I propose there should be a component / add-on that analyses your config and suggests improvements, or points out semantic errors. While a lot of things are documented, it would make HA much more approachable for people if they could get information about their set-up, sort of like a compiler offers you warnings to investigate. This would lead to more users and hence a more vibrant HA ecosystem.
Here is why:
My key driver for using HA was the ability to bridge ZWave components to HomeKit. Using an AeoTec USB controller I was able to add my first switch with no difficulty, just by adding the homekit: entry into the configuration.yaml file and defining where my ZWave USB controller was. I was impressed by how easy it was.
However as I added more Homekit nodes it got very unreliable, I can’t count the number of times I deleted the .homekit.state file to try and solve the problem. I nearly gave up and started to look at OpenHab, but then after reading the docs https://www.home-assistant.io/components/homekit/ I understood the importance of the auto_start: false.
So yes I should have read the docs completely first, but realistically a lot of people won’t do this, instead I was frustrated the HA couldn’t warn me somehow. Especially as in one file I had Zwave Enabled and HomeKit, but not auto_start : false
Regards
