Flair Puck WiFi connection stability
I currently have intermittent connectivity issues with the Flair puck. Moving beyond the old fashioned questions such as "have you rebooted your router etc - we are way betond that. I have a very robust Wi-Fi network and a good signal strength at the puck from the nearest wireless access point. I have set up a separate dedicated SSID for the Flair which is 2.4Ghz IP4 only, and am using WPA2 AES. Still, this is the connectivity situation:
As I can supply 100% adequate WiFi and also configure it with alot of granularity, what am I missing? The above picture is from the puck connection status in HA, and the below picture is all activity from my DHCP server for the same puck. Why does the puck keep needing to be reassigned (or asking for) the IP address?
Can you assign a fixed IP to the device?
Good thought. Unfortunately there is no way to do it on the device, I have it assigned on the router for that Mac address…
