I’ve been using MySensors for a while now in their present hardware/software configuration with no problems running lights (relays), temp sensors, etc up until recently. I upgraded my HASS.IO install of home-assistant to 0.61.1 and ever since then I have not been able to get any of my light actuators to respond to commands from the UI. My temp/humidity sensors though do send data; so i’m not sure if it has something with receiving or not.
I do not know what is going on; and having not changed anything I do not think it’s on my end. Was wondering what it could be? I connect to MySensors using a USB-Serial gateway.
EDIT: Fixed; changed USB ports; rebooted and worked perfectly. Not sure why that specific port died. I did do multiple restarts of the HA service as well as reboot and power off/on the actual Raspberry Pi; never thought of the port.
