Flicd add on
Hi.
I have add the repository GitHub - pschmitt/home-assistant-addons: Home Assistant addons by pschmitt so I can use my Flic buttons with HA. It mentions in the setup
The flicd server needs a bluetooth controller. If you are running Hass.io based on HassOS, you can use the built-in controller. If you are running the older Hass.io based on ResinOS, you’ll need to install the Bluetooth BCM43xx add-on.
I have the HA yellow and thought it would have this built in. Does anyone have any idea?
Also, I have the Flic hub.
