Good morning. I couldn’t find any information on how to hack a Sonoff POW R3 to make it an ESPHome device. Can someone please help me?
Thank you
Have you had any joy with this? I have a POW R3 on order and also want to intigrated with HA using ESPHome (I am migrating devices to ESPHome to avoid having to run a seperate MQTT server).
Almost… for some reason the switch want work, and the V showing 15v - but its a start, to get you online.
esphome:
esp32:
board: nodemcu-32s
Enable logging
logger:
wifi:
ssid: xxxxx
password: xxxxx
Optional manual IP
manual_ip:
static_ip: x.x.x.x
gateway: x.x.x.x
subnet: 255.255.255.0
dns1: x.x.x.x
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “sonoffvpkids Fallback Hotspot”
password: “xxxxxxxxxxxxx”
captive_portal:
Enable Home Assistant API
api:
password: “xxxxx”
ota:
password: “xxxxx”
uart:
rx_pin: GPIO16
baud_rate: 4800
- platform: cse7766
update_interval: 2s
current:
voltage:
power:
on_value_range:
- above: 4.0
then:
- light.turn_on: switch_led
- below: 3.0
then:
- light.turn_off: switch_led
energy:
output:
- platform: ledc
pin:
number: GPIO18
inverted: True
light:
- platform: monochromatic
output: led
internal: True - platform: status_led
internal: True
pin:
number: GPIO05
inverted: True
switch:
optimistic: true
lambda: |-
if (isnan(id(w_sensor).state)) {
return {};
} else if (id(w_sensor).state > 4) {
// Running
return true;
} else {
// Not running
return false;
turn_off_action:- switch.turn_on: relay_off
turn_on_action: - switch.turn_on: relay_on
- platform: gpio
restore_mode: ALWAYS_OFF
internal: true
pin: GPIO04
on_turn_on:- switch.turn_on: relay_off
- delay: 500ms
- switch.turn_off: relay_off # bi-stable relay so no need to keep on.
interlock: [relay_on]
- platform: gpio
internal: true
pin: GPIO02
on_turn_on:- switch.turn_on: relay_on
- delay: 500ms
- switch.turn_off: relay_on # bi-stable relay so no need to keep on.
interlock: [relay_off]
- platform: restart
Not sure if this is helpful, but I recently set up a Sonoff POW R3 with ESPHome for use with a hot water tank immersion heater.
Took various bits of code from various sources locally and online. In my case, I’ve added 3 Dallas temperature sensors connecting to GPIO4 so I can monitor the tank temperature.
I’m using this to utilise spare solar power after the car is charged. (better than selling to the grid for 4p a kWh
I initially used GPIO15 for the temperature sensors but that stopped everything from working.
substitutions:
esphome_name: hotwatersonoff
esphome_friendly_name: Hot Water Sonoff
esphome:
friendly_name: Hot Water Heater Sonoff
esp8266:
board: esp8285
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxx"
ota:
password: "xxxxxxxxx"
wifi:
output_power: 18db
power_save_mode: light
ssid: !secret wifi_ssid
ap:
ssid: "Hot-Water-Heater-Sonoff"
captive_portal:
dallas:
- pin: GPIO4
# Enable web server
web_server:
port: 80
time:
- platform: homeassistant
timezone: Europe/London
#GPIO0 Button (inverted)
#GPIO12 Relay and Red LED
#GPIO13 Blue LED (inverted)
uart:
rx_pin: RX
baud_rate: 4800
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
on_press:
- switch.toggle: fakebutton
switch:
name: "Hot Water Relay"
optimistic: true
turn_on_action:
- light.turn_on: led
turn_off_action:
- light.turn_off: led
- platform: gpio
inverted: yes
pin: GPIO12
restore_mode: RESTORE_DEFAULT_ON
output:
- platform: esp8266_pwm
pin:
number: GPIO13
inverted: True
light:
name: "${esphome_friendly_name} Blue LED"
output: pow_blue_led
internal: true
- platform: wifi_signal
name: "${esphome_friendly_name} WiFi Signal"
update_interval: 60s
- platform: uptime
- platform: cse7766
update_interval: 2s
current:
voltage:
power:
energy:
- platform: dallas
address: 0xb60000001284c428
name: "${esphome_friendly_name} Temperature Sensor 1"
icon: "mdi:water-thermometer"
filters:
- filter_out: nan
- platform: dallas
address: 0x4f00000012821c28
name: "${esphome_friendly_name} Temperature Sensor 2"
filters:
- filter_out: nan
- platform: dallas
address: 0xb10000001483f228
name: "${esphome_friendly_name} Temperature Sensor 3"
filters:
- filter_out: nan
name: "{esphome_friendly_name} Average Tank Temperature"
unit_of_measurement: "°C"
lambda: |-
return (id(temp_1).state + id(temp_2).state + id(temp_3).state)/3;
name: "{esphome_friendly_name} Max Tank Temperature"
lambda: |-
return ((id(temp_1).state > id(temp_2).state) ? ((id(temp_1).state > id(temp_3).state) ? id(temp_1).state : id(temp_3).state) : (id(temp_2).state > id(temp_3).state) ? id(temp_2).state : id(temp_3).state);
name: "{esphome_friendly_name} Min Tank Temperature"
lambda: |-
return ((id(temp_1).state < id(temp_2).state) ? ((id(temp_1).state < id(temp_3).state) ? id(temp_1).state : id(temp_3).state) : (id(temp_2).state < id(temp_3).state) ? id(temp_2).state : id(temp_3).state);
Hi Rich/Thansen1980 , can any of you post the clean configuration that will work with pow r3 (25A) for esp home
Thank you so much
+1, any clean fully working config?
define “clean”, pls ![]()
This one should be undaerstandable, tho it has some extra lambdas, but all are explainded with comments. Working fawlessly here with my Sonoff pow origin (POWR316). The 3 dashes at the beginning are to make things easier for the yaml parser, but it’s not mandatory.
##### information #####
# model: Sonoff pow origin (POWR316)
# explication: https://templates.blakadder.com/sonoff_POWR316.html
# buy: https://www.aliexpress.com/wholesale?SearchText=sonoff+powr316
# GPIO Pinout
# | Pin | Component |
# | GPIO0 | Button |
# | GPIO05 | Status LED (inverted) |
# | GPIO13 | Relay |
# | GPIO16 | CSE7766 Rx |
# | GPIO18 | LED (inverted) |
# As the communication with the CSE7766 is done using UART, you need to have an UART bus in your configuration with the rx_pin connected to the CSE7766.
# Additionally, you need to set the baud rate to 4800.
##### basic configs #####
# set up variables
substitutions:
my_name: 'POW316-WM'
my_device: pow316-wm
my_reboot_timeout: 30min
my_update_interval: 12sec
my_static_ip: 10.11.12.13
# define core configs
esphome:
friendly_name: ${my_name}
area: 'Waschküche'
comment: I usually comment the last change here
on_boot:
priority: -100
then:
esp32:
board: esp32dev
wifi:
fast_connect: true
reboot_timeout: ${my_reboot_timeout}
manual_ip:
static_ip: ${my_static_ip}
gateway: 192.168.1.1
dns1: 192.168.1.1
dns2: 9.9.9.9
ap:
# after connecting to it, navigate to http://192.168.4.1/
ssid: '${my_name} AP'
password: !secret ap_wifi_password
ap_timeout: 1min
captive_portal:
api:
encryption:
key: !secret native_api_key
ota:
safe_mode: true
password: !secret ota_password
logger:
level: DEBUG
# Disable logging to serial
baud_rate: 0
web_server:
port: 80
auth:
username: !secret web_srv_user
password: !secret web_srv_pswd
time:
on_time:
# device restart (5 minutes after dhcp router and WiFi APs reboot)
- days_of_week: THU
hours: 4
minutes: 35
seconds: 0
then:
- button.press: reboot
# shift values sortly before midnight reset
- hours: 23
minutes: 59
seconds: 59
then:
- sensor.template.publish:
state: !lambda return id(power_today_minus_2).state;
state: !lambda return id(power_today_minus_1).state;
state: !lambda return id(power_today).state;
#### specific configs #####
uart:
rx_pin: GPIO16
baud_rate: 4800
data_bits: 8
parity: EVEN
stop_bits: 1
binary_sensor:
# define button on device and it's press action
- platform: gpio
pin:
number: GPIO0
mode:
input: true
pullup: true
filters:
# eliminate bouncing noise
- delayed_on_off: 25ms
on_press:
then:
- switch.toggle: relay
# show as active when power reading is above 0W, idle when it's 0W. Both if state persists for at least 2 update cicles.
name: '${my_name} aktivity'
device_class: power
filters:
- delayed_on_off: 24s
lambda: 'if (id(power).state>(0)) return true; else return false;'
- !include common/binary_sensors/status.yaml
switch:
- platform: gpio
icon: 'mdi:lightning-bolt-circle'
pin: GPIO13
on_turn_on:
light.turn_on: led
on_turn_off:
light.turn_off: led
button:
- !include common/buttons/restart_button.yaml
- !include common/buttons/restart_safe_mode.yaml
# energy measurement
- platform: cse7766
# voltage sensor
voltage:
unit_of_measurement: 'V'
accuracy_decimals: 1
device_class: voltage
state_class: measurement
icon: 'mdi:alpha-v'
filters:
# agreggate values of polls
- throttle_average: ${my_update_interval}
# map from sensor -> measured value
- calibrate_linear:
- 0.647 -> 0.0
- 221.1-> 219
- 230 -> 226.5
# set not a number and values below 5V to zero or state value in V
- lambda: 'if (isnan(x)) return(0); else if (x<(5)) return(0); else return(x);'
# don't report minor changes from previous value
- delta: 1
# current sensor
current:
unit_of_measurement: 'A'
accuracy_decimals: 3
icon: 'mdi:alpha-a'
filters:
- calibrate_linear:
- 0.0 -> 0.004
- 3.374 -> 3.37
- 4.846 -> 4.864
- 8.045 -> 8.097
# set not a number and low values plus own consumption to zero or correct higher values with own consumption and state value
- lambda: 'if (isnan(x)) return(0); else if (x<(0.025 + 0.008)) return(0); else return(x - 0.008);'
- delta: 0.02
# power sensor
power:
device_class: power
unit_of_measurement: W
icon: 'mdi:alpha-w'
filters:
- calibrate_linear:
- 0.0 -> 1.2
- 768.4 -> 771.7
- 1110.3 -> 1109
- 1807.4 -> 1802
# set not a number and values below 5W plus own consumption to zero or correct higher values with own consumption and state value
- lambda: 'if (isnan(x)) return(0); else if (x<(5 + 1.2)) return(0); else return(x - 1.2);'
- delta: 1
# energy sensor
energy:
device_class: energy
unit_of_measurement: 'Wh'
filters:
# set not a number to zero or state value
- lambda: 'if (isnan(x)) return(0); else return(x);'
- delta: 0.5
# power factor
update_interval: ${my_update_interval}
name: '${my_name} power factor'
unit_of_measurement: '%'
device_class: power_factor
icon: 'mdi:decagram-outline'
lambda: 'return id(power).state / id(voltage).state / id(current).state;'
filters:
- lambda: 'if (isnan(x)) return(0); else return(x*100);'
# don't report changes from previous value lower than 1%
- delta: 1
# total daily energy
- platform: total_daily_energy
name: '${my_name} total daily energy'
power_id: power
state_class: total_increasing
icon: 'mdi:numeric-0-box-outline'
filters:
# shifting total daily energy short before reset at midnight
name: '${my_name} total energy today -1'
icon: 'mdi:numeric-1-box-outline'
filters:
name: '${my_name} total energy today -2'
icon: 'mdi:numeric-2-box-outline'
filters:
name: '${my_name} total energy today -3'
icon: 'mdi:numeric-3-box-outline'
filters:
# delete not a number or state value
- platform: uptime
internal: true
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days) + "d " : "") +
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
# WiFi rssi in dBs
internal: true
update_interval: 5min
filters:
# WiFi rssi in percents
name: '${my_name} WiFi Signalstärke'
accuracy_decimals: 0
icon: mdi:wifi-strength-2
lambda: |-
if (id(wifi_rssi_dbs).state < -92.0)
return 1.0;
if (id(wifi_rssi_dbs).state > -21.0)
return 100.0;
else
return round(( -0.0154 * id(wifi_rssi_dbs).state * id(wifi_rssi_dbs).state ) - ( 0.3794 * id(wifi_rssi_dbs).state ) + 98.182 );
filters:
# do not report changes lower than +-2%
- delta: 2.0
output:
- platform: ledc
pin: GPIO18
inverted: true
max_power: 0.66
light:
output: onboard_led
internal: true
text_sensor:
- platform: wifi_info
ip_address:
icon: mdi:ip-network-outline
ssid:
icon: mdi:access-point-network
bssid:
icon: mdi:plus-network-outline
icon: mdi:minus-network-outline
update_interval: 15min
lambda: |-
return {WiFi.macAddress().c_str()};
- platform: version
name: '${my_name} ESPHome Version'
icon: mdi:clock-start
status_led:
# use blue LED as status indicator
pin:
number: GPIO05
inverted: true
Is it possible to output to the serial port on the board? I need some help with the UART I think,
You have a number of include files. Can you provide the code for these or a link to a repository where they have been sourced?
Thanks in advance.
Hi @RichShort
Could you please share pinout diagram? I don’t know how to identity free gpio pins on PCB? I also want to connect temp sensor and use in my water heater
Long delay, sorry didn’t get a notification. In case you still need it I used GPIO15
Other pins probably work too. Depends how many you need
0,12,13 are used by sonoff so those can’t be used.
Hi everyone,
I just published a detailed guide on how to flash a Sonoff POW R3 with ESPHome. This tutorial covers the entire process, from hardware preparation to firmware configuration, and includes tips for integrating the device into Home Assistant.
If you’re looking to customize your Sonoff POW R3 for better energy monitoring or local control, this guide might help!
Feel free to ask if you have any questions or need further clarification. Happy flashing! ![]()
Hi everyone,
I’ve recently got a Sonoff POW R3 and attempting to flash it with ESPHome firmware.
However, I appear to be failing at the first hurdle! So far I’ve read a couple of guides on this but I can’t for the life of me get this thing into flashing mode.
It doesn’t seem to matter how long it hold the ‘Flashing’ button for, I just get no response. The FTDI tried to communicate but no get no response - I’ve tried switching the TX/RX pins to no avail.
I know the FTDI board and wires works, I’ve just checked the esptool flash-id command returns data with one of the SONOFF light switch I’ve got.
The guide by ‘sigalou’ suggests that the blue led should got off when it’s in flashing mode, but that just stays constantly on for me - though slightly dimmer that if I let it boot normally.
The board in my POW R3 appears to be dated 2022/12/26. I’m using an FTDI FT232RI which is fine for all the light switch I have - maybe I need a different one for this?
Any suggest/pointers as to were I’m going wrong with this would be much appreciated.
Many thanks
Had the same issue as you.
Landed up pulling the bottom side closest to the esp chip of the flashing button to ground using a jumper.
Also used esptool and some ChatGPT to get it solved.
Hope this helps and you get it sorted.
