I manged to get my Flourean thermostat communicating with MQTT.
These are my notes when I instated it hope it helps someone.
Install Ubuntu on vmware workstation
install python2.7 sudo apt-get install python2.7
install setuptools sudo apt-get install python-setuptools
install git sudo apt-get install git-core
cd /usr/local/lib/python2.7/
sudo mkdir broadlink
cd /usr/local/lib/python2.7/broadlink
sudo git clone git://github.com/ptd006/python-broadlink
cd /usr/local/lib/python2.7/broadlink/python-broadlink
sudo python2.7 setup.py install
cd …
sudo git clone git://github.com/ralphm2004/broadlink-thermostat
sudo easy_install pip
sudo pip install paho-mqtt
sudo python2.7 setup.py install ( this seemed to fail but I cattied on anyway)
cd /usr/local/lib/python2.7/broadlink/broadlink-thermostat
sudo nano broadlink-thermostat.conf (change details for your MQTT server)
sudo python2.7 /usr/local/lib/python2.7/broadlink/broadlink-thermostat/broadlink-thermostat.py
Would not start so ran sudo pip install broadlink
broadlink discover
found: 192.168.5.110 cf407XXea34
PID child 887
Hysen heating controller
set time 5:29:38 5
cf40703XXa34 room_temp 21.0
cf4
Hi sorry for my english.
I try to connect with my BEOK BOT-313W in hassbian (hassbian have venv python) i exec this code:
sudo systemctl stop [email protected]
sudo su -s /bin/bash homeassistant
source /srv/homeassistant/bin/activate
mkdir repos
cd repos
git clone https://github.com/ptd006/python-broadlink.git
python setup.py install
git clone https://github.com/ralphm2004/broadlink-thermostat.git
–Install mosquito
sudo hassbian-config install mosquitto
sudo systemctl start mosquitto.service
–Update apt-get
sudo apt-get update
–Install PIP
sudo apt-get install python-pip
edit broadlink-thermostat.conf with mosquito access data
python2.7 broadlink-thermostat.py
i receive “broadlink discover” and nothing more
What can i do
Thnks
Now i solved my problem.
In the configuration of my BEOK BOT-313W there are one option “Sensor mode setting” and when i click in “Out-s control” or “in-s and out-s control” i solved my problem and receive ip and temperature of the room.
Thnks
I change configuration.yaml with this value:
Work fine!
climate:
platform: mqtt
modes:
- ‘0’
- ‘1’
current_temperature_topic: /broadlink/43df7534ea34/room_temp
#target_temp_step: 0.5
temperature_command_topic: /broadlink/43df7534ea34/cmd/set_temp
temperature_state_topic: /broadlink/43df7534ea34/thermostat_temp
mode_command_topic: /broadlink/43df7534ea34/cmd/set_mode
mode_state_topic: /broadlink/43df7534ea34/auto_mode
power_command_topic: /broadlink/43df7534ea34/cmd/set_power
power_state_topic: /broadlink/43df7534ea34/power
payload_on: ‘1’
payload_off: ‘0’
Hi
I am trying to use script to set a schedule problem is it wont accept the payload.
whats the best way to get round this, it seems to stop on the"quotes"
script:
mqtt_but3:
alias: Weekend
sequence:
service: mqtt.publish
topic: “/broadlink/cf4070xxxx34/cmd/set_schedule”
payload: “’[[{“start_hour”: 6, “temp”: 22.5, “start_minute”: 0}, {“start_hour”: 6, “temp”: 15.0, “start_minute”: 55}, {“start_hour”: 11, “temp”: 15.0, “start_minute”: 30}, {“start_hour”: 17, “temp”: 22.0, “start_minute”: 30}, {“start_hour”: 20, “temp”: 23.0, “start_minute”: 0}, {“start_hour”: 23, “temp”: 15.0, “start_minute”: 10}], [{“start_hour”: 8, “temp”: 22.0, “start_minute”: 0}, {“start_hour”: 23, “temp”: 15.0, “start_minute”: 0}]]’”
sorted it , needed to use data_template and payload_template
mqtt_but4:
alias: WeekDay
sequence:
data_template:
payload_template: ‘[[{“start_hour”: 6, “temp”: 22.5, “start_minute”: 0}, {“start_hour”: 6, “temp”: 15.0, “start_minute”: 55}, {“start_hour”: 11, “temp”: 15.0, “start_minute”: 30}, {“start_hour”: 18, “temp”: 22.0, “start_minute”: 30}, {“start_hour”: 20, “temp”: 23.0, “start_minute”: 0}, {“start_hour”: 23, “temp”: 15.0, “start_minute”: 10}], [{“start_hour”: 8, “temp”: 22.0, “start_minute”: 0}, {“start_hour”: 23, “temp”: 15.0, “start_minute”: 0}]]’
when the thermostat is heating and you see the 3 vertical waves icon on your thermostat indicating it is heating, this is the mode, either 0 or 1, I presume, but this state is not send to home assistant, does this work for you?
if so how did you make this work?
I only always see a 0 before the temperature in hass, the 0 never changes, even when the thermostat is heating.
The mode 0 indicate manual mode and 1 indicate auto mode, used in this commands :
The 3 vertical waves icon i presume “on” when room_temp is less than set_temp, in history graph you can see it.
But I think no exits any state for 3 vertical waves
You can look all states in https://github.com/ralphm2004/broadlink-thermostat
/broadlink/xxxxxx34ea34/dayofweek 1
/broadlink/xxxxxx34ea34/remote_lock 0
/broadlink/xxxxxx34ea34/osv 42
/broadlink/xxxxxx34ea34/sec 36
/broadlink/xxxxxx34ea34/external_temp 0.0
/broadlink/xxxxxx34ea34/fre 0
/broadlink/xxxxxx34ea34/min 56
/broadlink/xxxxxx34ea34/unknown 0
/broadlink/xxxxxx34ea34/sensor 0
/broadlink/xxxxxx34ea34/loop_mode 1
/broadlink/xxxxxx34ea34/room_temp 14.5
/broadlink/xxxxxx34ea34/power 1
/broadlink/xxxxxx34ea34/thermostat_temp 5.0
/broadlink/xxxxxx34ea34/temp_manual 0
/broadlink/xxxxxx34ea34/room_temp_adj 0.0
/broadlink/xxxxxx34ea34/active 0
/broadlink/xxxxxx34ea34/poweron 0
/broadlink/xxxxxx34ea34/auto_mode 0
/broadlink/xxxxxx34ea34/svl 5
/broadlink/xxxxxx34ea34/hour 22
/broadlink/xxxxxx34ea34/svh 35
/broadlink/xxxxxx34ea34/dif 2
/broadlink/xxxxxx34ea34/schedule
thanks for this usefull info…
I think the:
is the state if it is heating or not…
but I don’t see how to get that state in relation to the climate mqtt component in hass?
does anyone know how to get this state with mqtt?
Duh, if you change:
mode_command_topic: /broadlink/xxxxxx34ea34/set_mode
to:
in your climate.yaml you will get the state if the thermostat is heating or not, now you can send messages whenever the thermostat is heating, exactly like I wanted
now it must also be possible somehow to display a flame icon or not in front of the temperature on the hass frontend whenever the thermostat is heating… because the 0 changes to 1 when the thermostat is heating.
I think you can use a sensor tag, something like this:
platform: mqtt
state_topic: ‘/broadlink/43df7534ea34/active’
payload_available: ‘1’
payload_not_available: ‘0’
You can do automations to the sensor states and you can see history of the sensor.
I use too, two switch for power and auto/manual mode:
switch:
platform: mqtt
payload_on: ‘1’
payload_off: ‘0’
platform: mqtt
payload_on: ‘1’
payload_off: ‘0’
And the climate tag like this:
climate:
platform: mqtt
modes:
- ‘0’
- ‘1’
payload_on: ‘1’
payload_off: ‘0’
Alloc186
(Petr T )
May 31, 2018, 8:40am
34
Hi there, could anybody just write me step by step guide how to connect and set my thermostat with home assistant? I completely noob in this, just bought Raspberry Pi 3 yesterday, flash it and now I can access configutation.yaml from windows 10, but thats all. I tried add MQTT component, but I dont know how to set it up. My wifi thermostat (BEOK TDS21-EP) is working well with default mobile APP. I can see its MAC adress and IP adress from my router…
I would like to achive automatiation something like turn off the thermostat when I leave home.
So I’ve wrote a beta custom_component for Hassio to drive these thermostats
All,
Attached is a beta of a climate control for the Hysen thermostats powered by broadlink, feel free to test and enhance take as needed.
I’ve included the config I have set up to get it working in hassio.
The heating state are off/heat/auto, due to the manual state not working with Alexa, also Alexa reports the device is not responding but it does (bug is hassio I think).
[Capture1]
[Capture2]
RENAME broadlinkHysen.py
broadlinkHysen.yaml (16.3 KB)
PUT broadlinkHysen.py in your costom_…
Sorin_Paun
(Sorin Paun)
November 10, 2018, 2:59pm
36
Hi
Im looking for a thermostat ** using DRY CONTACT 220v, position NORMALLY OPEN (
TODAY I have this simple one - see at the end model 54183
https://manualzz.com/doc/17362948/flash-54186--36-640-75-
I would like to replace with one like the one discussed above
See at the end of the pagem model GA with N wire in sockets 2 AND 3.
ANY EPERIENCE uin using these models “GA” with N wire on sockets 2 AND 3 ?
Merci
Svellem
(Svellem)
November 10, 2018, 6:50pm
37
@Sorin_Paun I tried Ine of these. I never got to change the IP adress / assign IP from dhcp and thus abandonded testing with the script.
thallaa
(Tero)
December 13, 2018, 8:35pm
38
Is there a list of compatible thermostats somewhere?
Aliexpress and eBay are full of wifi thermostats and it is rather difficult to figure out which one to buy.
Now I use this component, work fine for my beok 313:
Hi again!
I’m trying to call the climate.broadlink_set_advanced_conf service from the dev service tool but it always gives an error calling service on the bottom left part of the browser. Nothing in the logs.
This is the json i’m using:
“loop_mode”: 0, “osv”: 42, “dif”: 2, “svh”: 30, “svl”: 10, “freeze”: 1, “adj”: 1.0, “pon”: 1,“sen”: 0
I’ve also tried adding “entity_id” with the same result. Same when trying to use climate.broadlink_set_schedule service.
Any hint on what I’m doing wr…
for your information
https://raw.githubusercontent.com/home-assistant/home-assistant/fe3606bbb8fa94cc7f910b1071a110efbb1c2b86/homeassistant/components/climate/broadlink.py
i use this broadlink.py in custom_components folder
Hi, i too would like to get my Beok 313 working,
from what you say about Wifi thermostat (Beok, Floureon, Beca Energy) component
i assume we have to follow this to get our API key sniffed from the device if it’s not on a label on the side of it?
nylund
(Nicklas Nylund)
February 14, 2022, 1:08pm
41
I’m searching for a wifi floor heating thermostat replacing our old but I do not want to change the sensor. I suspect it is stuck in the floor. Our current sensor is 100kohm at 25 degree C and I think standard is 10kohm today for most sensors. However I have seen that some thermostats can be adjusted for different sensors.
Do you know of any (cheap) wifi thermostat with support for 100kohm sensor that can be controlled by Home Assistant?
