONF_CUSTOM_EFFECT = "custom_effect"
CONF_COLORS = "colors"
CONF_SPEED_PCT = "speed_pct"
CONF_TRANSITION = "transition"
DOMAIN = "flux_led"
SUPPORT_FLUX_LED = SUPPORT_BRIGHTNESS | SUPPORT_EFFECT | SUPPORT_COLOR
MODE_RGB = "rgb"
MODE_RGBW = "rgbw"
# This mode enables white value to be controlled by brightness.
# RGB value is ignored when this mode is specified.
MODE_WHITE = "w"
# Constant color temp values for 2 flux_led special modes
# Warm-white and Cool-white modes
COLOR_TEMP_WARM_VS_COLD_WHITE_CUT_OFF = 285
# List of supported effects which aren't already declared in LIGHT
EFFECT_RED_FADE = "red_fade"
EFFECT_GREEN_FADE = "green_fade"
EFFECT_BLUE_FADE = "blue_fade"
EFFECT_YELLOW_FADE = "yellow_fade"
EFFECT_CYAN_FADE = "cyan_fade"
EFFECT_PURPLE_FADE = "purple_fade"
EFFECT_WHITE_FADE = "white_fade"
EFFECT_RED_GREEN_CROSS_FADE = "rg_cross_fade"
EFFECT_RED_BLUE_CROSS_FADE = "rb_cross_fade"
EFFECT_GREEN_BLUE_CROSS_FADE = "gb_cross_fade"
EFFECT_COLORSTROBE = "colorstrobe"
EFFECT_RED_STROBE = "red_strobe"
EFFECT_GREEN_STROBE = "green_strobe"
EFFECT_BLUE_STROBE = "blue_strobe"
EFFECT_YELLOW_STROBE = "yellow_strobe"
EFFECT_CYAN_STROBE = "cyan_strobe"
EFFECT_PURPLE_STROBE = "purple_strobe"
EFFECT_WHITE_STROBE = "white_strobe"
EFFECT_COLORJUMP = "colorjump"
EFFECT_CUSTOM = "custom"
EFFECT_MAP = {
    EFFECT_COLORLOOP: 0x25,
    EFFECT_RED_FADE: 0x26,
    EFFECT_GREEN_FADE: 0x27,
    EFFECT_BLUE_FADE: 0x28,
    EFFECT_YELLOW_FADE: 0x29,
    EFFECT_CYAN_FADE: 0x2A,
    EFFECT_PURPLE_FADE: 0x2B,
    EFFECT_WHITE_FADE: 0x2C,
    EFFECT_RED_GREEN_CROSS_FADE: 0x2D,
    EFFECT_RED_BLUE_CROSS_FADE: 0x2E,
    EFFECT_GREEN_BLUE_CROSS_FADE: 0x2F,
    EFFECT_COLORSTROBE: 0x30,
    EFFECT_RED_STROBE: 0x31,
    EFFECT_GREEN_STROBE: 0x32,
    EFFECT_BLUE_STROBE: 0x33,
    EFFECT_YELLOW_STROBE: 0x34,
    EFFECT_CYAN_STROBE: 0x35,
    EFFECT_PURPLE_STROBE: 0x36,
    EFFECT_WHITE_STROBE: 0x37,
    EFFECT_COLORJUMP: 0x38,
EFFECT_CUSTOM_CODE = 0x60
TRANSITION_GRADUAL = "gradual"
TRANSITION_JUMP = "jump"
TRANSITION_STROBE = "strobe"
FLUX_EFFECT_LIST = sorted(list(EFFECT_MAP)) + [EFFECT_RANDOM]
CUSTOM_EFFECT_SCHEMA = vol.Schema(
        vol.Required(CONF_COLORS): vol.All(
            cv.ensure_list,
            vol.Length(min=1, max=16),
                vol.All(
                    vol.ExactSequence((cv.byte, cv.byte, cv.byte)), vol.Coerce(tuple)
        vol.Optional(CONF_SPEED_PCT, default=50): vol.All(
            vol.Range(min=0, max=100), vol.Coerce(int)
        vol.Optional(CONF_TRANSITION, default=TRANSITION_GRADUAL): vol.All(
            cv.string, vol.In([TRANSITION_GRADUAL, TRANSITION_JUMP, TRANSITION_STROBE])
DEVICE_SCHEMA = vol.Schema(
        vol.Optional(CONF_NAME): cv.string,
        vol.Optional(ATTR_MODE, default=MODE_RGBW): vol.All(
            cv.string, vol.In([MODE_RGBW, MODE_RGB, MODE_WHITE])
        vol.Optional(CONF_PROTOCOL): vol.All(cv.string, vol.In(["ledenet"])),
        vol.Optional(CONF_CUSTOM_EFFECT): CUSTOM_EFFECT_SCHEMA,
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend(
        vol.Optional(CONF_DEVICES, default={}): {cv.string: DEVICE_SCHEMA},
        vol.Optional(CONF_AUTOMATIC_ADD, default=False): cv.boolean,
def setup_platform(hass, config, add_entities, discovery_info=None):
    """Set up the Flux lights."""
    lights = []
    light_ips = []
    for ipaddr, device_config in config.get(CONF_DEVICES, {}).items():
        device = {}
        device["name"] = device_config[CONF_NAME]
        device["ipaddr"] = ipaddr
        device[CONF_PROTOCOL] = device_config.get(CONF_PROTOCOL)
        device[ATTR_MODE] = device_config[ATTR_MODE]
        device[CONF_CUSTOM_EFFECT] = device_config.get(CONF_CUSTOM_EFFECT)
        light = FluxLight(device)
        lights.append(light)
        light_ips.append(ipaddr)
    if not config.get(CONF_AUTOMATIC_ADD, False):
        add_entities(lights, True)
        return
    # Find the bulbs on the LAN
    scanner = BulbScanner()
    scanner.scan(timeout=10)
    for device in scanner.getBulbInfo():
        ipaddr = device["ipaddr"]
        if ipaddr in light_ips:
            continue
        device["name"] = "{} {}".format(device["id"], ipaddr)
        device[ATTR_MODE] = None
        device[CONF_PROTOCOL] = None
        device[CONF_CUSTOM_EFFECT] = None
class FluxLight(Light):
    """Representation of a Flux light."""
    def __init__(self, device):
        """Initialize the light."""
        self._name = device["name"]
        self._ipaddr = device["ipaddr"]
        self._protocol = device[CONF_PROTOCOL]
        self._mode = device[ATTR_MODE]
        self._custom_effect = device[CONF_CUSTOM_EFFECT]
        self._bulb = None
        self._error_reported = False
    def _connect(self):
        """Connect to Flux light."""
        self._bulb = WifiLedBulb(self._ipaddr, timeout=5)
        if self._protocol:
            self._bulb.setProtocol(self._protocol)
        # After bulb object is created the status is updated. We can
        # now set the correct mode if it was not explicitly defined.
        if not self._mode:
            if self._bulb.rgbwcapable:
                self._mode = MODE_RGBW
            else:
    def _disconnect(self):
        """Disconnect from Flux light."""
        self._bulb = None
    @property
    def available(self) -> bool:
        """Return True if entity is available."""
        return self._bulb is not None
    @property
    def name(self):
        """Return the name of the device if any."""
        return self._name
    @property
    def is_on(self):
        """Return true if device is on."""
        return self._bulb.isOn()
    @property
    def brightness(self):
        """Return the brightness of this light between 0..255."""
        if self._mode == MODE_WHITE:
            return self.white_value
        return self._bulb.brightness
    @property
    def hs_color(self):
        """Return the color property."""
        return color_util.color_RGB_to_hs(*self._bulb.getRgb())
    @property
    def supported_features(self):
        """Flag supported features."""
        if self._mode == MODE_RGBW:
            return SUPPORT_FLUX_LED | SUPPORT_WHITE_VALUE | SUPPORT_COLOR_TEMP
            return SUPPORT_BRIGHTNESS
    @property
    def white_value(self):
        """Return the white value of this light between 0..255."""
        return self._bulb.getRgbw()[3]
    @property
    def effect_list(self):
        """Return the list of supported effects."""
        if self._custom_effect:
            return FLUX_EFFECT_LIST + [EFFECT_CUSTOM]
    @property
    def effect(self):
        """Return the current effect."""
        current_mode = self._bulb.raw_state[3]
        if current_mode == EFFECT_CUSTOM_CODE:
            return EFFECT_CUSTOM
        for effect, code in EFFECT_MAP.items():
            if current_mode == code:
                return effect
        return None
    def turn_on(self, **kwargs):
        """Turn the specified or all lights on."""
        if not self.is_on:
            self._bulb.turnOn()
            time.sleep(.5)
        hs_color = kwargs.get(ATTR_HS_COLOR)
        if hs_color:
            rgb = color_util.color_hs_to_RGB(*hs_color)
        else:
            rgb = None
        brightness = kwargs.get(ATTR_BRIGHTNESS)
        effect = kwargs.get(ATTR_EFFECT)
        white = kwargs.get(ATTR_WHITE_VALUE)
        color_temp = kwargs.get(ATTR_COLOR_TEMP)
        # handle special modes
        if color_temp is not None:
            if brightness is None:
                brightness = self.brightness
            if color_temp > COLOR_TEMP_WARM_VS_COLD_WHITE_CUT_OFF:
                self._bulb.setRgbw(w=brightness)
            else:
                self._bulb.setRgbw(w2=brightness)
            return
        # Show warning if effect set with rgb, brightness, or white level
        if effect and (brightness or white or rgb):
            _LOGGER.warning(
                "RGB, brightness and white level are ignored when"
                " an effect is specified for a flux bulb"
        # Random color effect
        if effect == EFFECT_RANDOM:
            self._bulb.setRgb(
                random.randint(0, 255), random.randint(0, 255), random.randint(0, 255)
            return
        if effect == EFFECT_CUSTOM:
                self._bulb.setCustomPattern(
                    self._custom_effect[CONF_COLORS],
                    self._custom_effect[CONF_SPEED_PCT],
                    self._custom_effect[CONF_TRANSITION],
            return
        # Effect selection
        if effect in EFFECT_MAP:
            self._bulb.setPresetPattern(EFFECT_MAP[effect], 50)
            return
        # Preserve current brightness on color/white level change
        # Preserve color on brightness/white level change
        if rgb is None:
            rgb = self._bulb.getRgb()
        if white is None and self._mode == MODE_RGBW:
            white = self.white_value
        # handle W only mode (use brightness instead of white value)
            self._bulb.setRgbw(0, 0, 0, w=brightness)
        # handle RGBW mode
        elif self._mode == MODE_RGBW:
            self._bulb.setRgbw(*tuple(rgb), w=white, brightness=brightness)
        # handle RGB mode
        else:
            self._bulb.setRgb(*tuple(rgb), brightness=brightness)
    def turn_off(self, **kwargs):
        """Turn the specified or all lights off."""
        self._bulb.setRgbw(*tuple([0,0,0]), w=0, brightness=0)
        time.sleep(.75)
        self._bulb.turnOff()
    def update(self):
        """Synchronize state with bulb."""
        if not self.available:
            try:
                self._connect()
            except socket.error:
                self._disconnect()
                if not self._error_reported:
                    _LOGGER.warning(
                        "Failed to connect to bulb %s, %s", self._ipaddr, self._name
                    self._error_reported = True
                return
        self._bulb.update_state(retry=2)
restart HA and that’s it.
updated for Home Assistant 0.110
light.py
import logging
import random
import time
    ATTR_BRIGHTNESS,
    ATTR_COLOR_TEMP,
    ATTR_EFFECT,
    ATTR_HS_COLOR,
    ATTR_WHITE_VALUE,
    EFFECT_COLORLOOP,
    EFFECT_RANDOM,
    PLATFORM_SCHEMA,
    SUPPORT_BRIGHTNESS,
    SUPPORT_COLOR,
    SUPPORT_COLOR_TEMP,
    SUPPORT_EFFECT,
    LightEntity,
DOMAIN = "flux_led"
MODE_RGB = "rgb"
MODE_RGBW = "rgbw"
MODE_WHITE = "w"
EFFECT_MAP = {
            cv.ensure_list,
                vol.All(
    lights = []
    light_ips = []
        device = {}
        return
            continue
        device["name"] = f"{device['id']} {ipaddr}"
class FluxLight(LightEntity):
        self._bulb = None
    def _connect(self):
        if self._protocol:
        if not self._mode:
            else:
        self._bulb = None
    @property
    @property
    def name(self):
        return self._name
    @property
    def is_on(self):
    @property
    @property
    def hs_color(self):
    @property
    @property
    @property
    @property
    def effect(self):
                return effect
        return None
        if not self.is_on:
            self._bulb.turnOn()
            time.sleep(.5)
        if hs_color:
        else:
            rgb = None
            else:
            return
            _LOGGER.warning(
            self._bulb.setRgb(
            return
            return
        # Effect selection
            return
        if rgb is None:
        # handle RGBW mode
        # handle RGB mode
        else:
        time.sleep(.75)
    def update(self):
            try:
                self._connect()
            except OSError:
                self._disconnect()
                    _LOGGER.warning(
                return
manifest.json
  "name": "Flux LED/MagicLight",
  "requirements": ["flux_led==0.22"],
  "codeowners": []
Thanks @tims300! Works perfectly after I’ve been getting annoyed by this for quite a while now!
I rebuilt the script with fixing bugs that appear with when Google Home and Alexa also handle the same controllers, especially when states change from on and off for Automation trigger use: https://gist.github.com/ybarigou/52d42cd2e6b44bb70cbdb317a059e623
Hey there.
Firstly, thanks to @tims300 and @ybarigou for the hard work here!
I added @tims300 original code (updated for 0.110), however, now any time a light is turned off via Hassio, it can’t be turned back on. Well, it states it is on, but no light comes on. I need to go in manually and adjust color temp or brightness to get the light to react. I am also using both Google Home and Hassio to handle the same controllers. So, I tried your (@ybarigou) code. This affects all of my lights, not just the Flux_LED lights. I am unable to control any non flux_led lights, and any flux_led lights I have attached, are completely shaded in yellow and “unavailable” in the lovelace UI. I am hoping that perhaps I am able to get some help to overcome this, as this is beyond my level of expertise.
Not sure about non Flux_LED lights. Which ones specifically ?
Also, please use RGBW mode for monochromatic lights (instead of W)
Hey mate, thanks for the reply.
They are “Magic Hue” rgbw lights, controllable by the “Magic Home” app. I found an old article on here when I bought them months ago that referred me to use the flux_led platform in HA.
They were working okay for a while on flux_led; the only problem that I initially experienced was when I was creating an automation for an intruder alarm, making the lights strobe blue and red. The light wouldn’t respond if I sent a turn_on with “red_strobe” or “blue_strobe” effect when the light was initially off. This is how I stumbled onto this page.
Since adding this custom component, I managed to resolve the first issue, which was that all lights were unavailable in HA - that was due to user error. :wink: But, am still getting the second issue: If a simple Light.turn_on request is made without any {data} (i.e. brightness, color temp), the light will register as on, but not emit any light. I am able to overcome this in all of my automations by just ensuring to send data along with the turn_on request. However, if I use a switch in the lovelace UI, I can’t overcome it.
Forgive my ignorance, but could there be a way for me to amend the light.py custom component to inject {data} to a turn_on request IF a turn_on command is sent without {data}?
Edit: While writing, I tested something else. It seems that it may also affect the turn_off request. I turned off a light using lovelace UI, then I tried to turn it on with google assistant and that light experiences the same issue. So, any time a simple turn_on or turn_off is sent to a light, the light won’t emit any light.
Cheers!
I updated the code with a dirty fix should work now without the need to select RGBW for White only bulbs/led controllers; therefore, the mode can just be ‘w’ for monochromatic lights.
Also, RGBW bulbs are now directly considered RGB to fix the problem. In conclusion, with using the code I provided here, just keep every bulb’s mode in the configuration.yaml as is, i.e.:
  • for RGBW bulbs/controllers:
mode: rgbw
  • for RGB bulbs/controllers:
mode: rgb
  • for monochromatic bulbs/controllers:
mode: w
I’m having the same issue again since a few updates back. Was anybody able to fix this again? I would really appreciate it if someone could share a new fix. Thanks!
I’m also seeing this issue. Have a workaround by applying scenes more than once but sometimes they still don’t work and the brightness or colour won’t adjust correctly.
Thanks for this. Any way to support CCT? I am using a MagicHome Wifi controller in my ceiling which has cool white and warm white led strips connected to it. The app works perfectly to change the color temperature and turn it on/off, but Flux_LED doesn’t seem to support the CCT mode.
Please run pip install flux_led and provide the output of flux_led -sSiv here Sign in to GitHub · GitHub
Thanks, here you go…
➜  ~ flux_led -sSiv
8CCE4E03EA22 [192.168.0.7] ON  [CCT: 2726K Brightness: 0.5647058823529412% raw state: 129,37,35,97,2,255,0,255,0,143,2,1,15,203,]
8CCE4E03EE73 [192.168.0.8] ON  [CCT: 2726K Brightness: 0.5647058823529412% raw state: 129,37,35,97,2,255,0,255,0,143,2,1,15,203,]
I have the same device, and it works as expected in CCT mode. Make sure you have the device type set in the Magic Home Pro app, and wiring done as shown in the diagram
2021-11-22 14:07:33 DEBUG (MainThread) [flux_led.aioprotocol] ('192.168.209.190', 5577) <= 0x81 0x25 0x23 0x61 0x02 0x10 0x00 0x00 0x00 0xFF 0x02 0x00 0x0F 0x4C (14)
… and the state dumps …
70039F09090B [192.168.209.190] ON [CCT: 2700K Brightness: 1.0% raw state: 129,37,35,97,2,16,0,0,0,255,2,0,15,76,]
2021-11-22 14:07:33 DEBUG (MainThread) [flux_led.base_device] 192.168.209.190: State: LEDENETRawState(head=129, model_num=37, power_state=35, preset_pattern=97, mode=2, speed=16, red=0, green=0, blue=0, warm_white=255, version_number=2, cool_white=0, color_mode=15, check_sum=76)
I noticed brightness was being displayed as 100x less than it should have been in CCT mode in the CLI (was correct in Home Assistant)
I fixed that in Release 0.24.27 · Danielhiversen/flux_led · GitHub
Not sure what you mean. My lights are working fine with the MagicHome app. I want to get them talking to HA.
Did you get the CCT functionality working in HA? If so which mode did you specify? Last time when I checked a few weeks ago fluxled didn’t have a CCT mode, but maybe that’s changed now.
Yes. It worked out of box with dev. I didn’t have to do anything.
The integration got a huge overhaul in 2021.11 so its likely the same there.
I just tested it and you are right, it works perfectly! It correctly identified my LED CCT controllers. Thanks @bdraco for letting me know!
