Joe3
1
This code works and will flash a string of leds. Now I’m wondering how to flash only one in the row.
#light: # Flashing
- platform: fastled_clockless
on_turn_on:
then:
- light.turn_on:
brightness: 50%
effect: Flashing
chipset : WS2812B
rgb_order: GRB
internal: False
pin: GPIO3
num_leds: 7
name: "offstr Flash" # Name seven segments
effects:
- strobe:
colors:
- state: True
red: 0%
green: 100%
blue: 0%
duration: 500ms
- state: False
duration: 500ms
I use the partition platform to just turn them on and off. How do I combine flashing code with partition code to flash one segment?
light:
- platform: neopixelbus
type: GRB
variant: WS2811
pin: GPIO3 #RX pin
num_leds: 27
internal: true
- platform: partition
name: "offstr0" # Name Just Seg 0
segments:
- id: offstr
to: 2
Joe3
3
The Light Partition Link does not help.
Joe3
4
This does not work.
segments:
- id: offstr
to: 26
effects:
- strobe:
colors:
- state: True
red: 0%
green: 100%
blue: 0%
duration: 500ms #1000ms
- state: False
duration: 500ms
Joe3
5
This code disables the other segments.
nickrout
(Nick Rout)
6
You only have 3 leds defined, 24, 25 & 26.
Define the other leds as partitions.
Joe3
7
This is more of the code
They are all defined and the Turn on all partition makes a double partition.
weird.
light:
type: GRB
variant: WS2811
pin: GPIO3 #RX pin
num_leds: 27
internal: true
# Start Segments # Start Segments # Start Segments
name: "offstrAll" # All
segments:
- id: offstr
to: 26
segments:
- id: offstr
to: 2
segments:
- id: offstr
to: 5
segments:
- id: offstr
to: 8
segments:
- id: offstr
to: 11
segments:
- id: offstr
to: 14
segments:
- id: offstr
to: 17
segments:
- id: offstr
to: 20
segments:
- id: offstr
to: 23
segments:
- id: offstr
to: 26
effects:
- strobe:
colors:
- state: True
red: 0%
green: 100%
blue: 0%
- state: False
duration: 500ms
