Newb here, so please excuse me if this is simple.
Went through all the topics, but can’t find an answer to my problem.
I am having problems installing HA.
I have a Dell 3050 i5-7500T. I want to use an M2 (WD SN750) NVMe) which is 500gb (overkill I know) as the device to run HA. It was a previously used M2 memory card, so I cleaned it using Windows and then initialized it and formatted it. I then put it into a M2 external enclosure and tried to install the HA software using the instructions provided on HA, with the generic x86/64 file. I couldn’t get it to flash for several times, as it kept failing. Instead of using the URL method I downloaded the file and used that to install which seemed to work. I then took the M2 drive out of the case and installed it into the computer. I made all the changes to the BIOS and rebooted. It stuck as it started to see the devices, but not the HA operating system it seemed. I then stuck the M2 drive back into the external case and changed the bios to see the external drive and HA booted up fine. I put it back in the computer and changed the bios to see just the M2 in the computer and again it didn’t work.
I don’t understand when I put the WD sn750 in the enclosure it works fine and boots up HA, but when I put it in the computer m2 slot it doesn’t seem to boot up. I don’t want to keep it in the USB port.
Any ideas / help ?
Thanks in advance
Ross
