Fixing ESPHome Script for Pulse Valve
Hello everyone,
I need some help fixing my ESPHome script. I am using a pulse valve for watering, which opens with a positive pulse and closes with a negative pulse. Here is the code I am currently using. In Home Assistant, I have two entities: one for turning it on and another for turning it off. However, I would like to have just one switch to control the valve and see its status.
Could anyone help me modify this to have just one switch to control the valve and see its status? Any suggestions or improvements are greatly appreciated.
Thank you!
Below is the code I am using:
esphome:
  friendly_name: ventil_erdbeeren
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "fYg2MsukDml+tuO9LqX59IrFcfFx"
ota:
  password: "d28de69d526d"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Ventil-Erdbeeren"
    password: "sB0mLBykxBat"
captive_portal:
globals:
  - id: default_failsafe
    type: int
    restore_value: no
    initial_value: '2'  # default failsafe is 10 mins
switch:
  - platform: gpio
    pin: GPIO0
    name: "Ventil Erdbeeren On"
    restore_mode: ALWAYS_OFF
  - platform: gpio
    pin: GPIO2
    name: "Ventil Erdbeeren Off"
    name: "Ventil Erdbeeren"
    turn_on_action:
      - switch.turn_on: ventil_erdbeeren_on
      - delay: 50ms
      - switch.turn_off: ventil_erdbeeren_on
      - script.execute: failsafe
    turn_off_action:
      - switch.turn_on: ventil_erdbeeren_off
      - delay: 50ms
      - switch.turn_off: ventil_erdbeeren_off
  - platform: wifi_signal
    name: "Wifi Ventil Erdbeeren"
    update_interval: 60s
script:
  - id: failsafe
    then:
      - delay: '00:10:00'
      - delay: 50ms
Use gpio output
or make your gpio switches internal: true
It works! Grate!
Thank you very much.
