Flash TYWE3L (tuya RGB led strip)
Hi all,
I just installed ESPhome for the first time and was planning to make my first custom firmware for this led strip i got from aliexpress. Its a Tuya brand, the ship is called TYWE3L and is supposed to be a ESP8266?
https://www.aliexpress.com/item/10000013892613.html?spm=a2g0s.9042311.0.0.27424c4deRwZ5e
Module is TYWE3L, In a view it reminded me esp12 module, which is module with esp8266 MCU. Then searched and found that it’s sort of esp8266 type. Then i started looking into PCB and connections. As i found everything pointed, that it is actually esp8266 module and i can program it like ordinary one.
Anyone have any idea how to make that firmware on this one, so i can make a .bin file to flash it trough tuya-convert?
Found the chip here also, but i have no idea what to put as device type and board in the firmware.
Try here https://thibmaek.com/post/flashing-esphome-to-lsc-smart-connect-action-switches-power-plugs
Thank you! Managed with a slight different config, but still works :slight_smile:
No doubt you will share to esphome-configs.io
