**Fixed via update to HAOS v8** Honeywell TCC error updating temp - "not enough arguments for format string"
Previous to the last update, I was able to make changes from any of the thermostat cards & update my system temps. That’s no longer the case & I can’t figure out why. Is this a bug or something I have misconfigured?
Running in Hyper-V under Windows 10
Home Assistant Core 2022.5.4
Home Assistant Supervisor 2022.05.1
Home Assistant OS 7.6
Kernel version 5.10.108
Agent version 1.2.1
Logger: homeassistant.components.websocket_api.http.connection
Source: components/honeywell/climate.py:246
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 3:08:46 PM (2 occurrences)
Last logged: 4:34:24 PM
[139952319389456] not enough arguments for format string
[139952252779488] not enough arguments for format string
  File "/usr/local/lib/python3.9/site-packages/requests/models.py", line 910, in json
    return complexjson.loads(self.text, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/simplejson/__init__.py", line 525, in loads
    return _default_decoder.decode(s)
  File "/usr/local/lib/python3.9/site-packages/simplejson/decoder.py", line 370, in decode
    obj, end = self.raw_decode(s)
  File "/usr/local/lib/python3.9/site-packages/simplejson/decoder.py", line 400, in raw_decode
    return self.scan_once(s, idx=_w(s, idx).end())
simplejson.errors.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
  File "/usr/local/lib/python3.9/site-packages/somecomfort/client.py", line 429, in _resp_json
    return resp.json()
  File "/usr/local/lib/python3.9/site-packages/requests/models.py", line 917, in json
    raise RequestsJSONDecodeError(e.msg, e.doc, e.pos)
requests.exceptions.JSONDecodeError: [Errno Expecting value] <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<!--[if IE 8 ]>    <html class="ie8" xmlns="http://www.w3.org/1999/xhtml"> <![endif]-->
<!--[if IE 9 ]>    <html class="ie9" xmlns="http://www.w3.org/1999/xhtml"> <![endif]-->
<!--[if (gt IE 9)|!(IE)]><!-->
<html xmlns="http://www.w3.org/1999/xhtml">
<!--<![endif]-->
<head><title>
Unexpected Error
</title>
    <!--[if IE]>
        <style>
            .page {
	                height: auto !important;
        </style>
    <![endif]-->
    <script type="text/javascript" src="/portal/Scripts/jquery-1.12.0.min.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.unobtrusive-ajax.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.validate.min.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.validate.unobtrusive.min.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery-ui-1.10.4.min.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.qtip.min.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.idletimer.js"></script>
    <script type="text/javascript" src="/portal/Scripts/jquery.idletimeout.js"></script>
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/jquery.qtip.truehome.css" />
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/jquery.ui.truhome.css" />
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/Layout.css?v=2.8.42" />
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/Site.css?v=2.8.42" />
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/Buttons.css?v=2.8.42" />
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/EditorTemplates.css?v=2.8.42" />
    <link rel="stylesheet" type="text/css" href="/portal/Content/TrueHome/ModalAjaxContentDialog.css?v=2.8.42" />
    <script type="text/javascript" src="/portal/Scripts/Common/SessionTimeoutHandler.js?v=2.8.42"></script>
    <script type="text/javascript" src="/portal/Scripts/Common/ModalAjaxContentDialog.js?v=2.8.42"></script>
    <script type="text/javascript" src="/portal/Scripts/Common/CustomEvents.js?v=2.8.42"></script>
    <script type="text/javascript" src="/portal/Scripts/Common/EditorTemplates.js?v=2.8.42"></script>
    <script type="text/javascript" src="/portal/Scripts/Common/BrowserDetect.js?v=2.8.42"></script>
    <script type="text/javascript">
        var _gaq = _gaq || [];
        _gaq.push(['_setAccount', 'UA-33271749-1']);
        _gaq.push(['_setDomainName', 'alarmnet.com']);
        _gaq.push(['_trackPageview']);
        (function ()
            var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true;
            ga.src = ('https:' == document.location.protocol ? 'https://ssl' : 'http://www') + '.google-analytics.com/ga.js';
            var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s);
    </script>
</head>
<body>
    <!-- dialog window markup -->
    <div id="_verticalGradientBackground">
    </div>
    <div id="_contentWrapper">
        <div id="_leftBackground">
        </div>
        <div id="_content">
            <div id="header">
                <div id="header-top">
                    <ul id="toplinks">
                        <li><a href="https://www.honeywellhome.com" target="_blank">HoneywellHome.com</a></li>
                    </ul>
                </div>
                <div id="logo">
                    <a href="/portal/">Honeywell Home - My Total Connect Comfort<span></span></a>
                </div>
            </div>
            <div id="menucontainer">
                <ul id="menu">
                    <li class="menulink"><a href="https://www.honeywellhome.com/en/support"
                        target="_blank">
                        Contact Us</a></li>
                    <li class="menudivider"></li>
                        <a href="/portal/Home/FAQs">FAQs</a></li>
                        <a href="/portal/MyAccount">My Account</a></li>
                        <a href="/portal/">Control Center</a></li>
                        <a href="/portal/Account/LogOff">Sign Out</a></li>
                    <li id="greeting">
                        Welcome
                        <b>
                            Mike</b></li>
                </ul>
            </div>
            <div id="red-grey-line">
            </div>
            <div id="breadcrumb">
    <div class="crumbs">Unexpected Error</div>
            </div>
            <div id="main">
                <noscript>
                    <div id="NoJavaScript">
                        This site will not operate without JavaScript enabled.  Refer to the FAQs tab on this site to learn about enabling JavaScript for your browser.
                    </div>
                </noscript>
                <div id="NoCookies">
This site will not operate without Cookies enabled.   Refer to the FAQs tab on this site to learn about enabling Cookies for your browser.
                </div>
                <div id="unsupportedbrowser">
                </div>
                <div id="mainContent">
 <div id="resetpassword">
        <h1>Unexpected Error</h1>
        <div class="formfield">
            <div class="rounded-bevel-border-topleftcorner">
            </div>
            <div class="rounded-bevel-border-top">
            </div>
            <div class="rounded-bevel-border-toprightcorner">
            </div>
            <div class="rounded-bevel-border-left">
                <div class="rounded-bevel-border-right">
                    <div class="whiteborder">
                        <div class="white-border-top">
                        </div>
                        <div class="white-border-left-side">
                            <div class="white-border-right-side">
                                <div id="account-success-whitebox">
                                    <div class="account-success">
                                        </div>
                                                <img src="/portal/Images/Icons/icon_red_x.gif?v=2.8.42" alt="Error" />
                                                <div class="Success">Error</div>
                                            </div>
                                        </div>
                                        <div class="white-border-bottom">
                                        </div>
                                    </div>
                                    <div class="success-text">
                                        <p>
                                        Sorry, an error occurred while processing your request.
                                        </p>
                                    </div>
                                </div>
                            </div>
                        </div>
                        </div>
                    </div>
                    <div class="buttonarea">
                        <div class="buttonwrapper">
                            <div class="red-button-gray">
                                <a href="/portal/">Home</a>
                            </div>
                        </div>
                    </div>
                </div>
            </div>
            <div class="rounded-bevel-border-bottomleftcorner">
            </div>
            <div class="rounded-bevel-border-bottom">
            </div>
            <div class="rounded-bevel-border-bottomrightcorner">
            </div>
        </div>
    </div>
                </div>
            </div>
            <div id="gatewaylog">
            </div>
            <div id="_push">
            </div>
            <div id="_footer">
                <div>
                    Version 2.8.42 - November 10, 2020
                </div>
                <ul class="left" style="width: 700px;margin-top: 5px;">
                    <li class="rightborder">
                        <a href="/portal/Home/TermsAndConditions">Privacy Statement and End User License Agreement</a></li>
                        <a href="/portal/Home/TermsConditions">Terms &amp; Conditions</a></li>
                    <li class="rightborder"><a href="https://www.mytotalconnectcomfort.com/Account/ResetLocalisationCulture">Global Site</a></li>
                        <a href="/portal/Home/Feedback">Feedback</a></li>
                    <li><br/>&nbsp;&nbsp;<a href="https://honeywellhome.com/" target="_blank">&copy;
                        2022
                        Resideo Technologies, Inc.</a>
                        The Honeywell Home trademark is used under license from Honeywell International Inc. All rights reserved.
                    </li>
                </ul>
                <ul id="CultureControl">
<li class="rightborder"><a class="culture-link" data-ajax="false" href="/portal/Account/ChangeCulture?lang=en-US&amp;returnUrl=%2Fportal%2FError%3Faspxerrorpath%3D%2Fportal%2FDevice%2FSubmitControlScreenChanges" style="text-decoration: underline;">English</a> </li>
<li><a class="culture-link" data-ajax="false" href="/portal/Account/ChangeCulture?lang=fr-CA&amp;returnUrl=%2Fportal%2FError%3Faspxerrorpath%3D%2Fportal%2FDevice%2FSubmitControlScreenChanges" style="">Fran&#231;ais</a></li>
                </ul>
            </div>
        </div>
        <div id="_rightBackground">
        </div>
    </div>
    <div id="dialog" style="display: none">
        <div class="warning"></div>
        <ul>
            <li class="header">Your session is about to expire.</li>
            <li>You will be logged off in <span id='dialog-countdown' style='font-weight:bold'></span> seconds.</li>
            <li>Do you want to continue your session?</li>
        </ul>
    </div>
            var sessionTimeoutHandler = new SessionTimeoutHandler(
                "#dialog",
                "#dialog-countdown",
                "Yes",
                "No",
                '/portal/Account/LogOff',
                '/portal/Account/Timeout'
            sessionTimeoutHandler.Initialize();
        </script>
    <script type="text/javascript" language="javascript">
        $(function ()
            var isMobileDevice = false;
            if (BrowserDetect.browser == "Explorer" && parseFloat(BrowserDetect.version) < 8)
                $("#unsupportedbrowser").html('The web browser you are using is not supported.  A supported browser is required to use Total Connect Comfort.  The most recent versions of Chrome, Safari, Firefox and Internet Explorer may be used.  Update or download one of these browsers to use Total Connect Comfort.');
    </script>
</body>
</html>
: 0
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 189, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1627, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1664, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
    await service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 677, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 964, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 714, in _handle_entity_call
    await result
  File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 588, in async_service_temperature_set
    await entity.async_set_temperature(**kwargs)
  File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 446, in async_set_temperature
    await self.hass.async_add_executor_job(
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
  File "/usr/src/homeassistant/homeassistant/components/honeywell/climate.py", line 253, in set_temperature
    self._set_temperature(**kwargs)
  File "/usr/src/homeassistant/homeassistant/components/honeywell/climate.py", line 246, in _set_temperature
    setattr(self._device, f"setpoint_{mode}", temperature)
  File "/usr/local/lib/python3.9/site-packages/somecomfort/client.py", line 192, in setpoint_cool
    self._client._set_thermostat_settings(self.deviceid,
  File "/usr/local/lib/python3.9/site-packages/somecomfort/client.py", line 491, in _set_thermostat_settings
    result = self._post_json(url, data=data)
  File "/usr/local/lib/python3.9/site-packages/somecomfort/client.py", line 455, in _post_json
    return self._request_json('post', *args, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/somecomfort/client.py", line 443, in _request_json
    return self._resp_json(resp, req)
  File "/usr/local/lib/python3.9/site-packages/somecomfort/client.py", line 433, in _resp_json
    _LOG.exception("Failed to de-JSON %s %s" % req, resp)
TypeError: not enough arguments for format string
