I’m currently running Hass.io and I’ve setup a Flic button using Flicd and P. Schmitts Hassio Addons
It’s been running fine, but every now and then (i suspect after not using the button for some time), the Flic button disconnects. When i press the button, it flashes red twice which (according to this thead means it is disconnected).
After a reboot, the button works fine again.
Am I doing something wrong, or am i missing a setting, to keep the bluetooth connection alive between the button and my rpi3?
I came here with the same issue, saw the suggestion from DaKi and can confirm it worked for me too:
Disabling the discovery was what fixed it. I assume this isn’t intended to be left on all the time and may cause some issues with the bluetooth that only a full reboot will solve.
