Thanks to @Hellis81 Big edit here - the original post and writeup was not the best… So here’s a corrected one!
Goal
I’m forgetfull of time. So I want my office lights to flash 3 times as a strong reminder that I have an upcoming meeting.
Getting an icalendar feed
In outlook, you can look under options and share the calendar. Same in Google. Do that so you’ll get a calendar link. (Outlook made an ICS file output which is what I used)
Install iCal Sensor in HA
Here’s the link to install the addon
note that I changed the default option to 15 number of events - I’m a busy person
This will create 15 entities (they start with ical.)
And in Nodered… you can tie this all together in a flow!
Thanks again to @Hellis81 for pointing out the “time” node which I had never noticed…
[{"id":"a5414599721e7ce7","type":"comment","z":"fc970e5b.238d6","name":"Calendar Alert","info":"","x":110,"y":4120,"wires":[]},{"id":"54487f80b21f353f","type":"api-call-service","z":"fc970e5b.238d6","name":"Light toggle","server":"a0eea9da.0fe1d8","version":3,"debugenabled":false,"service_domain":"switch","service":"toggle","entityId":"switch.ltuya_webmeeting_light","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":670,"y":4220,"wires":[["e0c2727b2c38f916"]]},{"id":"d4e0f3e9b8ca4789","type":"api-call-service","z":"fc970e5b.238d6","name":"Light toggle","server":"a0eea9da.0fe1d8","version":3,"debugenabled":false,"service_domain":"switch","service":"toggle","entityId":"switch.ltuya_webmeeting_light","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":670,"y":4320,"wires":[["2ce338a5a4f97da0"]]},{"id":"a145882118587658","type":"api-call-service","z":"fc970e5b.238d6","name":"Light toggle","server":"a0eea9da.0fe1d8","version":3,"debugenabled":false,"service_domain":"switch","service":"toggle","entityId":"switch.ltuya_webmeeting_light","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":670,"y":4420,"wires":[["9d27300471e73d75"]]},{"id":"e0c2727b2c38f916","type":"delay","z":"fc970e5b.238d6","name":"","pauseType":"delay","timeout":"300","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"outputs":1,"x":850,"y":4220,"wires":[["d4e0f3e9b8ca4789"]]},{"id":"2ce338a5a4f97da0","type":"delay","z":"fc970e5b.238d6","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"outputs":1,"x":850,"y":4320,"wires":[["a145882118587658"]]},{"id":"9d27300471e73d75","type":"delay","z":"fc970e5b.238d6","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"outputs":1,"x":870,"y":4420,"wires":[["63369d0efc6b3e2f"]]},{"id":"63369d0efc6b3e2f","type":"api-call-service","z":"fc970e5b.238d6","name":"Light toggle","server":"a0eea9da.0fe1d8","version":3,"debugenabled":false,"service_domain":"switch","service":"toggle","entityId":"switch.ltuya_webmeeting_light","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":770,"y":4520,"wires":[[]]},{"id":"2b401252a3377ed3","type":"ha-time","z":"fc970e5b.238d6","name":"Event 13","server":"a0eea9da.0fe1d8","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityId":"sensor.ical_my_agenda_13","property":"attributes.start","offset":"-10","offsetType":"num","offsetUnits":"minutes","randomOffset":false,"repeatDaily":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"sunday":false,"monday":true,"tuesday":true,"wednesday":true,"thursday":true,"friday":true,"saturday":false,"debugenabled":false,"x":320,"y":4454.285714285716,"wires":[["54487f80b21f353f"]]},{"id":"c03b3ce701807ed9","type":"ha-time","z":"fc970e5b.238d6","name":"Event 2","server":"a0eea9da.0fe1d8","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityId":"sensor.ical_my_agenda_2","property":"attributes.start","offset":"-10","offsetType":"num","offsetUnits":"minutes","randomOffset":false,"repeatDaily":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"sunday":false,"monday":true,"tuesday":true,"wednesday":true,"thursday":true,"friday":true,"saturday":false,"debugenabled":false,"x":130,"y":4240,"wires":[["54487f80b21f353f"]]},{"id":"eac056ddeb0d8f0f","type":"ha-time","z":"fc970e5b.238d6","name":"Event 3","server":"a0eea9da.0fe1d8","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityId":"sensor.ical_my_agenda_3","property":"attributes.start","offset":"-10","offsetType":"num","offsetUnits":"minutes","randomOffset":false,"repeatDaily":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"sunday":false,"monday":true,"tuesday":true,"wednesday":true,"thursday":true,"friday":true,"saturday":false,"debugenabled":false,"x":130,"y":4303.333333333333,"wires":[["54487f80b21f353f"]]},{"id":"2cdf781249d4d9a4","type":"ha-time","z":"fc970e5b.238d6","name":"Event 4","server":"a0eea9da.0fe1d8","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityId":"sensor.ical_my_agenda_4","property":"attributes.start","offset":"-10","offsetType":"num","offsetUnits":"minutes","randomOffset":false,"repeatDaily":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"sunday":false,"monday":true,"tuesday":true,"wednesday":true,"thursday":true,"friday":true,"saturday":false,"debugenabled":false,"x":130,"y":4366.666666666666,"wires":[["54487f80b21f353f"]]},{"id":"c7e6ef15317ced9f","type":"ha-time","z":"fc970e5b.238d6","name":"Event 5","server":"a0eea9da.0fe1d8","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityId":"sensor.ical_my_agenda_5","property":"attributes.start","offset":"-10","offsetType":"num","offsetUnits":"minutes","randomOffset":false,"repeatDaily":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"sunday":false,"monday":true,"tuesday":true,"wednesday":true,"thursday":true,"friday":true,"saturday":false,"debugenabled":false,"x":130,"y":4493.333333333332,"wires":[["54487f80b21f353f"]]},{"id":"f6dbd2dd53e8b354","type":"ha-time","z":"fc970e5b.238d6","name":"Event 6","server":"a0eea9da.0fe1d8","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityId":"sensor.ical_my_agenda_6","property":"attributes.start","offset":"-10","offsetType":"num","offsetUnits":"minutes","randomOffset":false,"repeatDaily":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"sunday":false,"monday":true,"tuesday":true,"wednesday":true,"thursday":true,"friday":true,"saturday":false,"debugenabled":false,"x":130,"y":4429.999999999999,"wires":[["54487f80b21f353f"]]},{"id":"febce1fd0e53f278","type":"ha-time","z":"fc970e5b.238d6","name":"Event 7","server":"a0eea9da.0fe1d8","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityId":"sensor.ical_my_agenda_7","property":"attributes.start","offset":"-10","offsetType":"num","offsetUnits":"minutes","randomOffset":false,"repeatDaily":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"sunday":false,"monday":true,"tuesday":true,"wednesday":true,"thursday":true,"friday":true,"saturday":false,"debugenabled":false,"x":130,"y":4556.666666666667,"wires":[["54487f80b21f353f"]]},{"id":"524e75fd51a7bf79","type":"ha-time","z":"fc970e5b.238d6","name":"Event 8","server":"a0eea9da.0fe1d8","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityId":"sensor.ical_my_agenda_8","property":"attributes.start","offset":"-10","offsetType":"num","offsetUnits":"minutes","randomOffset":false,"repeatDaily":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"sunday":false,"monday":true,"tuesday":true,"wednesday":true,"thursday":true,"friday":true,"saturday":false,"debugenabled":false,"x":310,"y":4140,"wires":[["54487f80b21f353f"]]},{"id":"e4ca8c5b239e72a8","type":"ha-time","z":"fc970e5b.238d6","name":"Event 9","server":"a0eea9da.0fe1d8","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityId":"sensor.ical_my_agenda_9","property":"attributes.start","offset":"-10","offsetType":"num","offsetUnits":"minutes","randomOffset":false,"repeatDaily":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"sunday":false,"monday":true,"tuesday":true,"wednesday":true,"thursday":true,"friday":true,"saturday":false,"debugenabled":false,"x":310,"y":4202.857142857143,"wires":[["54487f80b21f353f"]]},{"id":"e30b6c84f5049715","type":"ha-time","z":"fc970e5b.238d6","name":"Event 10","server":"a0eea9da.0fe1d8","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityId":"sensor.ical_my_agenda_10","property":"attributes.start","offset":"-10","offsetType":"num","offsetUnits":"minutes","randomOffset":false,"repeatDaily":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"sunday":false,"monday":true,"tuesday":true,"wednesday":true,"thursday":true,"friday":true,"saturday":false,"debugenabled":false,"x":320,"y":4265.714285714286,"wires":[["54487f80b21f353f"]]},{"id":"718412368124b57d","type":"ha-time","z":"fc970e5b.238d6","name":"Event 11","server":"a0eea9da.0fe1d8","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityId":"sensor.ical_my_agenda_11","property":"attributes.start","offset":"-10","offsetType":"num","offsetUnits":"minutes","randomOffset":false,"repeatDaily":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"sunday":false,"monday":true,"tuesday":true,"wednesday":true,"thursday":true,"friday":true,"saturday":false,"debugenabled":false,"x":320,"y":4328.571428571429,"wires":[["54487f80b21f353f"]]},{"id":"ab7223e080024067","type":"ha-time","z":"fc970e5b.238d6","name":"Event 12","server":"a0eea9da.0fe1d8","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityId":"sensor.ical_my_agenda_12","property":"attributes.start","offset":"-10","offsetType":"num","offsetUnits":"minutes","randomOffset":false,"repeatDaily":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"sunday":false,"monday":true,"tuesday":true,"wednesday":true,"thursday":true,"friday":true,"saturday":false,"debugenabled":false,"x":320,"y":4391.4285714285725,"wires":[["54487f80b21f353f"]]},{"id":"315512077bc8bd6e","type":"ha-time","z":"fc970e5b.238d6","name":"Event 1","server":"a0eea9da.0fe1d8","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityId":"sensor.ical_my_agenda_1","property":"attributes.start","offset":"-10","offsetType":"num","offsetUnits":"minutes","randomOffset":false,"repeatDaily":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"sunday":false,"monday":true,"tuesday":true,"wednesday":true,"thursday":true,"friday":true,"saturday":false,"debugenabled":false,"x":130,"y":4176.666666666667,"wires":[["54487f80b21f353f"]]},{"id":"4723fa110689236c","type":"ha-time","z":"fc970e5b.238d6","name":"Event 14","server":"a0eea9da.0fe1d8","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityId":"sensor.ical_my_agenda_14","property":"attributes.start","offset":"-10","offsetType":"num","offsetUnits":"minutes","randomOffset":false,"repeatDaily":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"sunday":false,"monday":true,"tuesday":true,"wednesday":true,"thursday":true,"friday":true,"saturday":false,"debugenabled":false,"x":320,"y":4517.142857142859,"wires":[["54487f80b21f353f"]]},{"id":"f5f040d3c293075b","type":"ha-time","z":"fc970e5b.238d6","name":"Event 15","server":"a0eea9da.0fe1d8","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityId":"sensor.ical_my_agenda_15","property":"attributes.start","offset":"-10","offsetType":"num","offsetUnits":"minutes","randomOffset":false,"repeatDaily":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"sunday":false,"monday":true,"tuesday":true,"wednesday":true,"thursday":true,"friday":true,"saturday":false,"debugenabled":false,"x":320,"y":4580,"wires":[["54487f80b21f353f"]]},{"id":"a0eea9da.0fe1d8","type":"server","name":"GOOD Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":false,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30"}]
