Well, receiver response is usually slow, and didn’t notice any lag compared to the media_player
component. Also tried your buttons with light
, which is very responsive – see here
My plan is to add all media_players to a generic media_player per room. So that there is 1 ‘full’ card per room. This way I will have as many cards as I have rooms on my Media view, and I can include them separately on my ‘per room’ views.
At least I figured this is the most elegant / functional solution. Having 5 media players (in the same room) show up doesn’t make sense, since there would only 1 be playing while the rest 'd be idle.
Can you share your code please as that looks awesome and just what I need!
Sure, here it is:
First i have a custom_component that acts as a sensor for the source and volume_levels.
custom_components/switch/denonxml.py
import time, math, requests
import voluptuous as vol
from xml.etree import ElementTree
from homeassistant.components.media_player import (PLATFORM_SCHEMA, MediaPlayerDevice)
from homeassistant.const import (CONF_HOST, CONF_PORT)
import homeassistant.helpers.config_validation as cv
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
vol.Required(CONF_HOST): cv.string,
vol.Required(CONF_PORT): cv.string,
def setup_platform(hass, config, add_devices, discovery_info=None):
denonxml = DenonSensor(config.get(CONF_HOST), config.get(CONF_PORT))
add_devices([denonxml])
class DenonSensor(MediaPlayerDevice):
def __init__(self, host, port):
self._state = "off"
self._host = host
self._port = port
self._name = "Denon " + port
@property
def name(self):
return "Denon Zone" + self._port
@property
def state(self):
return self._state
@property
def source(self):
return self._mediasource
@property
def volume_level(self):
return self._volume
def getZon(self):
if self._port == "2":
return "Z2"
else:
return "ZM"
def turn_off(self):
url = "http://" + self._host + "/goform/formiPhoneAppDirect.xml?" + self.getZon() + "OFF"
requests.get(url)
time.sleep(4)
def turn_on(self):
url = "http://" + self._host + "/goform/formiPhoneAppDirect.xml?" + self.getZon() + "ON"
requests.get(url)
time.sleep(4)
def update(self):
url = "http://" + self._host + "/goform/formMainZone_MainZoneXml.xml?ZoneName=zone" + self._port
response = requests.get(url)
root = ElementTree.fromstring(response.content)
on_off = root.find('ZonePower').find('value').text
src = root.find('InputFuncSelect').find('value').text
volume = root.find('MasterVolume').find('value').text
self._state = on_off.lower()
self._mediasource = src
self._volume = math.ceil(float(volume)) + 80
Next, comes the custom_ui
custom_ui/state-card-custom_source.html
<dom-module id="state-card-custom_source">
<template>
<style is="custom-style" include="iron-flex iron-flex-alignment"></style>
<style>
:host {
line-height: 1.5;
ha-entity-toggle {
margin-left: 55px;
paper-button.nml {
min-width: 35px;
paper-button.sel {
min-width: 35px;
color: #03a9f4;
font-weight: 800;
paper-slider {
margin: 4px 0;
max-width: 100%;
min-width: 100px;
width: var(--ha-paper-slider-width, 200px);
</style>
<div class='horizontal justified layout'>
<state-info state-obj="[[stateObj]]"></state-info>
<paper-slider min="10" max="70" value="[[vol_num]]" pin on-change="volChanged" on-tap="stopPropagation"></paper-slider>
</div>
<ha-entity-toggle state-obj="[[stateObj]]" hass="[[hass]]"></ha-entity-toggle>
<paper-button-group>
<template is='dom-if' if='[[_showControl(stateObj,"1")]]'>
<paper-button class$='[[_clsbtn(stateObj,"Game")]]' on-tap="btntap11">XBOX</paper-button>
<paper-button class$='[[_clsbtn(stateObj,"CBL/SAT")]]' on-tap="btntap12">TATASKY</paper-button>
<paper-button class$='[[_clsbtn(stateObj,"Media Player")]]' on-tap="btntap13">KODI</paper-button>
</template>
<template is='dom-if' if='[[_showControl(stateObj,"2")]]'>
<paper-button class$='[[_clsbtn(stateObj,"Online Music")]]' on-tap="btntap21">AIRPLAY</paper-button>
<paper-button class$='[[_clsbtn(stateObj,"AUX")]]' on-tap="btntap22">KODI</paper-button>
</template>
</paper-button-group>
</div>
</template>
</dom-module>
<script>
Polymer({
is: 'state-card-custom_source',
properties: {
hass: {
type: Object,
stateObj: {
type: Object,
vol_num: {
type: String,
computed: 'computeVol(stateObj)',
_showControl: function (stateObj,zone) {
return (this.stateObj.entity_id.slice(-1) === zone);
_clsbtn: function (stateObj,btn_src) {
if (btn_src === this.stateObj.attributes.source)
return "sel";
else
return "nml";
computeVol: function(stateObj) {
return stateObj.attributes.volume_level;
btntap11: function (ev) {
this.setSource('SIGAME', ev);
btntap12: function (ev) {
this.setSource('SISAT/CBL', ev);
btntap13: function (ev) {
this.setSource('SIMPLAY', ev);
btntap21: function (ev) {
this.setSource('Z2NET', ev);
btntap22: function (ev) {
this.setSource('Z2AUX1', ev);
setSource(src, ev) {
var serviceData = {source: src} || {};
this.hass.callService('shell_command', 'set_denon_source', serviceData);
ev.stopPropagation();
volChanged: function(ev) {
var serviceData = {zone: this.stateObj.entity_id.slice(-1), volume: ev.target.value} || {};
this.hass.callService('shell_command', 'set_denon_volume', serviceData);
stopPropagation: function (ev) {
</script>
Finally, configuration.yaml
switch:
- platform: denonxml
host: 192.168.1.136
port: 1
scan_interval: 5
host: 192.168.1.136
port: 2
scan_interval: 5
shell_command:
set_denon_volume: '/usr/bin/curl -X GET http://192.168.1.136/goform/formiPhoneAppVolume.xml?{{ zone }}+{{ volume | float - 80 }}'
set_denon_source: '/usr/bin/curl -X GET http://192.168.1.136/goform/formiPhoneAppDirect.xml?{{ source }}'
group:
denon:
entities:
- switch.denon_zone1
- switch.denon_zone2
customize:
switch.denon_zone1:
friendly_name: Living Room
icon: mdi:video
custom_ui_state_card: custom_source
switch.denon_zone2:
friendly_name: BedRoom
icon: mdi:volume-high
And you should get:
Cheers
Bit late reply but didn’t found time to do something with it but today I had and got the same card as you have now. Just need to customize it so it reflect my Denon config
i have 6 sonos, and my Homescreen looks very bad with this extremly large covers in HASS.IO . Want the old group behavior back, but wont downgrade to HA again
Hass.io and HA are the same HomeAssistant, only the operating system is different. So this is not a Hass.io thing.
I do like to see this feature however!
Yeah that’s a much nicer view, the new way just takes up too much room, especially on a mobile device.
Would love to see this return, Hate having my media players all over the place!
yes, me too…
Same here. The default page is pretty much cluttered up with my sonos devices
The old small media player layout would look much nicer imho.
Would be cool to have an option (in the customize.yaml?) to set the media player layout.
Agree. Seems to me that it would be possible to switch view based on yaml.
If you just want to save space, you can do so by removing the picture.
homeassistant:
customize:
media_player.living_room:
entity_picture: ''
Thank you very much for that tip!
But unfortunately media player can still not be added to group state cards with this trick.
And they still do not look as nice as with the old design imho
What is the goal? A state card with media control buttons? There is no such UI implemented.
A state card that shows the state of a player? Create a template sensor or a template switch.
I figured out a slight work around that works for me (buy may not for you). I can lean toward the minimalist side so I like to keep my main page in HA as slim as possible.
I have 5 chromecast devices around my home and I really only care about them if they are playing something. So I separated them all out into their own groups, added them to my main page and then run an automation to hide and un-hide them when they play things.
The Group:
plankton_main:
entities:
- media_player.plankton
The Automation:
# Plankton Visable
- alias: plankton visable true
platform: template
value_template: "{{ not is_state('media_player.plankton', 'off') }}"
service: group.set_visibility
entity_id: group.plankton_main
visible: True
- alias: plankton visable false
- platform: homeassistant
event: start
- platform: state
entity_id: media_player.plankton
to: 'off'
visible: False
My goal is the possibility to add media players to other state cards and show there actual status
(if possible with Album Covers/Images, like in the old way to show media players)
Sorry if this is maybe a stupid question, but I’m completly new to this templated sensor stuff.
Can you please give me a hint, what would be the correct code, if I just want the actual state (off, paused, playing…) from a media_player, as a templated sensor?
Thanks in advance for you help
I have now found a way that is quite ok for me. For a quick overview in the default_view, I created templated sensors that reflect the current state of the respective mediaplayer.
sensors:
sonos_wohnzimmer_state:
value_template: '{{ states("media_player.sonos_wohnzimmer") }}'
friendly_name: 'Sonos Wohnzimmer'
For a detailed view, I then created a separate view, in which I have moved all media player entities.
This is still not as nice, comfortable and informative as the old mediaplayer representation, but at least the default_view is no longer so cluttered.
BTW: Does anyone know how I can change the color of the templated sensors similar to that of lamps? (yellow if a media player is currently playing and grey for all other states).
Hi.
How did you put in the custom icon the the media-sensor like Chromecast? Normally i have no issues with this kind of changes, but my sensores jut won’t change - i just got an blank icon, if i define what kind of icon i would use.
Could you please share that part, too?
I did try with both customize and the icon_template, with no luck inspired of the home-assistant page:
media_state_tv:
value_template: '{{ states("media_player.samsung_tv_remote") }}'
icon_template: >
{% if is_state('media_player.samsung_tv_remote', 'on') %}
mdi:cast
{% elif is_state('media_player.samsung_tv_remote', 'unknown') %}
mdi:tv
{% else %}
mdi:tv
{% endif %}
And the customize (in one of my packages):
homeassistant:
customize:
sensor.media_state_tv:
friendly_name: “Tv”
icon: mid:television
The name is viewed just fine, but not the icon.
