The board on the lights I got are different than in the video. My lights do not have the single LED chip at above the 8266 chip. I still attempted to flash them with my FTDI adapter but it would not connect. I also attempted to use Tuya Convert, but it also failed.
Does anyone know if these lights are still able to be flashed with Tasmota?
As you can see the LED controller as seen in the video is not there, but there are 5 smaller chips that are not present on the original board in the video. This is the original board from the video:
Can anyone tell me if Tasmota is still able to be flashed on this light with the different board? If it can, is there another way to do it other than with an FTDI adapter or Tuya Convert? I have tried both ways and it fails each time.
I just got one of these bulbs too. Its a bit confusing with the RX1, RX2, TX1, and TX2. My assumption is that the EN pad is to enable flashing mode. I was hoping someone had already gotten some experience with this.
