I have been attempting to flash my SD card to run HA on my Rpi4. When I select Flash in BalenaEtcher, it starts and then I get a lengthy error message that culminates in ECONNRESET. I would love to post the details of the error but don’t know how to, as it won’t copy. Any assistance would be greatly appreciated. Note that I run BE as Administrator.
Thanks in advance.
Kilgore-Elder
Could be a bad SD card
I thought that too but I replaced the SD card and it still does the same thing.
I think I need to expand on this problem. I use a Lenovo Yoga laptop running Windows 10, which has a built-in SD card slot. The SD card I used was one that’s recommended by HA, which I got from Amazon. I also used an external SD card reader that plugs into the USB port. Still nothing. I just keep getting this ECONNRESET error. I figure I need to download the Rpi4 file and flash from the file. Any suggestions?
ECONNRESET sounds like a network issue when connecting to the URL. Try downloading the image file to your local computer and use the Flash from File option.
Downloaded the inage from GitHub and flashed it. Installed and running. Thanks for the suggestion.
