Flash memory
I am trying to create a solution to automate turning blinds for the windows and this script provided by Andrew ( @triblondon ) is working for me:
esphome:
  platform: ESP8266
  board: d1_mini
  esp8266_restore_from_flash: true
  on_boot:
    priority: -100
    then:
      - stepper.report_position:
          position: !lambda "return id(saved_position);"
      - stepper.set_target:
          target: !lambda "return id(saved_position);"
      - stepper.set_speed:
          speed: 200 steps/s
      - script.execute: update_cover_position
logger:
ota:
  password: "foo" # set by ESPHome - use that value!
wifi:
  ssid: "foo"
  password: "foo"
  reboot_timeout: 2min
  ap:
    ssid: "Blinds-Tilt3 Fallback Hotspot"
    password: "foo"
captive_portal:
# Enable Home Assistant API
api:
  services:
    - service: set_stepper_target
      variables:
        target: int
      then:
            target: !lambda 'return target;'
        - script.execute: record_stepper_position
    - service: set_stepper_speed
      variables:
        speed: int
      then:
            speed: !lambda 'return speed;'
    - service: set_stepper_position
      variables:
        stepper_position: int
      then:
            position: !lambda "return stepper_position;"
            target: !lambda "return stepper_position;"
globals:
  - id: open_position
    type: int
    initial_value: '8000'
  - id: closed_position
    type: int
    initial_value: '1000'
  - id: saved_position
    type: int
    restore_value: true
stepper:
  - platform: a4988
    dir_pin: D4
    step_pin: D3
    sleep_pin: D2
    max_speed: 250 steps/s
    acceleration: 200
    deceleration: 200
cover:
    device_class: blind
    has_position: true
    optimistic: false
    open_action:
      - logger.log: "Opening"
      - cover.template.publish:
          current_operation: OPENING
          target: !lambda "return id(open_position);"
      - while:
          condition:
            lambda: 'return id(blind_stepper).current_position < id(open_position);'
          then:
            - delay: 1000 ms
          current_operation: IDLE
    close_action:
      - logger.log: "Closing"
          current_operation: CLOSING
          target: !lambda "return id(closed_position);"
      - while:
          condition:
            lambda: 'return id(blind_stepper).current_position > id(closed_position);'
          then:
            - delay: 1000 ms
    position_action:
      - logger.log: "Setting position"
          target: !lambda 'return (float(pos) * float( float(id(open_position)) - float(id(closed_position)) )) + float(id(closed_position));'
      - while:
          condition:
            lambda: 'return id(blind_stepper).current_position != ((float(pos) * float( float(id(open_position)) - float(id(closed_position)) )) + float(id(closed_position)));'
          then:
            - delay: 1000 ms
    stop_action:
      - logger.log: "Stopping"
          target: !lambda 'return id(blind_stepper).current_position;'
    name: "Current stepper position"
    lambda: return id(blind_stepper).current_position;
    update_interval: 5s
script:
  - id: update_cover_position
    then:
          position: !lambda 'return float( float(id(blind_stepper).current_position) - float(id(closed_position))) / float( float(id(open_position)) - float(id(closed_position)) );'
  - id: record_stepper_position
    then:
      - globals.set:
          value: !lambda 'return id(blind_stepper).current_position;'
But this configuration is writing the current position of blinds to flash memory and I understand that D1 flash can only handle finite number of write cycles so few questions:
  1. While the write cycle may be finite, with above configuration what sort of timeline (months or years) can be expected for the D1?
  2. Instead of writing to flash, is there a work around say write to a local file or create another sensor that can tracked for the purpose?
Lastly, I intend to attach rechargeable battery pack to the unit, is there anyway to get batter level using ESPHome?
Thanks.
