I have a NodeMCU device with WiFi. I’m not sure what firmware is installed, though I bought them recently. I’ve installed the current version of Hassio on my windows PC, added on the ESPHome addon, and I want to flash the device with ESPHome. I have a serial interface plugged into my USB port. I tried to use the ESPHome mini-app to flash the device, but OTA is the only method it seems to have. Of course, OTA won’t work – the device can’t log into WiFi without being set up to do so…
I need step-by-step instructions or a link to some. HELP!
yes, same result
I think this has to do with the PC, not the device or the serial adapter. I need some driver or other and all I see is references to Linux or Mac…
I’m still having a hard time. I downloaded esphome-flasher as recommended in the FAQs. It runs on the PC. But the yaml file and compiled binaries are on the Hassio RPi. I’m stick again.
First, you need to get the firmware file to flash. For Hass.io add-on based installs you can use the COMPILE button (click the overflow icon with the three dots) and then press Download Binary.
Hello my HA is running on a Raspberry Pi. If I create something new here in the ESPHome Addon and I would like to upload it to a new device, I proceed in this way. I enter the necessary data and compile the file. Then I connect a NodeMCU via USB cable and start the ESPHome addon completely new. After restarting the upload on the top right appears via USB and I can upload the file … As I said I have a Raspberry Pi, whether this works on the PC so I do not know …
Idk much about espeasy since I write my own firmware from scratch for my mqtt esp devices (using arduino libraries of course), but I do know regardless what method you use to flash a board on a pc, you will have to have the USB uart drivers for the board installed on the PC (usually ch340 for nodemcu boards). Otherwise your os won’t be able to talk to it (usually only a problem with windows, since linux distros mostly include the usual drivers… ch340, cp2101, and ftdi).
I only use a USB charging cable with my Wemos D1 and NodeMCU, as is the case with smartphones, I do not need a “flash button” on these boards. On my ESP32 cam boards, I have a “USB to serial TTL adapter cable” in use, here I have to press the “Flash button”.
Maybe your configatoin is wrong, see post from: @nickrout
@nickrout
All my smartphone (HTC, LG, Samsung, Nokia, Motorola …) charging cable work, I have no problems. The micro USB to USB cable from Anker also work perfectly …
Final note. After I got a true microUSB DATA cable installed, the USB port on the NodeMCU came to life and began working. I flashed my second NodeMCU board just in case I forget how to do this… Senior moments happen…
Very well!!!
Luckily, there are also professionals in the forum here @nickrout !!
Maybe I caused more confusion than I helped, sorry for that. Find this forum very well, have received a lot of help here, and have tried to give something back …
