Floating point precision problem with gas meter readout via hmc5883l
I’m trying to read out my Gasmeter via ESPHome and Home Assistant. At first I tried using a Reed Contact taking this as a starting point.
The problem, however, was that the display value of the physical meter and the calculated values were out of sync after about a day.
I blamed the reed contact and tried a different approach based on an HMC5883L and this guide
The problem, however, persisted. But now I was able to see continuous values from the HMC5883L, no signal loss, no spikes etc so I knew the readout was ok.
So I tried to debug this with Grafana. Below you see
  • the calculated display value from ESPHOME
  • the signal value of the HMC5883L sensor
  • the binary value “pulse” created from the HMC5883L sensor (see yaml below)
You see it works quite well until suddenly (where the ruler /mouse pointer is shown) the HMC5883L signal passes the “HIGH mark”, the binary value changes from 0 → 1 but the Gas meter display value is not incremented.
The ESP log itself shows that the increment has happend.
So my guess is this is a floating point precision problem. As far as I know there is no way to increase the precision with ESPHOME (to double or long) so I wonder what my options are to get this working correctly:
  1. set the initial display value (gv_gas_meter_displayinitial) from 16318.04 to 6318.04 and then somehow add 10000 in HomeAssistant again? (Short term solution, when the meter itself passes 20000 I need to ‘work around’ again…
  2. separate the values at the decimal point into two integers, e.g. INT1=16318 and INT2=04. Then I would need to find a way to “carry over” from INT2 to INT1 when going from 99 → 00 and find a way to combine the values in HomeAssistant again
  3. leave ESPHome and try a Raspberry PI Zero?
I’m really at a loss here how to proceed. Does anyone else already dealt floating point precision problems in ESPHome and can advise a solution?
Is any of my ideas how to circumvent the problem feasible?
Any help would be greatly appreciated!
Below my ESPHome Configuration, heavily inspired by @petsie and @cg089 :
substitutions:
  platform: ESP8266
  board: nodemcuv2
  device_name_short: "heesp18" # used by esp-home config
  friendly_name: "GasMeter:"
  device_description: "ESP8266 with GY-271 for magnetic readout of elster BK-G4 M"
  project_name: socrates.energy_monitor # format: author_name.project_name. Ref: https://esphome.io/components/esphome.html#esphome-creators-project
  update_interval_hmc5883l: 250ms
  main_cycle_interval: 500ms
  ip_address: 192.0.0.1
  impuls_factor: "0.01" # [m3] how much gas was measured during transition from low to high (one revelation of digit with magnet)
esp8266:
    board: ${board}
esphome:
  comment: ${device_description}
  build_path: ./build/${device_name_short}
  on_boot:
    then:
      - logger.log:
          level: info
          format: "BOOTMESSAGE:${device_name_short} API is connected, Device ready!"
      - globals.set:
          value: !lambda "return id(boot_counter)+=1;"
  on_shutdown:
    then:
      - logger.log: ${device_name_short} is down!
# (COMPONENT) LOG LEVEL OVERRIDE
logger:
  level: DEBUG
  logs:
    mqtt.component: DEBUG
    mqtt.client: ERROR
    sensor: INFO
    hmc5883l: INFO
# Base packages wifi, timeserver...
packages:
  base: !include common/base.yaml
  #base_webserver: !include common/base_webserver.yaml
  base_global: !include common/base_global.yaml
# Global variables
globals:
  - id: gv_gas_counter # gv_gas_counter (gas_impulse_counter)
    type: int
    restore_value: yes
    initial_value: "0"
  - id: gv_gas_counter_total # gv_gas_counter_total
    type: float
    restore_value: yes
    initial_value: "0.0"
  - id: gv_m3_to_kwh_factor # gv_m3_to_kwh_factor ( ggf. über service anpassbar?)
    type: float
    restore_value: yes
    initial_value: "10.94"
  - id: gv_gas_meter_displayinital # (initial value when recording began - used to recalculate values upon setting new displayvalue via service)
    type: float
    restore_value: yes
    initial_value: "16318.04"
  - id: gv_gas_meter_display_value # current calculated value on the gas meter device
    type: float
    restore_value: yes
  - id: gv_gas_meter_total_m3 # (gv_gas_meter_total_m3) total m3 recorded since startup of this device
    type: float
    restore_value: yes
  - id: gv_gas_impulse_high # boolean value set when uT > 50 and reset when uT < 0
    type: bool
    restore_value: no
    initial_value: 'false'
  - id: gv_gas_impulse_high_level_value # float value: level when magnetic field strength is considered HIGH
    type: float
    restore_value: yes
  - id: gv_gas_impulse_low_level_value # float value: level when magnetic field strength is considered !HIGH
    type: float
    restore_value: yes
    initial_value: "-50.0"
# Native API Component
#** This provides a service callable from HomeAssistant to re-set
#** or adjust the display value of the gasmeter. This should only
#** be neccessary if the ESP8266 was offline for maintenance.
api:
  port: 6053
  reboot_timeout: 5min
  services:
    - service: set_gasmeterdisplay
      variables:
        my_newdisplayvalue: float
      then:
        - logger.log:
            format: "Setting Gasmeter Display value: %.2f"
            args: [my_newdisplayvalue]
        - globals.set:
            value: !lambda "return (my_newdisplayvalue);"
        - globals.set:
        # - globals.set:
        #     id: gv_gas_meter_total_m3
        #     value: !lambda "return ((my_newdisplayvalue) - id(gv_gas_meter_displayinital));"
        # # - globals.set:
        #     id: gv_gas_counter
        #     value: !lambda "return ( ((my_newdisplayvalue) - id(gv_gas_meter_displayinital))/${impuls_factor} );"
        - logger.log:
            format: "Gasmeter Display value: %.2f"
            args: [id(gv_gas_meter_display_value)]
# Switch to restart, reset all, reset bootcounter
switch:
    name: ${friendly_name} reset all
    turn_on_action:
      then:
        - lambda: |-
            id(boot_counter) = 0;
            id(gv_gas_counter_total) = 0.0;
            id(gv_gas_counter) = 0;
            id(gv_gas_meter_total_m3)= 0.0;
            id(gv_gas_meter_display_value)= 0.0;
            id(daily_value)= 0.0;
            id(hourly_value)= 0.0;
            id(bootcounter).update();
            id(gas_meter_display).update();
            id(gas_meter_total_m3).update();
            id(gas_meter_total_kw).update();
            id(gas_meter_total_kw_day).update();
        - logger.log: ${device_name_short} all values reset!
# Setup of I2C HMC5883L GY-271 magnetic field measurement
i2c:
  sda: GPIO4
  scl: GPIO5
  scan: true
  frequency: 800kHz
# ALL SENSORS
  - platform: hmc5883l
    address: 0x1E
#    field_strength_x:
#      name: "HMC5883L Field Strength X"
#      id: hmc5883l_x
    field_strength_y:
      name: "HMC5883L Field Strength Y"
#    field_strength_z:
#      name: "HMC5883L Field Strength Z"
#      id: hmc5883l_z
#      heading:
#        name: "HMC5883L Heading"
    #oversampling: 1x
    oversampling: 4x
      #oversampling: 64x
    #range: 130uT
    range: 250uT
      #range: 800uT
    update_interval: ${update_interval_hmc5883l}
    name: ${friendly_name} DIC 0.01 m3 Impulse
    force_update: true
    accuracy_decimals: 0
    #unit_of_measurement: "m³"
    update_interval: 1s
    icon: "mdi:mdi-numeric-positive-1"
    #device_class: gas
    lambda: |-
      return id(gv_gas_impulse_high);
    name: ${friendly_name} Meter Display Counter
    force_update: true
    accuracy_decimals: 2
    icon: "mdi:counter"
    device_class: gas
    lambda: |-
      return id(gv_gas_meter_display_value);
    name: ${friendly_name} Acc. Gas Consumption This Day1
    state_class: measurement
    device_class: gas
    name: ${friendly_name} Registered Impulses Total
    lambda: |-
      return (id(gv_gas_counter));
    name: ${friendly_name} Acc. Gas Consumption Total
    accuracy_decimals: 1
    device_class: gas
    state_class: total_increasing
    lambda: |-
      return id(gv_gas_meter_total_m3);
    name: ${friendly_name} Acc. Gas Consumption Total This Day
    icon: mdi:gauge
    lambda: |-
      return (id(daily_value));
    name: ${friendly_name} Gas per hour
    icon: mdi:gauge
    lambda: |-
      return (id(hourly_value));
    name: ${friendly_name} Acc. Gas Energy Total
    device_class: energy
    unit_of_measurement: "kWh"
    lambda: |-
      return (id(gv_gas_meter_total_m3) * id(gv_m3_to_kwh_factor));
    name: ${friendly_name} Acc. Gas Energy Total This Day
    lambda: |-
      return (id(daily_value) * id(gv_m3_to_kwh_factor));
    name: ${friendly_name} Acc. Gas Energy Total This Hour
    lambda: |-
      return (id(hourly_value) * id(gv_m3_to_kwh_factor));
# INTERVAL - run PLC like every "cycle"
#** This component allows you to run actions at fixed time intervals.
#** For example if you want to toggle a switch every minute, you can
#** use this component. Please note that it’s possible to achieve the
#** same thing with the time.on_time trigger, but this technique is
#** more light-weight and user-friendly.
interval:
  - interval: ${main_cycle_interval}
    then:
    - lambda: |-
       if (id(hmc5883l_y).state >= id(gv_gas_impulse_high_level_value) && !id(gv_gas_impulse_high)) {
          ESP_LOGI("main", "----------------------------------------------------------------------------------------");
           ESP_LOGI("main", " *** Value Update ***");
           ESP_LOGD("mein", "       [gv_gas_counter_total] as found: %f", id(gv_gas_counter_total) );
           id(gv_gas_counter_total) += ${impuls_factor};
           ESP_LOGD("mein", "       [gv_gas_counter_total] as left : %f", id(gv_gas_counter_total) );
           ESP_LOGD("mein", "       [gv_gas_meter_display_value] as found: %f", id(gv_gas_meter_display_value) );
           id(gv_gas_meter_display_value) += ${impuls_factor};
           ESP_LOGD("mein", "       [gv_gas_meter_display_value] as left : %f", id(gv_gas_meter_display_value) );
           ESP_LOGD("mein", "       [gv_gas_meter_total_m3] as found: %f", id(gv_gas_meter_total_m3) );
           id(gv_gas_meter_total_m3) += ${impuls_factor};
           ESP_LOGD("mein", "       [gv_gas_meter_total_m3] as left : %f", id(gv_gas_meter_total_m3) );
           ESP_LOGD("mein", "       [daily_value] as found: %f", id(daily_value) );
           id(daily_value) += ${impuls_factor};
           ESP_LOGD("mein", "       [daily_value] as left : %f", id(daily_value) );
           id(hourly_value) += ${impuls_factor};
           id(gv_gas_counter) += 1;
           id(gv_gas_impulse_high) = true;
           id(gas_meter_m3_today).publish_state(${impuls_factor});
        } else if (id(hmc5883l_y).state <= id(gv_gas_impulse_low_level_value) && id(gv_gas_impulse_high)) {
          id(gv_gas_impulse_high) = false;
Hey, I’m trying the exact same thing with my gas meter and a HMC5883l. Was running this combo with Python on a Raspberry Pi for last few years with very high precision and nearly no drift. The code from Gaszähler auslesen mit Magnetometer HMC5883 und Raspberry Pi
Now after setting up Homeassistant I would include my gas meter with ESPHome. But the counter is way off after just one day. I added logging today and after googling for Float Precision I landed here on your post.
Here is my log from the last few minutes
Time	level	Tag	Message
22:53:18	[I]	[interval:072]	gas_counter_total1: 45545.613281
22:53:18	[I]	[interval:074]	gas_counter_total2: 45545.625000
22:53:40	[I]	[interval:078]	gas_low
22:53:40	[I]	[interval:081]	----
22:55:10	[I]	[interval:071]	gas_high
22:55:10	[I]	[interval:072]	gas_counter_total1: 45545.625000
22:55:10	[I]	[interval:074]	gas_counter_total2: 45545.636719
22:55:30	[I]	[interval:078]	gas_low
22:55:30	[I]	[interval:081]	----
22:57:03	[I]	[interval:071]	gas_high
22:57:03	[I]	[interval:072]	gas_counter_total1: 45545.636719
22:57:03	[I]	[interval:074]	gas_counter_total2: 45545.648438
22:57:25	[I]	[interval:078]	gas_low
22:57:25	[I]	[interval:081]	----
22:58:55	[I]	[interval:071]	gas_high
22:58:55	[I]	[interval:072]	gas_counter_total1: 45545.648438
22:58:56	[I]	[interval:074]	gas_counter_total2: 45545.660156
22:59:15	[I]	[interval:078]	gas_low
22:59:15	[I]	[interval:081]	----
23:00:45	[I]	[interval:071]	gas_high
23:00:45	[I]	[interval:072]	gas_counter_total1: 45545.660156
23:00:45	[I]	[interval:074]	gas_counter_total2: 45545.671875
23:01:08	[I]	[interval:078]	gas_low
23:01:08	[I]	[interval:081]	----
23:02:38	[I]	[interval:071]	gas_high
23:02:38	[I]	[interval:072]	gas_counter_total1: 45545.671875
23:02:38	[I]	[interval:074]	gas_counter_total2: 45545.683594
23:03:00	[I]	[interval:078]	gas_low
23:03:00	[I]	[interval:081]	----
23:04:30	[I]	[interval:071]	gas_high
23:04:30	[I]	[interval:072]	gas_counter_total1: 45545.683594
23:04:30	[I]	[interval:074]	gas_counter_total2: 45545.695312
23:04:50	[I]	[interval:078]	gas_low
23:04:50	[I]	[interval:081]	----
23:06:20	[I]	[interval:071]	gas_high
23:06:20	[I]	[interval:072]	gas_counter_total1: 45545.695312
23:06:20	[I]	[interval:074]	gas_counter_total2: 45545.707031
23:06:43	[I]	[interval:078]	gas_low
23:06:43	[I]	[interval:081]	----
23:08:13	[I]	[interval:071]	gas_high
23:08:13	[I]	[interval:072]	gas_counter_total1: 45545.707031
23:08:13	[I]	[interval:074]	gas_counter_total2: 45545.718750
23:08:35	[I]	[interval:078]	gas_low
23:08:35	[I]	[interval:081]	----
23:10:05	[I]	[interval:071]	gas_high
23:10:05	[I]	[interval:072]	gas_counter_total1: 45545.718750
23:10:05	[I]	[interval:074]	gas_counter_total2: 45545.730469
23:10:25	[I]	[interval:078]	gas_low
23:10:25	[I]	[interval:081]	----
esphome:
esp8266:
  board: esp01_1m
  restore_from_flash: true
# Enable logging
logger:
  level: INFO
#preferences:
#  flash_write_interval: 1min
# Enable Home Assistant API
api:
  encryption:
    key: ""
ota:
  password: ""
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Gasmeter Fallback Hotspot"
    password: ""
captive_portal:
substitutions:
  friendly_name: "Gas"
i2c:
  sda: GPIO0
  scl: GPIO2
  scan: true
globals:
  - id: gas_counter_total
    type: float
    restore_value: yes
  - id: gas_high
    type: bool
    restore_value: no
    initial_value: 'true'
interval:
  - interval: 2500ms
    then:
    - lambda: |-
       if (id(hmc5883ly).state >= 200 && !id(gas_high)) {
          ESP_LOGI("interval", "gas_high");
          ESP_LOGI("interval", "gas_counter_total1: %f", id(gas_counter_total));
          id(gas_counter_total) += 0.01;
          ESP_LOGI("interval", "gas_counter_total2: %f", id(gas_counter_total));
          id(gas_high) = true;
          id(led).turn_on();
        } else if (id(hmc5883ly).state <= 100 && id(gas_high)) {
          ESP_LOGI("interval", "gas_low");
          id(gas_high) = false;
          id(led).turn_off();
          ESP_LOGI("interval", "----");
web_server:
  port: 80
number:
    name: "${friendly_name} Actual Meter Reading"
    optimistic: True
    min_value: 0
    max_value: 99999.99
    step: 0.01
    entity_category: config
    mode: box
    icon: 'mdi:counter'
    set_action:
      then:
        - lambda: |-
            ESP_LOGI("num_temp", "Value of gct befor %f", id(gas_counter_total));
            ESP_LOGI("num_temp", "Value to set %f", x);
            id(gas_counter_total) = x ;
            ESP_LOGI("num_temp", "Value of gct after %f", id(gas_counter_total));
  - platform: wifi_signal
    name: "${friendly_name} WiFi Signal"
    update_interval: 60s
    entity_category: diagnostic
  - platform: uptime
    on_raw_value:
      then:
        - text_sensor.template.publish:
            state: !lambda |-
              int seconds = round(id(uptime_sensor).raw_state);
              int days = seconds / (24 * 3600);
              seconds = seconds % (24 * 3600);
              int hours = seconds / 3600;
              seconds = seconds % 3600;
              int minutes = seconds /  60;
              seconds = seconds % 60;
              return (
                (days ? to_string(days) + "d " : "") +
                (hours ? to_string(hours) + "h " : "") +
                (minutes ? to_string(minutes) + "m " : "") +
                (to_string(seconds) + "s")
              ).c_str();
#    address: 0x68
    field_strength_x:
      name: "${friendly_name} HMC5883L X"
    field_strength_y:
      name: "${friendly_name} HMC5883L Y"
    field_strength_z:
      name: "${friendly_name} HMC5883L Z"
    range: 250uT
    oversampling: 8
    update_interval: 1s
    lambda: |-
      return id(gas_counter_total);
    update_interval: 5s
    icon: 'mdi:fire'
    device_class: gas
    name: "${friendly_name} Gesamt kWh"
    # Gasvolumen in m³ x Zustandszahl x Brennwert = Gasverbrauch in kWh
    # Zustandszahl: ?
    # Brennwert: ?
    # aktueller Wert aus letzter Rechnung Octopus 19.05.2022 10,086
    filters:
    lambda: |-
      return (id(gas_counter_total) * (10.086));
    update_interval: 5s
    icon: 'mdi:fire'
text_sensor:
    name: "${friendly_name} Uptime Human Readable"
    icon: mdi:clock-start
# Optional: Diese LED soll blinken, sobald ein Signal vom Gaszähler erkannt wird
output:
  - platform: gpio
    pin: GPIO1
As you can see I use float for the counter and increment by 0.01 but in the log you see it is always a little bit more or less what is added to the counter.
Have you managed to get this problem fixed? I’m thinking about some sort of offset calculation. Count with an integer, increment by one and divide just once before the output by 100 to get the 2 digits value.
Hi there,
sorry for the late reply.
But you are right on track with your workaround. This is exactly what needs to be done.
relevant configuration parts from my config (just for reference):
# Testing float to integers <WHOLE>.<REMAINDER>
  - id: gv_gas_meter_display_value_integer_part
    type: int
    restore_value: yes
    initial_value: "16319"
  - id: gv_gas_meter_display_value_fraction_part
    type: int
    restore_value: yes
    initial_value: "46"
# This value is reported to HomeAssistant
    force_update: true
    icon: "mdi:counter"
    device_class: gas
    lambda: |-
      return ( id(gv_gas_meter_display_value_integer_part) + (id(gv_gas_meter_display_value_fraction_part)*0.01) );
interval:
    then:
    - lambda: |-
       if (id(hmc5883l_z).state <= ${zero_crossing_value} && !id(gv_gas_impulse_high)) {
           //ESP_LOGD("main", "       [gv_gas_counter_total] as found: %f", id(gv_gas_counter_total) );
           //id(gv_gas_counter_total) += ${impuls_factor};
           //ESP_LOGD("main", "       [gv_gas_counter_total] as left : %f", id(gv_gas_counter_total) );
           ESP_LOGD("main", "       [gv_gas_meter_display_value_float] as found: %f", id(gv_gas_meter_display_value_float) );
           id(gv_gas_meter_display_value_float) += ${impuls_factor};
           ESP_LOGD("main", "       [gv_gas_meter_display_value_float] as left : %f", id(gv_gas_meter_display_value_float) );
           ESP_LOGD("main", "       [gv_gas_meter_total_m3] as found: %f", id(gv_gas_meter_total_m3) );
           ESP_LOGD("main", "       [gv_gas_meter_total_m3] as left : %f", id(gv_gas_meter_total_m3) );
           ESP_LOGD("main", "       [daily_value] as found: %f", id(daily_value) );
           ESP_LOGD("main", "       [daily_value] as left : %f", id(daily_value) );
           // Test with two integers as <WholePartInt>.<RemainderInt>
           ESP_LOGD("main", "       [gv_gas_meter_display_value_fraction_part] as found: %i", id(gv_gas_meter_display_value_fraction_part) );
           id(gv_gas_meter_display_value_fraction_part) +=1;
           ESP_LOGD("main", "       [gv_gas_meter_display_value_fraction_part] as left : %i", id(gv_gas_meter_display_value_fraction_part) );
           ESP_LOGD("main", "       [gv_gas_meter_display_value_integer_part] as found: %i", id(gv_gas_meter_display_value_integer_part) );
           if (id(gv_gas_meter_display_value_fraction_part) >= 100) {
             ESP_LOGD("main", " *** CARRY OVER DETECTED ... compensating...");
             id(gv_gas_meter_display_value_integer_part) +=1;
             id(gv_gas_meter_display_value_fraction_part) = id(gv_gas_meter_display_value_fraction_part) - 100;
             ESP_LOGD("main", "       [gv_gas_meter_display_value_integer_part] as left : %i", id(gv_gas_meter_display_value_integer_part) );
           id(gas_meter_display_integer).update();
Hope this helps :slight_smile:
Hey, thank you very much for the reply. I managed to get my gasmeter running with integer counting. And it is rock solid for the ~3 days now. I just count with integers and calculate the floating point only once. I also managed to get an input field in the webserver to set the actual reading whenever needed.
Here’s my code:
esphome:
esp8266:
  board: d1_mini
# Enable logging
logger:
  level: INFO
preferences:
api:
  encryption:
    key: "kZenN+1T6/LU9AEwUEG2hzp2OCHmjwtK2brsk15Zv/o="
ota:
  password: "0a8f2df9223b98114d914b425376edea"
wifi:
  ap:
    password: "8ero5LJdrhQ4"
captive_portal:
substitutions:
i2c:
  scan: true
globals:
    type: int
    initial_value: '4554851'
    restore_value: yes
  - id: gas_high
    type: bool
    restore_value: no
interval:
  - interval: 2500ms
    then:
    - lambda: |-
          ESP_LOGD("interval", "gas_high");
          ESP_LOGD("interval", "gas_counter_total1: %d", id(gas_counter_total));
          id(gas_counter_total) += 1;
          ESP_LOGD("interval", "gas_counter_total2: %d", id(gas_counter_total));
          id(led).turn_on();
          ESP_LOGD("interval", "gas_low");
          id(led).turn_off();
          ESP_LOGD("interval", "----");
web_server:
  port: 80
number:
    name: "${friendly_name} Set Meter Reading"
    optimistic: True
    min_value: 0
    max_value: 99999.99
    step: 0.01
    mode: box
    icon: 'mdi:counter'
    set_action:
      then:
        - lambda: |-
            ESP_LOGD("num_temp", "Value of gct before %d", id(gas_counter_total));
            ESP_LOGD("num_temp", "Value to set float %f", x);
            int d;
            d = floor(x*100);
            ESP_LOGD("num_temp", "Value to set int %d", d);
            id(gas_counter_total) = d ;
            ESP_LOGD("num_temp", "Value of gct after %d", id(gas_counter_total));
    filters:
      - sliding_window_moving_average:
          window_size: 6
          send_every: 6
  - platform: uptime
    on_raw_value:
      then:
            state: !lambda |-
              return (
              ).c_str();
#    address: 0x68
#    field_strength_x:
#      name: "${friendly_name} HMC5883L X"
#      id: hmc5883lx
    field_strength_y:
#    field_strength_z:
#      name: "${friendly_name} HMC5883L Z"
#      id: hmc5883lz
    range: 250uT
    oversampling: 8
    update_interval: 1s
    name: "${friendly_name} Gesamt m³"
    lambda: |-
      return ((float)id(gas_counter_total) / (float)100);
    update_interval: 5s
    icon: 'mdi:fire'
    device_class: gas
    # Zustandszahl: ? Brennwert: ?
    filters:
    lambda: |-
      return ((float)id(gas_counter_total) / (float)100 * (10.086));
    update_interval: 5s
    icon: 'mdi:fire'
text_sensor:
light:
  - platform: status_led
    pin: D5
Hope someone will find this helpful
