Hi there,
I’m using the flex-table-card to display the departure times of the busses in my area.
I get the data via a rest sensor and let it fill its attributes:
- platform: rest
scan_interval: 60
value_template: '{{ value_json.locations[0].disassembledName }}'
json_attributes:
- stopEvents
resource: https://www.vrr.de/vrr-efa/XML_DM_REQUEST?calcOneDirection=0&coordOutputFormat=WGS84[dd.ddddd]&deleteAssignedStops_dm=1&depSequence=30&depType=stopEvents&doNotSearchForStops=1&genMaps=0&imparedOptionsActive=1&inclMOT_0=true&inclMOT_1=true&inclMOT_10=true&inclMOT_11=true&inclMOT_12=true&inclMOT_13=true&inclMOT_17=true&inclMOT_18=true&inclMOT_19=true&inclMOT_2=true&inclMOT_3=true&inclMOT_4=true&inclMOT_5=true&inclMOT_6=true&inclMOT_7=true&inclMOT_8=true&inclMOT_9=true&includeCompleteStopSeq=1&includedMeans=checkbox&itOptionsActive=1&itdDateDayMonthYear=23.10.2024&itdDateTimeDepArr=dep&itdTime=18:13&language=de&locationServerActive=1&maxTimeLoop=1&mode=direct&name_dm=de:05315:11201&outputFormat=rapidJSON&ptOptionsActive=1&serverInfo=1&sl3plusDMMacro=1&type_dm=any&useAllStops=1&useElevationData=1&useProxFootSearch=0&useRealtime=1&version=10.5.17.3&vrrDMMacro=1
Yesterday I was made aware, that there is now real-time data, which I want to use in my Dashboard. This is how far I’ve come:
type: custom:flex-table-card
style: |
ha-card {
font-size: 1em;
line-height: 2em;
.card-header {
text-align: center;
css:
td.left:nth-child(1): "text-align:center;width: 40px;"
td.left:nth-child(3): "text-align:center;width: 40px;"
th.left:nth-child(1): "text-align:center;width: 40px;"
th.left:nth-child(3): "text-align:center;width: 40px;"
entities:
include:
- sensor.abfahrtenbus2024
columns:
- data: stopEvents
modify: x.transportation.number
icon: mdi:bus
- data: stopEvents
modify: x.transportation.destination.name
- data: stopEvents
modify: x.departureTimePlanned
icon: mdi:clock
- data: stopEvents
modify: "{{x.departureTimeEstimated}}"
icon: mdi:bus
I can’t use any logic in the 4th coloum - for example showing the time difference between now() and the estimated departure time or only showing the departure time if it exists at all. (Sometimes this element is not part of the response json from the rest inquiry).
So I need your hive mind. Anybody got a guess?
You mean when it shows undefinedundefined…etc. ?
style: |
ha-card {
font-size: 1em;
line-height: 2em;
.card-header {
text-align: center;
css:
entities:
include:
columns:
- data: stopEvents
icon: mdi:bus
- data: stopEvents
- data: stopEvents
icon: mdi:clock
- data: stopEvents
modify: |
if (String(x.departureTimeEstimated).length < 10)
else
icon: mdi:clock
- data: stopEvents
modify: |-
else {
(Date.parse(String(x.departureTimeEstimated))-
Date.parse(String(x.departureTimePlanned))) /60000;}
icon: mdi:bus
Thank you!
This is the configuration I ultimately chose.
max_rows: 6
style: |
ha-card {
font-size: 1em;
line-height: 2em;
.card-header {
text-align: center;
css:
th.left:nth-child(4): "text-align:center;width: 40px;"
td.left:nth-child(4): "text-align:center;width: 40px;"
entities:
include:
columns:
- data: stopEvents
icon: mdi:bus
- data: stopEvents
icon: mdi:directions
- data: stopEvents
modify: |
{ String(x.departureTimePlanned).substr(11, 5) }
else
{String(x.departureTimeEstimated).substr(11, 5)}
icon: mdi:clock
- data: stopEvents
modify: |-
else {
icon: mdi:exclamation-thick
Hi @kirijanker
would you mind to share some more infos on how you get the data from vrr? I am looking for something similar for may area.
Thanks in advance
Sorry, I didn’t receive a notification earlier.
If you still have the question, here’s my workflow:
- Go to the vrr.de website and open the Web Inspection Tools (or Developer Tools) using F12.
- In the Developer Tools, navigate to the Network tab for network analysis.
- On the VRR site, select Abfahrtsmonitor and type in the bus stop you want to monitor. Click on the correct suggestion and keep an eye on the network tab in Developer Tools.
- Look for a POST request with a response labeled something like
XML_DM_REQUEST?...
. Select the most recent one.
- Copy the details of this request into a notepad.
- You can use this request in your REST sensor, as described earlier.
