Flic integration no longer loaded since 0.108
Any one running into this problem?
running hassio on Pi3, flicd add-on installed.
I reported an issue in guthub, but yet to heard.
Same thing here. I can start the add.on from the dashboard. but this just results in this log:
Available HCI devices found:
hci0
Trying hci0
hci0 is busy, shutting down and retrying…
Successfully bound HCI socket
Flic server is now up and running!
Initialization of Bluetooth controller done!
flicd: flicd.cpp:2741: void le_set_scan_enable_handler(uint8_t): Assertion `!status’ failed.
have you tried to rebind the buttons (press and hold the flic buton for 10 sec)?
What I found was sometimes after upgrade, the binding lost. That was what happened in this case for me.
