Hello Everyone
I just got solar setup, so I’m trying to add the Fronius integration to HASS.
Supposedly, it should just work? Fronius - Home Assistant
However, when I click on it to install, it takes me to HASS and shows
Config flow could not be loaded
The log shows
2022-01-11 08:57:41 ERROR (MainThread) [homeassistant.config_entries] Error occurred loading configuration flow for integration fronius: No module named 'homeassistant.components.fronius.config_flow'
I have added the inverter directly to my configuration.yaml like so
- platform: fronius
resource: http://192.168.1.77
monitored_conditions:
- sensor_type: inverter
However this is only giving me some of the sensors that I need (not getting grid feed etc - just inverter output)
My HASS is the official VM (running on Proxmox under LXC), Home Assistant OS 6.5 and HomeAssistant version 2021.11.5. I have a Lets Encrypt SSL cert and HTTP → HTTPS redirect enable if that makes a difference.
Can someone point me in the right direction to get this component installed?
Fixed - it turns out I wasn’t up to date! Somehow jumping through menus I missed the outstanding updates. Upon updating, It is all working as expected (ish).
