Fixed IP-address: A start job is running for Wait Until Kernel Time Synchronized takes ages
I have an instance of HAOS with fixed ip-address. Address, subnet and gateway are correct configured.
Everything works fine, but when starting the machine, I can see following message on the console
This can take up to more than a minute.
After time-out boot process continues and HA works fine.
Is there a way to avoid this timeout?
kind regards,
B
Does your machine have access to the Internet so it can set its clock?
yes, of course. Incoming and outgoing traffic possible, no firewalls and/or ACL’s defined.
I have the (subjective) feeling that this has something to do with a combination of fixed IP’s/mutliple IP’s/addons…
What I tested already
  • created a new VM with HAOS in proxmox
  • assigned multiple fixed IP adresses
rebooted several times and no problem
Than:
  • restored a backup of my production VM to this new machine
rebooted several times → sometimes timeout.
Errors here:
[FAILED] Failed to start Wait Until Kernel Time Synchronized:
and when I run:
systemctl status systemd-time-wait-sync.servcice
Main problem
  • It’s hard to reproduce: sometimes I get this timeout, sometimes not. I’m sure my home network infrastructure is good, requests to a ntp server from other devices never gave any problems
  • a out-of-the box instance with multiple fixed IP’s has no problems either
So I’m a bit stuck here :frowning:
Any help is appreciated,
kind regards,
Bart
I had the same problem. I was using a fixed IP address, but i was reserving it in my DHCP server. I deleted this and set it to static using the HA web UI, and it boots up super fast now with no delay!
Could you please explain what you did?
I have a similar issue
Hello, I’m facing the same problem , did you find a solution for it ?
I did a static ip for my nas, didn’t work. Reset nas, all good again.
