Fixed IP, unable to log in
Having installed HASS.IO and having tried logging in using KeenDNS service without any success, I have obtained a fixed external IP. I have forwarded port 8123 to HASS.IO to the host running HASS.IO and tried logging in over http.
Unfortunately, nothing changed. OK, there might be issues with reverse proxies that can be understood. Having a fixed IP, I cannot understand what I am doing wrong.
Could you please point me to fixed IP configuration manual?
Regards
A fixed IP can’t fix a broken reverse proxy from KeenDNS
An external static IP is just an external static IP. What configuration are you referring to?
flamingm0e,
I am sorry for inaccurate question. I have released KeenDNS and do not used anymore. I am trying logging in merely typing my fixed IP and port in a browser: http://AA.BB.CC.DD:8123. Port number 8123 has been forwarded to fixed IP in a local network.
I am interested in manual how to configure access through fixed IP’s.
Sorry for mess in my thoughts. Being newbie, your input would be appreciated.
Regards
fix your http: section with base_url of your external IP address.
aside from that, there is nothing special about a fixed IP.
Thank you for the prompt replies. I will.
flamingm0e,
Adding correct IP to base_url in http section has solved the problem. Thanks again.
Willing to secure connection, I have configured SSL via DuckDNS following the instruction posted here. After that HASS.IO stopped responding even in local network.
Nevertheless, HASS.IO can still be accessed through SSH.
Is there any way how to disable DuckDNS plugin through SSH or I will have to reinstall HASS.IO completely?
Regards
after you use DuckDNS, you need to use the internal IP address with https and you will get a warning about the certificate.
flamingm0e,
Finally, local and external connections work. I do really appreciate your help. Am I right that DuckDNS supports only one active session and an attempt to connect from two different locations at the same time will be rejected?
Regards
No. DuckDNS doesn’t have anything to do with number of connections.
DuckDNS is merely a dynamic DNS provider. It maps your dynamic public IP address to a hostname. The add-on in hassio also takes care of getting SSL certificates.
You can connect to your Home Assistant with as many devices as you desire.
