Floor3D Pro Card – Game Engine Backbone Edition
HACS Default License MIT Version Downloads
:megaphone: Temporary Notice – Cards Unavailable (RESOLVED)
My GitHub account was unexpectedly suspended, which makes all my HACS cards — ClockPro Card, Floor3DPro Card, and OverlayPro Card — temporarily unavailable. Nothing has been deleted; access is simply blocked.
This may have been triggered by a sudden spike in users and download activity on my cards, which can sometimes activate GitHub’s automated security filters. I contacted GitHub Support, and after a manual review, all restrictions were fully lifted. No policy violations were found.
Everything is now accessible again.
Thank you for your understanding and support.
Your Home Digital Twin for Home Assistant (3D Lovelace Card)
:link: Floor3D Pro Card (source & documentation):
Original concept and vision: floor3d-card by @andyHA – with full respect and acknowledgment of the foundational work.
:link: Original card (source & documentation):
https://github.com/adizanni/floor3d-card
:warning: Important:
This is not a feature expansion of the original Project.
For feature requests or development inquiries, please contact the original author.
Context
The original floor3d-card works exceptionally well and introduced a powerful idea: a true digital twin inside Home Assistant.
However, as models grow large and entity counts increase, natural performance and lifecycle limits emerge — not due to poor design, but because UI‑driven architectures do not scale like engines.
This Project focuses on scaling and stabilization, not on rewriting the core idea.
Overview
Floor3D Pro Card is a Lovelace card for Home Assistant that enables the creation of a 3D digital twin of a home based on its physical structure, Providing an interactive 3D floor plan. The card represents device and sensor data from Home Assistant through a three-dimensional home model in a visual and interactive manner.
  • The card associates Home Assistant entities such as lights, switches, doors, windows, shutters, and sensors with objects within the 3D model, allowing the current state of the home to be observed within a single scene.
  • For example, when a room light is turned on, the corresponding area is illuminated in the model; door, window, and shutter objects visually reflect their open–close states, while sensors display their associated states directly within the scene.
Floor3D Pro Card, unlike apProaches based on 2D images or image-based floor plans, builds the scene using real 3D geometry.
This allows the entire home to be monitored and interactively managed through a single 3D scene, particularly in large or multi-story environments.
Technically, the card uses a home model created with 3D modeling tools such as Sweet Home 3D, Rhino, 3ds Max, Blender, SketchUp, and similar software, exported in obj or glb format.
The model is uploaded to Home Assistant and defined through the card configuration.
The 3D scene is generated using a JavaScript-based 3D rendering infrastructure and is synchronized with Home Assistant entity states in real time.
Project Vision
Floor3D Pro Card is part of a future 3-module ecosystem:
  • Floor3D Pro Card → 3D Scene Engine
  • Overlay Pro Card → UI Overlay Engine
  • Scene3D → Full Interactive 3D Dashboard Platform
Built on a Real Game-Engine Backbone
Release 1.5.3-Pro.Faz.0
Shaped by architectural discipline — not just code.
Not a game engine, but engineered to behave like one.
This card implements a deterministic game-engine architecture for both rendering and asset management.
Determinism as the Primary Goal
This isn’t a performance hack — it’s determinism as a foundation.
Deterministic rendering. Deterministic assets. Isolated instances. Stable behavior.
Deterministic Render Scheduler
Floor3D Pro routes every render trigger through a single, predictable scheduler.
This ensures 100 triggers result in only 1 render, eliminating jitter, lag, and random redraws for a consistently smooth experience on any device.
Deterministic Asset Backbone
All models load once, and each card receives its own isolated clone.
This prevents duplicate fetches, parse storms, and UI‑driven chaos, delivering a stable and efficient asset pipeline that behaves like a real game engine.
Deterministic Transactional Editor
All edits stay in a draft state until you intentionally commit them.
This removes rebuild storms, preview resets, and accidental refresh loops, resulting in a clean, predictable editing workflow even in large, complex setups.
Deterministic Engine Core Overview
Detailed explanation in ENGINE.md
Deterministic Correction: (Fix)
Repairs the original behavior through a clean, deterministic game‑engine backbone..
  • Overlay is display‑only — must not block clicks on level/zoom controls
  • Touchstart listener marked passive — prevents scroll‑blocking violations
  • Canvas obscurity logic corrected — animation stops only when a real dialog/overlay is present, not when root containers appear
  • Edit-Card preview guard added — unsafe DOM traversal no longer crashes the card
  • Raycasting concat pressure eliminated — deterministic rebuild without array growth
  • Cover/Index alignment restored — _states and _position now map deterministically, including valid 0 positions
  • Editor lifecycle guard added — early render() calls no longer risk undefined-access crashes
  • Edit‑Card fallback template enabled — hostile lifecycle states no longer break the editor
  • DOM custom‑element isolation added — original and Pro cards can run side‑by‑side without conflict.
  • Layout‑timing gap stabilized — model_loaded events could fire while the parent size was still 0×0; rendering is now deferred until valid layout dimensions exist, preventing first‑frame stretch and aspect‑ratio artifacts
Additional Pro Features
Release 1.5.3-Pro.Faz.1
Activation (All Pro features are opt-in and disabled by default.)
Engine Diagnostics (optional)
Pro_log: engine
Feature Skills (optional)
Pro_skill: [level, editor, mobile]
Enables selected Pro skill modules.
  • level → Pro Skill: level keeps entity‑heavy multi‑floor models fast and responsive
  • editor → Pro Skill: editor stable editing without auto‑commit chaos
  • mobile → Pro Skill: mobile smoother experience on tablets/phones
You can enable one or multiple skills:
Pro_skill: level
or
Pro_skill: [level, editor]
To disable all skills (default):
Pro_skill: []
Engine Behavior Tracing
Optional detailed logging for debugging engine behavior.
Allows tracing render scheduling, asset cache and lifecycle decisions without polluting normal logs.
Activation (This feature is opt-in and disabled by default.)
Pro_log: engine
LEVEL-Based Entity Filtering Pro Skill: level
Release 1.5.3-Pro.Faz.1.A
The level skill adds a performance‑focused execution filter for entity‑heavy multi‑floor models.
Each entity defines its level in the YAML configuration, where -1 entities are always active (security, climate, exterior lights, alarms, etc.) and never paused.
All other entities activate only when their YAML‑defined level matches the highest visible floor; non‑matching levels become inactive to reduce update and render load.
Inactive entities stop receiving HA updates, are skipped in render/update cycles, and ignore interactions and service calls, improving responsiveness on large setups without changing what is visually shown.
Pro_skill: level
Usage
# Always-active entity (security, exterior, climate, etc.)
- entity: <your_entity>
  object_id: <your_object_id>
  level: -1   # always active, never paused
# Floor-specific entity (active only when this floor is visible)
  level: 3    # active only when floor 3 is the highest visible level
EDITOR‑User Driven Cycle Pro Skill: editor
Release: 1.5.3‑Pro.Faz.1.B
The editor skill replaces Home Assistant’s auto‑saving behavior with a deterministic manual‑commit editing model.
It changes how edits are applied — not what can be edited — and affects only the visual editor UI (not YAML).
When enabled, all edits stay local:
no auto‑commit, no preview‑triggered commits, no lifecycle commits, no debounce, no background updates, no config-changed spam.
Editing becomes free, but applying changes becomes intentional.
A dedicated Commit Changes button appears and becomes the only valid way to save configuration updates.
One click = one deterministic commit, enforcing a clean draft → commit → apply workflow.
This prevents preview rebuild storms, model reload loops, editor flicker, accidental partial saves, and keeps editing responsive on weaker devices.
All changes remain local until manually committed.
Pro_skill: editor
Mobile-Optimized Runtime Profile Pro Skill: mobile
Release: 1.5.3‑Pro.Faz.1.C
The mobile skill enables a dedicated renderer profile optimized for tablets, phones, and other low‑power devices.
It does not change the UI; it simply activates a lighter, deterministic render‑cost tier that improves smoothness, responsiveness, thermal balance, and stability on heavy models.
When enabled, the renderer switches to mobile‑friendly settings:
  • Pixel ratio clamp → forces pixelRatio = 1 to reduce GPU load
  • Shadow tier reduction → uses BasicShadowMap instead of PCF soft shadows
  • Antialias control → disables expensive multisample antialiasing
These adjustments apply only to rendering.
Mobile mode does not modify entity logic, interactions, editor behavior, UI layout, or logging features.
Desktop behavior remains unchanged when the skill is disabled.
Pro_skill: mobile
From this point onward, the content is sourced from the original floor3d-card by @andyHA and has been adapted, condensed, and reformatted for this documentation.
3D Model Preparation
Recommended Workflow (Easy Method)
  • Sweet Home 3D is recommended because it Provides the simplest workflow for designing your home model with furniture and objects.
  • After modeling, export using the ExportToHASS plugin (original author @andyHA):
    https://github.com/adizanni/ExportToHASS
  • This plugin generates an OBJ model with correct object groups for the Floor3D card.
Use GLB Instead of OBJ
  • OBJ exports create many files and are often large in size.
  • GLB is faster, lighter, and more efficient for the card.
To convert OBJ → GLB, install Node.js and run:
npm install -g obj2gltf
obj2gltf -i home.obj -o home.glb --checkTransparency
To optimize your GLB using Draco compression, install Node.js and run:
npm install -g gltf-pipeline
gltf-pipeline -i home.glb -o home_compressed.glb --dracoCompression
Copy the resulting .glb file into your Home Assistant /config/www/community/floor3dPro-card/ folder.
Advanced Workflow (Professional Tools: Rhino, 3ds Max, Blender, SketchUp)
  • The card can support models created in Sweet Home 3D, Rhino, 3ds Max, Blender, SketchUp, and similar tools, exported as OBJ or GLB.
Importing OBJ for Editing
When importing the OBJ generated by ExportToHASS into a Professional 3D tool:
  • Import OBJ groups as: layers
  • Import OBJ objects as: none / nothing
This preserves the grouping logic required by the Floor3D card.
Exporting Back to OBJ
When exporting your edited model back to OBJ:
  • Do NOT export object names
  • Export layers as OBJ groups
This ensures compatibility with the card’s object‑group structure.
Critical Rule: Layer = Object Group
  • Every layer must have a unique name.
  • Professional 3D tools treat layers the same way Sweet Home 3D treats object groups.
Example Mapping
  • SweetHome3D OBJ:
    Group (door) → wing + frame + handle
    g lvl001Door_1
  • Professional App:
    Layer (door) → wing + frame + handle
    Layer lvl001Door_1
Level Naming Convention (original author’s format)
Use layer names like:
  • lvl000Flowers_18_3
  • lvl001...
  • lvl002...
These represent floors/levels, and if you don’t follow this naming convention, the level buttons will not work.
When exporting, layer names become OBJ groups.
Key Principle: OBJ group = layer
This is the shared logic across all Professional 3D modeling applications.
Installation
Method 1: HACS (Recommended)
  1. Open HACS in Home Assistant.
  2. Search for: Floor3D Pro Card.
  3. Select the repository and click Download.
  4. Restart Home Assistant.
After installation, HACS will automatically register the card as a Lovelace resource.
Method 2: Manual Installation
  1. Download the latest floor3dpro-card.js from the Releases page:
    https://github.com/levonisyas/floor3dpro-card/releases
  2. Place the file in:
    /config/www/community/floor3dpro-card/
  3. Add it as a Lovelace resource:
resources:
  - url: /local/community/floor3dpro-card/floor3dpro-card.js
    type: module
Notes
  • No custom repository setup is required anymore, since Floor3D Pro is now included in the official HACS Default Repository Store.
  • Manual installation is only recommended for advanced or offline setups.
Build Chain Floor3D Pro Card
Supported / Verified Environment
  • OS: Windows
  • Node.js: v16.20.2
  • npm: 8.19.4
:warning: Note: Node.js 18/20 may work but are not officially supported for this repository at this time.
Locked Tool Versions (Stable Build)
These versions are confirmed to build successfully:
  • TypeScript: 4.3.5
  • Rollup: 2.62.0 (2.62.x)
  • rollup‑plugin‑typescript2 (rpt2): 0.30.0
  • tslib: 2.6.2 (TS helper — resolves tslib cannot be found errors)
Configuration
north
north defines the north direction on the X‑Z plane.
For example, {x: 0, z: 1} (the default) represents north pointing in the positive Z direction.
Used together with sky: yes for correct orientation.
north:
  x: 0
  z: -1
Camera Rotation, Camera Position and Camera Direction
In edit mode, double‑clicking on an empty area of the model retrieves the current camera position and rotation. A Prompt box appears showing two sets of coordinates, which you can copy and paste into the card configuration in code editor mode. This allows you to manually define the new default camera position.
camera_position:
  x: 609.3072605703628
  "y": 905.5330092468828
  z: 376.66437610591277
camera_rotate:
  x: -1.0930244719682243
  "y": 0.5200808414019678
  z: 0.7648717152512469
camera_target:
  x: 37.36890424945437
  "y": 18.64464320782064
  z: -82.55051697031719
3D Model
3D Model Description
Name Defines the name assigned to the 3D model.
Path Specifies the directory path where the 3D model files are located.
Obj / Glb file Defines the 3D model file to be used (.glb or .obj).
Mtl Wavefront file Specifies the .mtl material file required for .obj models.
Object list JSON Defines the JSON file mapping model objects to HA entities.
Appearance
Appearance Description
Style Defines the general style applied to the card’s canvas element.
Lock Camera Locks camera zoom/rotation when set to yes.
Selection Mode Enables object selection mode for console listing.
Edit Mode PopUp Enables popup notifications in edit mode.
Header Defines whether the card header is displayed.
Click Enables single‑click interaction.
Overlay Enables the overlay panel for object‑related data.
Background Color Defines the canvas background color.
Hide Levels Menu Hides the level selection menu.
Global Scene Light Defines global light intensity (0..1).
Shadow Enables shadow casting for lights.
+ Lights - Perf Enables extra‑light performance mode.
Show Axes Displays 3D axes in the scene.
Sky Enables sky, ground, and sun environment.
Overlay and Action
When you enable overlay in the card’s Appearance settings, additional customization options appear, such as alignment, size, fonts, and colors. This creates a panel displayed on top of the model canvas. You must also enable the click option for it to function. Each entity has an action parameter that defines what happens when its associated object is clicked. If action is set to “overlay,” clicking the object displays the entity’s name and state inside the overlay panel.
Entities
Entity Description
Entity Defines the Home Assistant entity to attach to the card, using either a direct entity_id or an object_group reference (not applicable for text and gesture).
Type & Object Defines the binding between the entity and the 3D object, specifying the object_id of the model element to link with the entity.
Template Defines a dynamic JavaScript template in the format [[[ template ]]] that reacts to the entity’s state using variables such as $entity.
Action Defines the on‑click behavior for the entity, supporting ‘more-info’, ‘overlay’, or ‘default’ actions.
3D Type Defines how the entity is represented in the 3D scene, using types such as light, hide, color, text, gesture, door, or rotate.
Object Specifies the object_id of the 3D model element that the entity will be bound to.
3D Type — Light
Light behavior is straightforward: the light object illuminates when the linked Home Assistant entity is turned on, and turns off when the entity is off. If the light entity has color or brightness attributes, they are used to render the light. Double‑clicking the light object toggles it.
Light options Description
Lumens Defines the light’s brightness level (0–5000), with typical LED and bulb sources reaching up to 4000 lumens.
Color Defines the emitted light color; ignored if the light entity Provides its own color/temperature attributes.
Decay Controls how quickly the light intensity decreases over distance (0–2 typical).
Distance Sets the maximum effective range of the light in centimeters.
Shadow Determines whether the light casts shadows.
Target Object Specifies the target object for spot lights.
Angle Defines the beam angle of the spot light in degrees.
Vertical Alignment Controls vertical alignment: top, middle, bottom.
Direction Defines the direction vector of a spotlight using x, y, z coordinates.
3D Type — Color
The object is painted with the defined color when the state of the linked entity matches the specified value.
Color condition Description
Color Defines the color to apply (Hex, HTML, RGB).
State Defines the entity state in which the color is applied.
3D Type — Room
A parallelepiped is drawn to highlight the room. Works with all room objects whose names contain “room.” Non‑rectangular rooms are simplified. Supports color condition.
Room options Description
Transparency % Defines the room’s transparency level.
Color Defines the base color of the room.
Elevation (cm) Sets the vertical position of the room.
Label Controls label visibility.
Label text Defines the text displayed on the label.
Label Width Label width in scaled cm.
Label Height Label height in scaled cm.
Attribute Optional entity attribute to display.
Font Font used for the label text.
Span percentage Percentage of the plane the label spans.
Text Background Color Background color of the label text.
Text Foreground Color Foreground (text) color.
Color (Condition) Color applied when condition is met.
State (Condition) Entity state that triggers the conditional color.
3D Type — Hide
The object is hidden when the entity matches the specified state.
Hide options Description
State Defines the entity state that hides object.
3D Type — Show
The object becomes visible when the entity matches the specified state.
Show options Description
State Defines the entity state that shows object.
3D Type — Text
The object displays the entity’s state text.
Text options Description
Transparency % Defines transparency level.
Color Defines base color.
Elevation (cm) Vertical position.
Label Label visibility.
Label text Text displayed.
Label Width Width in scaled cm.
Label Height Height in scaled cm.
Attribute Attribute used for text.
Font Font used.
Span percentage Percentage of plane used.
Text Background Color Background color.
Text Foreground Color Text color.
Color (Condition) Conditional color.
State (Condition) State that triggers conditional color.
3D Type — Door
A door or window rotates or slides depending on type.
Door options Description
Door Type Movement type: swing or slide.
Side Hinge or sliding side.
Direction Opening direction: inner or outer.
Degrees Max opening angle (swing).
Percentage open Opening percentage (slide).
Pane object Moving pane object_id.
Hinge object Hinge object_id.
3D Type — Cover
Cover options Description
Pane object Moving cover component.
Side Opening direction: up or down.
3D Type — Rotate
The object rotates when the entity is “on.”
Rotate options Description
Axis Rotation axis: x, y, z.
Hinge-pivot object Pivot object for grouped rotation.
Rounds per second Rotation speed (negative reverses).
3D Type — Gesture
Double‑click triggers a domain.service call.
Gesture options Description
Domain Home Assistant service domain.
Service Specific service to execute.
3D Type — Camera
Double‑clicking opens a pop‑up showing the camera view.
Object Groups
Object Groups Description
Object Group Name of the group.
Objects List of 3D objects in the group.
Object Id object_id of each object.
Zoom Areas
Zoom Areas Description
Zoom Name of the zoom area.
Object Target 3D object.
Distance (cm) Camera distance during zoom.
Hi
Please allow me to drop some question to this project. Because Iam not sure if I interpret the documentation correct.
  1. “… Providing an interactive 3D floor plan …” Does this mean that I can interactively rotate, move, scale the model directly in the dashboard ? Or is it still based on the view which was active during export ?
  2. If YES, where is the rendering done ? On client or HA server side ?
  3. If client, whats about performance on a low end tablet. eg I use a older Fire10 tablet. Would this be suitable for small size model ?
  4. Is ist possible to interactively hide/unhide floor and walls ?
  5. Is it correct that I have to place and draw the objects (switches, lights ect.) while drawing the model. Later on I have to link these objects with HA entities ? Means no endless long YAML config as the overlay solutions require.
thx for clarification
Bernhard
Edit:
Sorry to bother you. I did not recognize that the card comes with a demo model. With that one I could answer all questions by myself.
Hi, its me again.
I have now installed your Floor3DPro card and managed to get your demo model rendered.
But i guess there is a bug in the card itself. The entity selector does not work. Means it popup, but I can only scroll and select, not possible to enter or Copy/Paste a entity name.
Furthermore, once an entity is selected the options menue does not allow me to select anyhing. It pops up for 1-2 seconds and then disapear. So ist unusable.
I have observed this behaviour with HA 2026.2.1 and two different browser.
Then I installed the original Floor3d card which works as expected, no problem at all. Rendering and working with the model in viewer mode works fine.
Needless to say that manual YAML editing works fine and give expected results.
greez
bb
@bbernhard
Hi, thanks a lot for the detailed report and for testing Floor3D Pro so thoroughly.
You are absolutely right — this behavior was not present in the original Floor3D card, and the root cause is not related to your setup or browser.
What actually happened
Floor3D Pro introduced a deterministic / transactional editor backbone, similar to a game-engine style architecture.
As part of that upgrade, the editor included an internal safeguard against a known Home Assistant issue from earlier versions:
configuration option array concatenation swelling, which could cause:
  • Increasing CPU usage
  • GPU pressure due to repeated re-renders
  • Growing memory usage over time
  • Editor slowdowns after many config changes
This safeguard reset certain internal option arrays on each editor transaction to keep everything deterministic and stable.
What changed in Home Assistant 2026.x
Starting with Home Assistant 2026.x, the HA core itself fixed this concat/swelling issue internally and also introduced a more aggressive transactional editor refresh behavior.
Because of that change, the additional safeguard in Floor3D Pro became redundant and had an unintended side effect:
  • Second-level dropdown menus were collapsing immediately after a selection
  • The editor looked like it was “refreshing” itself after each change
This is why:
  • Manual YAML editing worked fine
  • The original Floor3D card worked fine
  • Only the Pro editor UI showed this behavior
The fix
The latest update removes the now-unnecessary internal reset logic and fully aligns Floor3D Pro with the Home Assistant 2026.x editor lifecycle.
This restores:
  • Stable dropdown behavior
  • Preserved editor state between selections
  • Full parity with the original Floor3D editor experience
What to do now
Please update to the latest Floor3D Pro version and reload the editor.
The issue should be fully resolved.
Thanks again for reporting this — it directly helped identify a subtle interaction between the Pro backbone and the new Home Assistant core behavior.
In V. Faz.4, Floor3D Pro will migrate to getConfigForm():
Note: The current fix restores compatibility with HA 2026.x while keeping the editor backward-stable until the Faz 4 migration is completed.
Confirmed, now the problem is fixed.
thx lot.
btw. I just found some more (minor) issues with Visual editor.
Shall the reported here or in the original Floor3D thread ?
best rgds
Bernhard
Hi Bernhard, no worries at all — feel free to ask anytime.You can post your questions wherever you prefer, but if the issue is related to the Game Engine Backbone Edition, this thread is the most up‑to‑date place and the easiest for me to follow. Thanks for checking things so thoroughly.
“From my perspective, Home Assistant doesn’t have any native 3D architecture at all — the frontend is simply not designed for 3D workflows. What I’m building is not just a different style, but a full backbone‑level system closer to a modern game‑engine architecture, so my expectations and design patterns naturally differ.”
Do you have any news regarding your repository availability?
It is an amaising work you have here and it is a shame that github is not letting you share it with the world!
By the way, i am using as well overlay card and I don’t know if you are working in such idead but is it possible to have the overlay card attached to an object of the 3D model? This card would be activated by touching the object or just simply floating on top of the object. ( like in Zircon3D)
Thank you.
Best regards,
Mike
Hello Mike, @mikecastroosorio-cod
Thank you very much for your message and for your kind words about my work. I also appreciate your sympathy regarding the GitHub situation — my innovative work being blocked like this has been very discouraging, so your support truly means a lot.
About your question regarding attaching an overlay to a 3D model object:
Yes, this is already possible through two different interaction layers.
1) Overlay Pro Card Trigger API
You can open or close an OverlayPro Card programmatically and bind it to any object ID in your 3D scene.
window.dispatchEvent(new CustomEvent('overlaypro-card-open', {
  detail: { target: '001' }
Overlay Pro Card listens for:
  • overlaypro-card-open { target: "001" }
  • overlaypro-card-close { target: "001" }
This allows you to trigger overlays from any event: object click, gesture, automation, script, or external JS.
https://community.home-assistant.io/t/overlay-pro-card-engine-powering-overlay-popup-ui-layers/
2) Floor3D Pro — 3D Type / Gesture
Inside Floor3D Pro Card, the 3D Type — Gesture system supports interactions such as:
  • Double‑click → triggers a domain.service call
    This can be used to open overlays, toggle entities, or activate any custom logic.
Upcoming Platform
I’m also preparing a full bundle called Scene3D — Full Interactive 3D Dashboard Platform.
“The Layered (Overlay) Stack Card is already ready and will soon appear as the Scene3D Pro Card, forming a core part of the upcoming Scene3D platform.”
Recommended Setup (for now)
For the most efficient and clean workflow, I recommend using a vertical stack:(Panel View)
  1. OverlayPro Card (first card)
  2. Floor3DPro Card (second card)
This gives the best interaction flow and avoids UI conflicts.
Levent
Hi!
Thank you so much for the tip! I will try it no time!
I can smell the improvements from here!
Don’t dispair about github situation! It will be resolved soon, I guess.
Let us know once it is back again so we can enjoy your excellent work!
Keep it up Engineer!
Thank you for sharing!
Mike
Hi I tried to use the 3D Type/Gesture to popup a dashboard view but it seems something wrong. It shows “popup_view/open”.extra keys not allowed @ data[‘entity_id’].
Hi All,
First of all, many thanks to @levonisyas for continuing the amazing project. I startet a while ago with the original floor3d card from @adizanni and invested quite some time rebuilding my home with sweet home 3d. It became a little complex and I realized that the card slowed down significantly when adding more lights to the floor plan. As this was one of the main functions why I wanted to have my digital twin (and be able to use it on my iPad or iPhone) I stopped using it.
Now I startet the testing again with the new card to see if I can integrate all the functionality that makes it a true twin…
What worked so far is that I can:
see all open and closed doors and windows in my home;
see if I got mail delivered (another door sensor in my mailbox);
adjust the temperature in each room;
monitor every camera by clicking on it;
get the rain and temperature from my weather station;
(after a lot of testing) control and see the status of all shutters.
For the shutters and one awning I wanted to use the cover 3d type but it did not work the way I wanted. The problem is that the shutter and awning are just moving into other parts of the house. So I created windows with different states of the shutters 0%, 10% and so on, and did the same for the awning. Now I do have an entity (select input) for each of them that triggers the show 3d type.
What I am still struggling with are two points:
  1. I am not able to use the visual editor. I made sure to have the latest release installed, I tested with different browsers, tried it with a windows pc, a macbook and my iPad. But I can only see the drop down menu and when I klick on an option it does not select it. Does anyone have the same problem (or even better a solution? :stuck_out_tongue_winking_eye:)
  2. And this is the real critical point. I do have several hue, tuya lights and other lights that are triggered by shellys. The moment I put more than 6 light sources in the floor plan the whole model becomes very laggy and slow. I tried different settings with lower lumen, shadow yes, no, decay 0-2, and distance <100 but it made no real difference. Does anybody have the same experience or any suggestion what I can do to get it working? This is a real deal breaker for me, as I want to see which lights are on and I want to trigger them with the digital twin.
One additional Information, there is no difference if the lights are on or off. Does anybody know why that does not impact the performance? I thought that the rendering is slower when the lights are on but it dose not seem to be the case…
Greetings,
Drago
Hi
Iam using your Floor3Dpro card sucessfuly. Speed and features are perfect for me, I do not miss anything. Thank you.
But there is one painpoint. After each change of the yaml or the 3dmodel I heavily struggle with the browser cache. , HA config reload, Incognito Mode, page reload and other tricks do not necessarily work. Always I have to fiddle around until i can see my modification.
Any advice or best practice how to deal with that ?
btw. I use VSCode for YAML editing.
thx in advance
Bernhard
One more thing: I noticed that the card drastically slows down the card browser in the "add new card" Window. I guess this is because the new new card windows renders a preview of all cards.
It even happen that the browser timeout and no card can be added.
Once I remove the floor3d-card folder it is fast as normal.
Is there any way to prevent the card from rendering in card browser window ?
thx in advance
bernhard
Hello, I have been using the original card floor3d card for more than two years, using obj's 3D model files, which have been very stable without any errors until recently when I discovered that some elements in the 3D layout drawings were rendering incorrectly. For example, for an electric fan, if it is turned on, it should have a rotation effect. I used type3d: rotate, but I haven't had this effect recently. The windows or curtains open and close, and the effect is not synchronized. I have to refresh the 3D floor plan to update the status. I guess it may be related to the browser kernel update or haos system version update, so I was looking for an alternative solution and found floor3d pro card, which is very useful. The problem with my old card. On this new card, it does not appear.
What I am very concerned about:
  1. Is this card an enhanced version of the meta card? Or is it the performance stable version? What is the biggest difference from the original card?
  2. I directly copied all the configurations from the old card to the new card, which is completely compatible. I kept the first line of type: custom: floor3dpro card, and all other configurations were from the original card, so it can run successfully.
Thanks for creating this. I've been using adizanni's original Interactive floor 3d plan for years, and it has continued to work well. Can I run my existing GLB models and card YAML in your version without modification?
@levonisyas, thank you for floor3dpro-card. I’ve been running it on a large model and ended up making a set of changes, which I’ve published as a fork: floor3dx-card
It is based on 1.5.3-Pro.Faz.2.1. The source stays close to yours, and the element names are changed at build time, so it installs next to floor3dpro-card and the two can be compared on one view. Configs are compatible; only the type: line differs.
Bugs I found that also affect floor3dpro-card
  • Doors and windows displaced after leaving a view and coming back. The asset cache shares geometry between card instances, but the door, rotate, cover and room setup re-centres geometry in place. The first visit is fine. On the second, the new card starts from geometry that is already shifted and shifts it again, so every door part ends up far from the house until the browser is refreshed. The fix gives those meshes a private geometry copy. There is a regression test in the repo.
  • Low-resolution rendering outside panel and sidebar views. The ResizeObserver is only attached in those two modes. Elsewhere the drawing buffer keeps its load-time size, so a card that loads while hidden, or before layout settles, renders into a small buffer that gets stretched.
  • A second card on a cached GLB skips the GLB-specific handling, because _modeltype is only set on a cold load.
  • Console flooding. Entity <undefined> not found is logged for every entity-less gesture entry on every state update. With 19 gesture entries that was several hundred lines per update.
Additions
  • Draco, Meshopt, WebP and KTX2 model support, with the decoders shipped alongside the card. A bare GLTFLoader stalls at “Loading: 100%” on these files.
  • pro_skill: mobile lowers the pixel ratio only while the camera is being dragged, then redraws at device resolution. pixel_ratio: 1 restores the permanent clamp.
  • Options pixel_ratio, antialias, anisotropy, and light.light_object (one light for a multi-part fixture while the whole group stays clickable).
  • Compression scripts in tools/ that preserve object names, order and identity node transforms.
If you want any of this upstream: the branch engine-changes-for-upstream in my repo holds the engine changes as one commit on top of your main, with your element and file names untouched. You can take whatever parts are useful.
What has and hasn’t been tested. Daily use on Home Assistant OS with Chrome, two Sweet Home 3D exports of about 2,900 and 1,300 objects, plus a headless-browser test harness. KTX2 was tested only on a test model.
Install through HACS as a custom repository (type Dashboard) with the URL above.
