Hi all,
Maybe, someone here in the DEVs section could help me to figure out an issue with my energy dashboard after I had an issue with the API connection to SolarEdge Monitoring…
first, I need to describe what happened:
On September 21st, I got an Energymeter installed for my SolarEdge Inverter.
Everything was set up and seemed to work nicely, until I saw, that the SolarEdge LOCAL Integration could not read the information from the Meter via Modbus.
When this happened, I tried to change some settings in the Inverter to read also the meter values and send them through modbus…
But then, I’ve noticed that the Monitoring (Web and App) from Solaredge switched the view to the dashboard without meter information.
I’ve tried to redo the changes.
This was the time, when the initial issue started…
Even after I got the View of the App back - and could see all changes, the “history” in the Monitoring was gone.
The app just looked as it was just set up - with no further information from the previous days and months.
In HomeAssistant, the sensor that was used for the Solar Production, was also reset (lifetime energy)…
finally, I got it back running - in the night - but the outcome on the Dashboard can be seen here:
This is the Solar-Production for September 21st
This is the Solar-Production for September 22nd
and this is the Solar-Production for September 23rd
I’ve checked the SQLite Database where the Statistics are stored (as far as I understand)
and these are the recordings I would asume are related to the EnergyDashboard…
"id": 3651,
"created": "2021-09-21 15:12:00.054576",
"metadata_id": 1,
"start": "2021-09-21 14:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8384.112,
"sum": 789.9529999999995
"id": 3696,
"created": "2021-09-21 16:12:00.096206",
"metadata_id": 1,
"start": "2021-09-21 15:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 0.005,
"sum": 790.7140000000007
"id": 3741,
"created": "2021-09-21 17:12:00.100608",
"metadata_id": 1,
"start": "2021-09-21 16:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 0.005,
"id": 3786,
"created": "2021-09-21 18:12:00.105650",
"metadata_id": 1,
"start": "2021-09-21 17:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 0.005,
"id": 3831,
"created": "2021-09-21 19:12:00.109082",
"metadata_id": 1,
"start": "2021-09-21 18:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 0.005,
"id": 3876,
"created": "2021-09-21 20:12:00.115131",
"metadata_id": 1,
"start": "2021-09-21 19:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 0.005,
"id": 3921,
"created": "2021-09-21 21:12:00.122294",
"metadata_id": 1,
"start": "2021-09-21 20:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 0.005,
"id": 3966,
"created": "2021-09-21 22:12:00.129139",
"metadata_id": 1,
"start": "2021-09-21 21:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 0.005,
"id": 4011,
"created": "2021-09-21 23:12:00.152165",
"metadata_id": 1,
"start": "2021-09-21 22:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 0.005,
"id": 4056,
"created": "2021-09-22 00:12:00.137474",
"metadata_id": 1,
"start": "2021-09-21 23:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8386.175,
"sum": 9176.884
"id": 4101,
"created": "2021-09-22 01:12:00.142365",
"metadata_id": 1,
"start": "2021-09-22 00:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8386.175,
"sum": 9176.884
"id": 4146,
"created": "2021-09-22 02:12:00.271361",
"metadata_id": 1,
"start": "2021-09-22 01:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8386.175,
"sum": 9176.884
"id": 4191,
"created": "2021-09-22 03:12:00.155781",
"metadata_id": 1,
"start": "2021-09-22 02:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8386.175,
"sum": 9176.884
"id": 4236,
"created": "2021-09-22 04:12:00.151024",
"metadata_id": 1,
"start": "2021-09-22 03:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8386.175,
"sum": 9176.884
"id": 4281,
"created": "2021-09-22 05:12:00.165081",
"metadata_id": 1,
"start": "2021-09-22 04:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8386.175,
"sum": 9176.884
"id": 4326,
"created": "2021-09-22 06:12:00.158784",
"metadata_id": 1,
"start": "2021-09-22 05:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8386.231,
"sum": 9176.94
"id": 4371,
"created": "2021-09-22 07:12:00.165074",
"metadata_id": 1,
"start": "2021-09-22 06:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8387.211,
"sum": 9177.92
"id": 4416,
"created": "2021-09-22 08:12:00.182573",
"metadata_id": 1,
"start": "2021-09-22 07:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8390.09,
"sum": 9180.799
"id": 4461,
"created": "2021-09-22 09:12:00.194476",
"metadata_id": 1,
"start": "2021-09-22 08:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8394.8,
"sum": 9185.509
"id": 4506,
"created": "2021-09-22 10:07:56.384249",
"metadata_id": 1,
"start": "2021-09-22 09:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8401.606,
"sum": 9192.315
"id": 4518,
"created": "2021-09-22 11:12:00.097873",
"metadata_id": 1,
"start": "2021-09-22 10:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8409.402,
"sum": 9200.111
"id": 4530,
"created": "2021-09-22 12:12:00.040954",
"metadata_id": 1,
"start": "2021-09-22 11:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8417.885,
"sum": 9208.594000000001
"id": 4542,
"created": "2021-09-22 13:12:00.047369",
"metadata_id": 1,
"start": "2021-09-22 12:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8424.9,
"sum": 9215.609
"id": 4554,
"created": "2021-09-22 14:12:00.046287",
"metadata_id": 1,
"start": "2021-09-22 13:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8430.415,
"sum": 9221.124000000002
"id": 4566,
"created": "2021-09-22 15:12:00.046332",
"metadata_id": 1,
"start": "2021-09-22 14:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8434.913,
"sum": 9225.622000000001
"id": 4578,
"created": "2021-09-22 16:12:00.049546",
"metadata_id": 1,
"start": "2021-09-22 15:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8437.351,
"sum": 9228.060000000001
"id": 4590,
"created": "2021-09-22 17:12:00.053856",
"metadata_id": 1,
"start": "2021-09-22 16:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8437.957,
"sum": 9228.666000000001
"id": 4602,
"created": "2021-09-22 18:12:00.069212",
"metadata_id": 1,
"start": "2021-09-22 17:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8437.954,
"sum": 9228.663
"id": 4614,
"created": "2021-09-22 19:12:00.033862",
"metadata_id": 1,
"start": "2021-09-22 18:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8437.954,
"sum": 9228.663
"id": 4626,
"created": "2021-09-22 20:12:00.039015",
"metadata_id": 1,
"start": "2021-09-22 19:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8437.954,
"sum": 9228.663
"id": 4634,
"created": "2021-09-22 21:12:00.032527",
"metadata_id": 1,
"start": "2021-09-22 20:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8437.954,
"sum": 9228.663
"id": 4642,
"created": "2021-09-22 22:12:00.041186",
"metadata_id": 1,
"start": "2021-09-22 21:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8437.954,
"sum": 9228.663
"id": 4650,
"created": "2021-09-22 23:12:00.041797",
"metadata_id": 1,
"start": "2021-09-22 22:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8437.954,
"sum": 9228.663
"id": 4658,
"created": "2021-09-23 00:12:00.043819",
"metadata_id": 1,
"start": "2021-09-22 23:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8437.954,
"sum": 9228.663
"id": 4666,
"created": "2021-09-23 01:03:31.499206",
"metadata_id": 1,
"start": "2021-09-23 00:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8437.954,
"sum": 9228.663
"id": 4674,
"created": "2021-09-23 02:12:00.097932",
"metadata_id": 1,
"start": "2021-09-23 01:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8437.954,
"sum": 9228.663
"id": 4682,
"created": "2021-09-23 03:12:00.033302",
"metadata_id": 1,
"start": "2021-09-23 02:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8437.954,
"sum": 9228.663
"id": 4690,
"created": "2021-09-23 04:12:00.035528",
"metadata_id": 1,
"start": "2021-09-23 03:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8437.954,
"sum": 9228.663
"id": 4698,
"created": "2021-09-23 05:12:00.038124",
"metadata_id": 1,
"start": "2021-09-23 04:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8437.954,
"sum": 9228.663
"id": 4706,
"created": "2021-09-23 06:12:00.036602",
"metadata_id": 1,
"start": "2021-09-23 05:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8437.971,
"sum": 9228.68
"id": 4714,
"created": "2021-09-23 07:12:00.042672",
"metadata_id": 1,
"start": "2021-09-23 06:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8438.558,
"sum": 9229.267000000002
"id": 4722,
"created": "2021-09-23 08:12:00.043005",
"metadata_id": 1,
"start": "2021-09-23 07:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8441.723,
"sum": 9232.432
"id": 4730,
"created": "2021-09-23 09:12:00.050821",
"metadata_id": 1,
"start": "2021-09-23 08:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8446.753,
"sum": 9237.462000000001
"id": 4738,
"created": "2021-09-23 10:12:00.046757",
"metadata_id": 1,
"start": "2021-09-23 09:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8451.594,
"sum": 9242.303
"id": 4746,
"created": "2021-09-23 11:12:00.050466",
"metadata_id": 1,
"start": "2021-09-23 10:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8460.967,
"sum": 9251.676000000001
"id": 4754,
"created": "2021-09-23 12:12:00.060357",
"metadata_id": 1,
"start": "2021-09-23 11:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8469.082,
"sum": 9259.791000000001
"id": 4762,
"created": "2021-09-23 13:12:00.054219",
"metadata_id": 1,
"start": "2021-09-23 12:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8476.912,
"sum": 9267.621000000001
"id": 4770,
"created": "2021-09-23 14:12:00.057441",
"metadata_id": 1,
"start": "2021-09-23 13:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8483.913,
"sum": 9274.622000000001
"id": 4778,
"created": "2021-09-23 15:12:00.057892",
"metadata_id": 1,
"start": "2021-09-23 14:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8489.198,
"sum": 9279.907000000001
"id": 4786,
"created": "2021-09-23 16:12:00.061313",
"metadata_id": 1,
"start": "2021-09-23 15:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8492.306,
"sum": 9283.015000000001
"id": 4794,
"created": "2021-09-23 17:12:00.063269",
"metadata_id": 1,
"start": "2021-09-23 16:00:00",
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 8493.227,
"sum": 9283.936000000002
as you can see, the STATE = 8384.112, recorded on sept.21st at 16:12 - and SUM = 790.7140…
Then, for the rest of the day, I only have recordings with a STATE = 0.005 while the sum remains the same.
This applies for the rest of the day…
On Sept.22nd, Record-ID 4056, Created at 2021-09-22 00:12 the STATE has changed to 8386.175 which would be a valid increase from the last recorded state the day before at 16:12.
But the sum has changed to 9176.884 - this is true, if I add the reported value 8386.175 to the last summary from the day before.
at least, this would explain the huge increase of 8 Mwh in the night of the 22nd September, when I was able to fix the Monitoring response for the Sensor.
This would also explain, why no other recordings could be shown on the day of the 22nd, because the measurements are just too small to be shown in that scale.
Is there a way to fix the SUM ??
// another nice feature would be - if this can be fixed somehow, that I could consider a way to import some older measurements that were taken before the dashboard was set up…
