Hi all
I try to set up a table to display my manually read meter values (gas, water, electricity). I got so far to use multiple custom:flex-table-card’s and select the entries from the todo lists (if anyone has a smarter solution I am open for it
In the description of the todo-list I past the regarding year so I am able to filter by it.
If I try to filter the entries via a input_text helper like
"{{ state('input_text.year') }}"
instead of “2024” I do not get displayed a single entry correct…
type: custom:flex-table-card
service: todo.get_items
entities:
- todo.zahler
columns:
- name: Datum
data: items
modify: if (x.description == "2024" ) {x.summary} else {'x'}
- name: Datum
data: items
modify: x.description
sort_by:
- items+
max_rows: 24
This is the current output:
Of course I normally set max_rows to 12 to “filter” only for the current year values
Does anyone has any suggestions?
If the you need the full card configuration just let me know, but it’s just similar to the one I pasted in a horizontal stack.
Many thanks in advance!
Provide what your source looks like
I did not find an option to get the yaml from the frontend so I took a screenshot:
The data in the list is from 01 - 2023 till 12 - 2024 as “item summary” and in the “description” I planned to write the year (you see some examples in the background).
input_text.jahr is a helper I created with the GUI.
My biggest issue (as long as there is not a much smarter way to do the whole thing at all) is that the following isn’t working:
modify: if (x.description == "{{ state('input_text.jahr') }}" ) {x.summary} else {'x'}
The state of input_text.jahr is 2024. I already checked this in the developer tools - states
For me it looks like it does not get it, that state(‘input_text.jahr’) = 2024 and therefore it occurs that all items gets marked as ‘x’…
I already tried:
'{{ state('input_text.jahr') }}'
Try 1) make results in the output picture i post with my next message (seems like I can only send one image per message), 2) and 3) cause that no output is displayed at all.
Thanks for your reply
Hope this was not to much information
Im using Home Assistant now for one month and still getting used to everything, but this is the first time I do not find a solution for days now.
Output for
entities:
- todo.zahler
columns:
- name: Datum
data: items
- name: description
data: items
sort_by:
- items+
is:
There are only a few cards that allow templating directly, I am quite (not 100%) sure that this card does not.
In that case you can use a wrapper card, this one I like myself
iantrich/config-template-card:
Templatable Lovelace Configurations (github.com)
Do you have any syntax suggestions? I am not getting any tries to work… I am about to use a conditional card and copy my card for every year and just display the one regarding to the choosen year in input_text.jahr, but this would be a very ugly workaround in my opinion
