Flair Smart Vents - How do you get the temperature target value from Puck?
I have been able to connect my Flair Smart vents with Homeassistant (BTW, Kudos to the Client Services at Flair, they are very reactive and I got my API key in a couple of days).
I am piloting the vents with an automation triggered by my Aqara zigbee temperature probes. Everything is working well except I hardcoded the trigger temperature.
Can I read the Flair Puck temperature target to dynamically adjust my automations?
I don’t see any target temperature field in the documentation of the integration… (GitHub - RobertD502/home-assistant-flair: Custom component for Home Assistant Core for Flair pucks, vents, rooms, structures, and minisplits)
Just want to clarify why the puck doesn’t have a target temperature: Pucks are associated with rooms so the target temperature is reflected in the climate entity for the room the puck is associated with.
