In the past HASSIO upgrade between 95 and 97 my google calendars have stopped working, but I can’t see mention of calendars changing in the release notes.
I’ve removed the /config/.google.token and reauthenticated but the following error persists.
Any ideas?
2019-08-16 12:48:57 ERROR (MainThread) [homeassistant.components.calendar] Error while setting up platform google
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 149, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
return fut.result()
File "/config/custom_components/google/calendar.py", line 34, in setup_platform
for data in disc_info[CONF_ENTITIES] if data[CONF_TRACK]])
File "/config/custom_components/google/calendar.py", line 34, in <listcomp>
File "/config/custom_components/google/calendar.py", line 47, in __init__
super().__init__(hass, data)
TypeError: object.__init__() takes exactly one argument (the instance to initialize)
google_calendars.yaml has entries like this…
- cal_id: phillprice.com_qwertyuiopasdfghjklzxcvbnm@group.calendar.google.com
entities:
- device_id: movie_releases
ignore_availability: true
track: true
I’m using 97.1 on HassOS 2.11 on a Pi.
