I’m trying to flash the eWeLink PCIe Computer Remote (SANT-SUD01) as detailed here.
My Pi running Home Assistant OS & ESPHome has insufficient memory to successfully compile so I have to compile and run on a WSL Ubuntu machine. However it is successfully identified & Backed Up the chip and stock firmware and am using the USB to UART Module (Micro/Mini/Type-A or Type-C) | The Pi Hut module to connect to it.
When flashing it usually fails at 50% - is there an undocumented stage that’s required first or should this be working?
Also tried directly from python on Windows and get the same error.
C:\Users\Kev\Downloads>C:\Users\Kev\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\LocalCache\local-packages\Python312\Scripts\esptool.exe --port COM10 --before default_reset --after hard_reset --chip esp8266 write_flash -z --flash_size detect 0x0 mclaren-pc-power-control.bin
esptool.py v4.6.2
Serial port COM10
Connecting...
Chip is ESP8285N08
Features: WiFi, Embedded Flash
Crystal is 26MHz
MAC: 48:55:19:4c:39:54
Stub is already running. No upload is necessary.
Configuring flash size...
Auto-detected Flash size: 1MB
Flash will be erased from 0x00000000 to 0x0006cfff...
Compressed 444272 bytes to 314232...
Writing at 0x00005d92... (10 %)Traceback (most recent call last):
File "C:\Users\Kev\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\LocalCache\local-packages\Python312\site-packages\esptool\__init__.py", line 1073, in _main
main()
File "C:\Users\Kev\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\LocalCache\local-packages\Python312\site-packages\esptool\__init__.py", line 868, in main
operation_func(esp, args)
File "C:\Users\Kev\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\LocalCache\local-packages\Python312\site-packages\esptool\cmds.py", line 595, in write_flash
esp.flash_defl_block(block, seq, timeout=timeout)
File "C:\Users\Kev\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\LocalCache\local-packages\Python312\site-packages\esptool\loader.py", line 131, in inner
return func(*args, **kwargs)
File "C:\Users\Kev\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\LocalCache\local-packages\Python312\site-packages\esptool\loader.py", line 1037, in flash_defl_block
self.check_command(
File "C:\Users\Kev\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\LocalCache\local-packages\Python312\site-packages\esptool\loader.py", line 436, in check_command
val, data = self.command(op, data, chk, timeout=timeout)
File "C:\Users\Kev\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\LocalCache\local-packages\Python312\site-packages\esptool\loader.py", line 405, in command
p = self.read()
File "C:\Users\Kev\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\LocalCache\local-packages\Python312\site-packages\esptool\loader.py", line 338, in read
return next(self._slip_reader)
StopIteration
A fatal error occurred: The chip stopped responding.
esptool.py --before no_reset --port /dev/ttyACM0 chip_id
esptool.py v4.6.2
Serial port /dev/ttyACM0
Connecting...
Detecting chip type... Unsupported detection protocol, switching and trying again...
Connecting...
Detecting chip type... ESP8266
Chip is ESP8285N08
Crystal is 26MHz
Chip ID: 0x004c3954
Hard resetting via RTS pin...
esptool.py --before no_reset --port /dev/ttyACM0 flash_id
esptool.py v4.6.2
Connecting....
Connecting...
Chip is ESP8285N08
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
Manufacturer: 5e
Device: 3214
Detected flash size: 1MB
esptool.py --port /dev/ttyACM0 read_flash 0x000000 0x100000 flash_backup.bin
esptool.py v4.6.2
Connecting...
Connecting...
Chip is ESP8285N08
Crystal is 26MHz
1048576 (100 %)
1048576 (100 %)
Read 1048576 bytes at 0x00000000 in 93.2 seconds (90.0 kbit/s)...
Yaml:- mclaren-pc-power-control.yaml
substitutions:
friendly_name: "McLaren PC Power Control"
friendly_name_short: "McLaren Control"
hostname: "mclaren-pc-power-control"
esphome:
# Shows up in UI
comment: "Remote power button for ${friendly_name_short}."
wifi:
ssid: "MYSSID
password: "MyPASS"
esp8266:
# Specifically a 'ESP8285N08' with 1MB built in flash
# See: https://docs.platformio.org/en/stable/boards/espressif8266/esp8285.html
board: esp8285
logger:
level: INFO
script:
- id: regular_press
mode: single
then:
- output.turn_on: out_relay
- delay: .5s
- output.turn_off: out_relay
status_led:
pin:
number: GPIO13
inverted: True
- platform: pulse_meter
pin: GPIO0
timeout: 5s
switch:
- name: "${friendly_name_short} Power"
platform: template
lambda: |-
if (id(power_status_pulses).state > 60.0f) {
return true;
} else {
return false;
#Replace the lambda function above with the one below if you have inverted the relay output
# lambda: |-
# if (id(power_status_pulses).state > 60.0f) {
# return false;
# } else {
# return true;
# Mimic the user pressing the button
turn_on_action:
- script.execute: regular_press
turn_off_action:
output:
- platform: gpio
#Inverts relay operation, this avoids force shutdown behavior on some motherboards. Uncomment here and replace the above lambda if you are having this problem.
#inverted: True
pin: GPIO12
# Enable Home Assistant API
api:
encryption:
key: "MYENCRYPTION"
ota:
password: "MYPASSWORD"
Run
esphome run mclaren-pc-power-control.yaml
Then Errors with
(number): 1
esptool.py v4.6.2
Connecting....
Chip is ESP8285N08
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Flash will be erased from 0x00000000 to 0x0006dfff...
Compressed 448496 bytes to 316371...
Writing at 0x00013f7f... (20 %)ERROR Running command failed:
ERROR Please try running esptool.py --before default_reset --after hard_reset --baud 460800 --port /dev/ttyACM0 --chip esp8266 write_flash -z --flash_size detect 0x0 /mnt/c/Users/Kev/Downloads/.esphome/build/mclaren-pc-power-control/.pioenvs/mclaren-pc-power-control/firmware.bin locally.
INFO Upload with baud rate 460800 failed. Trying again with baud rate 115200.
esptool.py v4.6.2
Connecting......................................
ERROR Running command failed: Failed to connect to ESP8266: No serial data received.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
ERROR Please try running esptool.py --before default_reset --after hard_reset --baud 115200 --port /dev/ttyACM0 --chip esp8266 write_flash -z --flash_size detect 0x0 /mnt/c/Users/Kev/Downloads/.esphome/build/mclaren-pc-power-control/.pioenvs/mclaren-pc-power-control/firmware.bin locally.
Reconnecting and running the command manually produces the following:-
sudo chmod 777 /dev/ttyACM0 ;esptool.py --before default_reset --after hard_reset --port /dev/ttyACM0 --chip esp8266 write_flash -z --flash_size detect 0x0 /mnt/c/Users/Kev/Downloads/.esphome/build/mclaren-pc-power-control/.pioenvs/mclaren-pc-power-control/firmware.bin
esptool.py v4.6.2
Connecting....
Chip is ESP8285N08
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
Writing at 0x0002693c... (35 %)Traceback (most recent call last):
File "/home/kev/.local/lib/python3.10/site-packages/esptool/__init__.py", line 1073, in _main
main()
File "/home/kev/.local/lib/python3.10/site-packages/esptool/__init__.py", line 868, in main
File "/home/kev/.local/lib/python3.10/site-packages/esptool/cmds.py", line 595, in write_flash
File "/home/kev/.local/lib/python3.10/site-packages/esptool/loader.py", line 131, in inner
File "/home/kev/.local/lib/python3.10/site-packages/esptool/loader.py", line 1037, in flash_defl_block
self.check_command(
File "/home/kev/.local/lib/python3.10/site-packages/esptool/loader.py", line 436, in check_command
File "/home/kev/.local/lib/python3.10/site-packages/esptool/loader.py", line 405, in command
p = self.read()
File "/home/kev/.local/lib/python3.10/site-packages/esptool/loader.py", line 338, in read
StopIteration
Highest I’ve gotten is 50%
